Question about Canon imageRUNNER 6020I Copier
Waste Toner Container
Where is the waste toner container located on the Copier?
  • Anonymous Nov 27, 2007
    do you have to unscrew the back panel??
  • Anonymous Apr 17, 2008
    Looked at your solution. Opened up the back of our Canon Image Runner 330. Our container is on the side back. Only needed to open the lower side piece. Got it cleaned out. Thanks for the info.
  • 186 Answers
You must take off the back panel of the copier and you will see a box sitting on the bottom. You can empty it and should be ok
Posted on Jul 10, 2007
Replace waste toner box
The toner box should be a clear plastic container and you should have no trouble locating it. I have emptied the container before and reused it. Just be careful and not inhale the toner dust
May 22, 2014 | Dell Office Equipment & Supplies
Copier says to replace the waste toner container...where exactly is that located. we don't have the manual
the waste toner container is located on right side way of copier behind plastic cover in left angle, near the paper path door.
Hope that helps!
Apr 26, 2011 | Canon imageRUNNER 5020i Copier
Where is the waste toner container on a canon 7065 copier fax machine
waste toner container is located in front side.open your toner door and door support front frame where the canon logo was sticked.after removing this you can see easily waste toner container
Jan 27, 2011 | Canon ImageRUNNER 3235 Black and White...
How do i move the tray? and where do i find the waste toner container?
the waste toner container is located at right sideway of copier in right lover corner covered with plastic cover with one screw.
Wich tray do you want to move?
Jul 16, 2010 | Canon imageRUNNER 5000 Copier
Need to locate the waste toner container on a Canon ir 6800
The waste toner bottle should be on the right side of the copier toward the rear of the copier. It is behind a pannel that is held in with 2 screws. Take the screw out & open the pannel & the bottel should be inside that opening it is a milky white container. Pull it out, it is rather large. When you dump out the toner make sure you have a plastic bag with No holes in it, it can be very messy if you are not carefull......Good Luck
May 20, 2009 | Canon IMAGERUNNER 6570 Copier
Canon Imagerunner C3100
If you open the front door,the plastic container in front is the waste toner container .Remove that bottle and dump all that toner.Make sure the neck of the container is free from toner inside and outside.And put the container back in it's place.
Mar 29, 2009 | Canon imageRunner C3100 Copier
Estudio 3511 empty waste toner problem
Hello sir;You have to empty waste toner container, it located at the end of the drum unit.
Jan 05, 2009 | Toshiba Estudio 200L Copier
Where is the waste toner container in a Canon 5020i?
ok on the right side of the copier lower right cover 2 screws pakes the panel off behind it is a large plastic bottle pull it out empty it put it back in. then in this order touch these keys... add func// 2 & 8 at same time / then add func again screen should change to serv mode.. then in this order touch copier / counter / misc/ waste toner / clear /ok turn off and on good luck
Jan 02, 2009 | Canon imageRUNNER 5020i Copier
Cannon Image Runner 5570
If the copier is indicating to empty waste toner bottle do as previously described. Until you reset the copy counter for the waste toner you will still get the message. Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's.
Nov 16, 2007 | Canon imageRUNNER 5570 Copier
Sharp AR-C160 Color Copier Problem
hi im jules_09.its easy just remove the collecting container it must be full with waste toner then just disposse of the waste toner.just open the front door then locate the container its just ther you cant miss it.its a plastic bottle sometimes at the side of the machinre,
Oct 11, 2007 | Sharp AR-C160 Color Copier
Canon imageRUNNER 6020I Copier Logo
276 people viewed this question
Clive
Clive
old marine
old marine
