Question about Whirlpool Duet GHW9150P Front Load Washer
My washing machine shows a F2 error and won't finish washing my clothes. I tried pushing the button for 5 seconds, but nothing happens. I even unplug the machine from the wall. What do I need to do?
    President:
  • Whirlpool Master
  • 2,651 Answers
F 02, is a "long drain" error. So perhaps there is a clog in your pump assemble. reomve the 3 screws from along the front bottom of your machine(3 torx 20 screws) youll seee the acees cover to your pump behind there.
Posted on Dec 23, 2008
LE error code has popped up & suddenly the control lock is on, I have pressed the control lock & it counted 3,2,1 & nothing happens, won't unlock & LE is still there
if the door locks and wont unlock
LE error
then your machine still has water in it from the last spin/ wash
i think its a blocked up waste outlet
or the pump is blocked up
you need to check the machine is draining correctly and in a timely manner.,..
or it will fail
you need to fully drain the machine then turn off the mains
wait 5 mins and the door will then open
then check the drainage...
Feb 08, 2015 | Washing Machines
Tip
LG Washing Machine LE Error Code or Fault Code
If you are getting a LE error code from your LG Washing machine, there are a couple of reasons why the error code would be displayed.
The main cause for this error code is because you used too much or the wrong kind of detergent in your washer. This code is set off by too much suds in the washer. Not only will this set off the alarm code, but it may also cause your washer to leak and even start to have a bad smell from the dampness getting where it should not be.
To remedy your problem if you do get this code you must first just let your washer sit for a half hour or so to let the suds disperse. Unplug the washer to erase the code and also to make sure it does not run. Then plug the washer back in and press the power button. Then press the spin button until the no spin/drain only cycle is selected. When all of the water is drained from the washing machine, remove all of the clothing and run a rinse and spin cycle to remove the excess soap from the washer. Then you can finish washing the clothing, but do not add any more soap.
Always make sure that you use the proper amount of detergent and use detergents that are low sudsing.
Other causes for this code can be a large load on a gentile wash cycle. This will cause a miscommunication to the motor. If this happens, lighten the load, reset, and restart the washing machine.
Just plain overloading the washing machine can also cause this error code. The motor will get too hot trying to handle the large load and cause the fault code. If this happens, unplug the washing machine and wait thirty minutes before attempting to wash again.
If you get this code immediately on the start up of a new washing machine, it is best to try to just reset the machine. Unplug the machine and hold the start/pause button in for five seconds. Then plug the machine back in and restart the washing machine.
http://www.fixya.com/support/r4342015-lg_washing_machine_ie_error_code
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
http://www.fixya.com/support/r4341798-lg_washing_machine_oe_error_code
http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
on Mar 15, 2010 | Washing Machines
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
Can't get a Bosch MAXX 5 WAA24161GB to start. Changed fuse and socket, but machine still won't work?
hello, have you checked the glass fuse inside the washer make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 06, 2011 | Bosch Washing Machines
What does it mean when it flashes LE on the display?
Hi, if you are getting a LE error code from your LG Washing machine, there are a couple of reasons why the error code would be displayed.
Take care
May 24, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De GO PATS
