Question about Goodman GMS90703BXA Heater
Making noise my gmp 125-4 is making noise when blower comes no
  • 1,420 Answers
Check your air filter. The blower may be off balance or have dirt in some of the fins. Look on the blower wheel for a small tab of metal used to keep the blower in balance. It may have fallen off.
Posted on Jan 02, 2009
My Goodman furnace model GMP Series runs the blower fan without calling for heat or cool! I can disconnect the thermostat completely and the fan still comes on. Thanks!
Likely have a stuck relay. You can replace the board or install your own relay that controls the fan.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 20, 2017 | Heating & Cooling
Ac makes whining noise on a 2004 Pontiac grand prix
Is the whining noise coming from the engine compartment where the compressor is located or is the noise coming from inside the car? If the noise if coming from inside the car it could be your blower. When a blower wears down the bushing is the first thing to wear down and it begins to have play. That makes the blower/fan vibrate making a loud whining noise. Replacing the blower could solve that whining noise.
If the noise if coming from the AC compressor, it also could be a bad bearing within the compressor.
Feb 23, 2015 | Pontiac Cars & Trucks
Have a gmp 125-5 furnace and light blinks 5 times
Here what i found , five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Mar 29, 2014 | Heating & Cooling
Janitrol gmp gas furnace ignitor troubleshooting 125 blink
if it is shutting off abruptly the limit is either wired wrong or set wrong. If the fan comes on and blows the flame out there is a hole in your heat exchanger which can result in fire or carbon monoxide poisoning. Have an experienced tech take a look at it to be safe.
Nov 25, 2017 | Heating & Cooling
Have a gmp125-4 furance blower runs all the time checked themostat wires error code 1 blink then 2 then 3 then 5 furance works if you turn power off turn back on when heat kickes off blower comes on gives...
Sounds like limit switch issue. Furnace heats up, high temp limit switch opens, fan will stay on. GMP model is older and do not have the codes.
May be over fired, have airflow problem, to cause the limit to open.
Next time before shutting off power, try to find the limit, it has two wires that connect to a 1.5 x 2 inch card mount to the furnace fire wall. tap on it and see if the blower stops. If so replace the limit.
Sep 06, 2011 | Goodman Heating & Cooling
Janitrol GMP 100-4 replacing blower new blower has extra yellow wire. do I just not connect it
Look on the motor wiring diagram, being that it is yello would lead me to believe that this is
a muti-speed blower. If this is true, look for a place on the terminal board that says "Park"Otherwise make sure you tape it off and move it out of the way
May 26, 2011 | Goodman Furnace Draft Inducer Blower ...
Hello, I bought the 32 ford model kit from Gmp but the instruction manual was uncomplete. the only part that was described is the steering mecanism. i want a manual for the whiring of the engine. ...
Hi there yes thats all you get if you read the boz it will say the instructions are brief and that you need to have a good knowledge in 32fords and hotrods i studied loads of pics for mine and when its done with an exelaxant paint job its a very rewarding model.
just think that the manufacturers in china they have the same instructions as you get, a few pics they have to learn to build them to.
hope this helps if you would like more on gmp help please do contact me at austintant@hotmail.co.uk put your subject as gmp
Mar 18, 2011 | Ford 1932 Ford Two In One Model Kit 118 By...
I have a goodman GMP 125-5 furnace. I have
sounds like the primary limit typically behind the gas valve its larger then the others, rectangle in shape with 2 wires going to it. be careful if your bypassing limit this can create a very hazardous condition
Nov 06, 2009 | Goodman GDS80904BNA Open Flame Heater
Goodman furnace\ blower comes on,unasked
Sounds like the fan switch on the furnace is set to low. Turn power off to furnace, take door off of furnace look for a fan switch, it may be a fan - limit together. The limit settings should be approximately 160° to 200°, and the fan settings should be about 100° to 140° set it to 120° it it's already set there then you probably need to replace it.
Aug 03, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
379 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Dennis Boxerman
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
