Question about Kenmore 24032\24036 Top Load Washer
Kenmore-80series washer -the agitator needs to be replaced.
One of the agitator's wing is broken due to heavy duty wash. How do I replace the agitator?
  • Anonymous Jan 30, 2009
    I think my agitator in my washer is broken right off. Can this be replaced?
  • 640 Answers
Remove the agitator cap,,remove the plastic seal under just pull straght up with your hand,,inside agitator theres a nut,,remove thi 1/2 inch nut with ractet and pull agitator straight up
Posted on Dec 28, 2008
My washer works perfect except in the heavy duty fast/fast setting It agitates and seems to be working very hard then stops. it starts for awhile then stops again. There is also a smell of hot metal.
Double check your coupling work first then try the drum bearings by reaching in through the front and see how much movement the drum has? Does it rotate smoothly? Have you run it with the access panel off and listened close up?
Feb 16, 2016 | Washing Machines
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore 70 series 110 washer won't drain or spin, but agitates
You have a broken lid switch. Check to see if the switch is broken off of the two screws that hold it under the lid. If it is, get a new one, take off the case and replace old switch with the new one.
Apr 06, 2009 | Kenmore 24932 Top Load Washer
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 28731 top load washer
You will need to replace the motor coupling. Here is a video to show you how to do it.
Oct 24, 2008 | Kenmore 23822 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
183 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
