Question about Akai PDP-4247 Television
Black screen on Zenith plasma tv's
Zenith 42''model P42W34: The main power board is producing the correct power, the Z SUS board #6871QZH030A has 2 bad 250v 680uf electrolytic radial 105 deg C capacitors and the Y SUS board #6871QYH027A has 2 of the same value caps that are bad. I priced the 4 caps for $20, they have a 2000 hr rating(seems short). Has anyone benn successful replacing these caps?
Zenith 50'' model Z50PX2D: The main board #E247691 has 3 bad capacitors. Two are 450v 330uf and the other is a 250v 820uf electrolytic radial 105 deg capacitor.I priced these at $18.
Is it the short cap life that causes failures? These tv's are only a few(1.5 &3) years old. All 3 boards are $500.
  • Kris Luettchau
    Kris Luettchau May 11, 2010
    Hi there. Looks like you have a multiple board problem! Zenith 42''model P42W34-- sounds like you got a handle on things. I have tyhisd same tv, im about to open it and check the fuses first, then the rest...
    i'll post pics as i go, it may help, since im not sure which ones your talking about.
  • Anonymous Mar 23, 2014
    Stays on for uncertain short period then powers off. Have replaced all electrolytic caps. Cannot access engineer mode to reset lamp fault if one exists.
    Scholar:
  • 50 Answers
Hello, My name is Dave and I can help you fix your Plasma TV. Give me a call. Feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Posted on Jan 29, 2009
My 42" Zenith plasma flat panel television model
You can check the va, vs adjustment, but alot of plasmas does this, my first thought would be the y sus board, it also could be the panel which is not worth fixing, if it is really bad, check voltage and if this isn't out then Y- board is the next thing to check.
Jan 27, 2011 | Zenith P42W24B 42 in. Plasma Television
LG 42 inch plasma. Half screen is ok (rh side) other side black
Buffer boards or Y-SUS main needs to be replaced. What do you mean by motherboard? The power supply board or the Logic or X main.... They YBU/YBL and the YSUS work in unison. Y-Buffer upper controls top half, Y Buffer lower control bottom have YSUS controls both of those. There is also D, G, E F boards that can split screan. But they to are controlled with the Y-SUS Main. Hope this helps...
Jun 29, 2010 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
I have 3 black stripes on my Zenith 42
Turn off the TV then unplug it. Disconnect the cable connection and clean the terminals. If the stripes still exist, you have a bad TCP (tape carrier package). It is responsible in transmitting color information to the display panel from the X-Drive (A-Bus) Board. This is not an easy repair. Service of an experienced or a qualified technician is recommended.
Nov 27, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
1/2 the screen goes black
vera partner what you have is a problem of poor voltage or damaged card card check your x that is the bottom of the plasma must consist of at least four cards
Aug 21, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Zenith zsus pop
Hello to all! Some of the time with LG type Y & Z sustain boards you must replace both the boards in order to completely the repair or but not always. Please feel free to message or call me if you need more help with your Zenith plasma TV. 1-503-432-9904 / pleasefixitdave@yahoo.com Ask for Dave! If you are reading this post and you need help with a plasma or LCD type TV give me a call!
Dec 20, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black verticle line on screen of zenith p42w34
I'm sorry you have not been given a clear answer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave! If your reading this post and you have a plasma or LCD type TV and need any type of help please feel free to give me a ring or message me with the problem your having. I'll do my best to help you!
Talk to you later!
Dave :-)
Nov 30, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Zenith p42w34 will not turn on
Before Opening, double check something for me and post a follow up. I have this tv and I believe it has dual power buttons. One main and one secondary. A remote can't turn it on unless the main power button on the bottom left is on.
Please post follow up.
May 13, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Hitachi P50H401 video goes off and on
this is from a tech tip I got that should help.
No Picture:
1. The Power Supply may not be producing the correct voltages.
2. The Digital Module (Digi-Main) may not be producing correct
turn on commands (Power 1 and 2).
3. The Logic PWB may not be supplying the correct Vs/Va turn on
commands (Vsago and Vcego).
The Panel can have a defect of two natures.
1. The panel is shorted.
2. The panel is defective, but not presenting a short.
3. Y-SUS and/or X-SUS may be defective (Shorted and or nonworking
May 01, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Zenith P42W34 EDTV Plasma Black Line
Just reheat and add soder to fuse connected behing the driver boards.
Oct 19, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Televison & Video Logo
737 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
