Question about Philips Universal PH301S Remote Control
Hi; I am Gerri I have a philips universal remote that I want to program to hitachi t.v., also I have a one for all universal remote that I want to program to symphonic tv.
    Scholar:
  • 61 Answers
1. Turn on your t.v.
2. press the T.V. Button on your universal remote. (read the manual for this part as sometimes they have you hit the set button first.)
  1. Press and hold Set until the light on t.V. button blinks once, pauses and then blinks twice. Now release the Set key. (again this might be different for each universal remote.
  2. Enter the first three-digit TV code for your Hitachi from the list which follows:
    145, 151, 056, 032
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  3. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TV Why test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
Now for the symphonic do the same thing but the codes are. 0155 is the Symphonic TV/VCR combo code
or 0126, 0053, 0091
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up button and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You basically keep hitting the increment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Posted on Dec 23, 2008
  • 405 Answers
    Guru:
  • 449 Answers
HITACHI ............ 042 543 545
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand. happy holiday
    Master:
  • 416 Answers
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
or you can get code herelink for the complete code list www.lexrixa.com/remote-control.htm
Good Luck
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
I NEED THE REMOTE CODE TO OPERATE A HITACHI TV FROM A PHILIPS UNIVERSAL REMOTE
Direct Philips Magnavox Universal Remote Code Entry PM335
DVD, etc.).
brand.
HITACHI ........... 0088/ 0059/ 0142/ 0060/ 0072/ 0004/ 0009/ 0091/ 0001/ 0012/ 0061/ 0137/ 0139/ 0141 /0179 /0227
May 09, 2011 | Hitachi 53UDX10B 53" Rear Projection...
I need the codes for a Philips Universal Remote for a Hitachi Tv
Hello
The universal remote code for Hitachi TV/VCR combo with philips universal remote model LC034] is
0324.
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
flashes.
CHANNEL UP. If the device
not operate your device, try one of
the other codes for your brand.
OK.
Feb 09, 2011 | Televison & Video
Philips 3003 universal remote code for hitachi tv
ok here are all the codes for your control. to program a hitachi 0410, 0507, 0815, 0607, 0808, 0002, 0502, 0710, 1801, 0701, 0802, 0707, 0315, 0515, 0715, 0519, 0324
now if you dont know how to program it here is the manual that will tell you how. click here for the manual. now if you ever need to program any other device in this remote control you can use philips code finder by clicking here selecting what the device is then the brand
if this helped assist you please feel free to rate the solution. If you need further assistance then follow up with a comment and i will be glad to assist you. Thanks, Midwest-tek
Aug 30, 2010 | Philips SRU3003 Remote Control
Need to program a universal remote for the hitachi 57 and cant find the mannual
What brand of remote are you trying to use?
Each style of universal remote has its own set of codes. I prefer the Philips models.
Jan 05, 2010 | Hitachi 57F500 57" Rear Projection...
I need to know how to program my CLU-5729TSI to run my Philips DVD player DVP1013
I have Hitachi universal remote CLU - 5729TSI how can I Program it to change the code for a different tv. a toshiba 36 inch it is around a 1999-2000 model.
Sep 27, 2009 | Hitachi CLU-5713TSI Remote Control
Need codes for a philips universal 0713 remote control
i lost my mannual to my philips universal remote and i need to program it to my hitachy vcr,sharp tv. and my dvd
Apr 11, 2009 | Philips Magnavox Learning Universal Remote
Can you help me program my remote?
hi i have a philips universal a rca tv and a dvd named lennox sound 2003 i want to program the dvd with the remote please help no codes lost
Feb 09, 2009 | Philips Universal PH301S Remote Control
Lost codes for philips universal remote control 34/08
hi
i have a philips universal remote needs codes to program my dvd play lennox dvd 2003
Feb 08, 2009 | Philips Universal PH301S Remote Control
Universal Remote iwave
I Have The Codes,But No instructions!! Big IWave . 0054-Philips Hitachi-0145 JVC-0053 LG- 0178 OR 1265
Jun 09, 2008 | Hitachi 50HDA39 50 in. Plasma HDTV
Televison & Video Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
