Question about LG enV VX9900 Cellular Phone
LG EnV2 powers off w/ error message
My phone is showing an error message: use genuine battery and then powers off. This just started this evening and the phone is a replacement for the original phone I bought last summer.
  • 6 more comments
  • Anonymous Dec 23, 2008
    my phone comes up with error message and then shuts off also.
  • Anonymous Jan 02, 2009
    same ****
  • Anonymous Jan 13, 2009
    i have the same problem... How do you fix it?
  • Anonymous Jan 17, 2009
    yep, me four... if i charge it for a really long time, it will just charge and i can turn it on :P it takes hours though, so not a good solution
  • Anonymous Feb 12, 2009
    same here. it just randomly powers off, then why i try to turn it back on it says theres an error and to use a genuine battery. then turns off. sometimes it will come back on, but its getting to be a pain
  • Anonymous Mar 07, 2009
    I have the same problem. I bought the phone from Verizon and it has the battery it came with. I've only had it for about 2 months. I don't turn it off because everytime I try to turn it back on it says "use genuine battery, power off". Unfortunately, the phone has turned itself off twice while I've been asleep. Just this morning I tried for over an hour to get the darn thing to turn on. I just push down on the battery as hard as I can. Finally, it turned back on. I don't know what to do about it. I don't want to take it to Verizon because they'll just hand me another phone that will probably mess up worse than this.
  • nijlkam May 11, 2010
    Solution link . . . http://www.LGenV-VX9900.com,
  • echomoon May 11, 2010
    What type of battery do you have in? Did you buy it from verizon?
  • 3 Answers
I had the same problem but found a solution. Take the battery out of the phone. Put it in a ziplock bag & place it in your freezer for about an hour. Before you put it back in your phone hold the end key on your phone for about 15 seconds. Place the battery back in the phone & try to power up. If the battery is completey dead throw it on the charger for about 15 minutes, then attempt to power up. If the phone comes on place it back on the charger. These has worked for me several times without fail. The key to this phone is not to let the battery go totally down, & never turn it off. Seems stupid but if you want to avoid doing the steps above I recommend it.
Posted on Feb 02, 2009
I have the same problem...try a couple of things, take the battery out and wipe the copper metal connectors off with nail polish remover, on both the battery and inside where the battery sits in the phone. If that fails to work when you are turning on the phone push down on the battery as hard as you can down and slightly to the side, you should feel the battery move slightly. Hold it in that position as tightly as you can while turning on the phone. The problem with the phone is that the copper terminals get dirty and it tells the phone not to turn on. If you have to go back to verizon with the phone I doubt they will cover the battery...your looking at 49.95. This fix is assuming you did not get your phone wet in any manner.
Posted on Jan 27, 2009
This usually means water damage in the phone or bad connector between battery and phone. water damaged phones are weird. They can be fixed or dryed out with the rice trick. But your phone will act up eventually. Sometimes its everydady sometimes every month. Mine worked after i left in a bag of rice for a week. Worked fine for 2 more months and it's acting up again. So sometimes i have to squeeze the battery where the connectors meet while powering on and it won't do the "genuine battery" power off. Sometimes it will work for a while sometimes just a few minutes. Sucks these days you almost need a phone with warranty. Mine was a month old and it got waterdamaged i guess from when i took a shower and steam from the shower damaged it, but it was sitting on a counter 3 feet away. Some phones are just Lemons?$#!%%$#$~!
Posted on Jan 02, 2010
I had this problem with my ENV 3 and yesterday Verizon told me it was junk.They said the water damage corrodes the circuit board almost immediatly.I decided to try this idea I had today and for the past 3 hours it is up and working like new.I removed the 5 small screws and took the phone apart. I unclipped the metal circuit board cover and used a Q-tip and rubbing alcohol and "dabbed" the entire circuit board.Gave it a few minutes to dry completely and put it back together.Installed battery and turned it on. BE CAREFUL when disassembling the phone DO NOT get in a hurry and break it or tear any of the connections. I hope this helps some of you!!!! This was Very Light Water Damage, not submerged.
Posted on May 19, 2010
I know how to fix this but its the biggest pain in the *** ever. when ur phone does this take the battery out put it in a slip-lock baggy and stick it in ur freezer, for a about 45min -1 hour, im on my 3 env2. im going to verizon tomorrow, and telling i want the env3, and if they dont give it to me, then ill cancal my service
Posted on Sep 09, 2009
I am having the same exact problem with my phone. I purchased my phone less than a week ago. I just got off the phone with Verizon and I was told that it is defect in the phone and there is no way to fix it; the phone needs to be replaced. Thankfully, I am still under warranty.
Posted on Jan 22, 2009
On power up, why does it indicate 'use genuine battery', then shuts off?
If your phone does not indicate it is charging, the 'use genuine battery' message may its way of telling you the battery is defective.
Nov 23, 2015 | LG VX8350 Cellular Phone
How do you erase text messages from the LG VX9100 ENV2 RED when the screen inside is broken?
To delete single messages on an ENV2 with broken inner screen:
1) Go to your message inbox on your external screen to find the message you want to erase, but don't open it.
2) Open your phone and hit OK (to open message)
3) Hit the top left silver button, then OK.
Wait a few seconds for it to delete. If you know you have multiple messages right in a row you can skip step 1 and the first part of 2 (open your phone).
Mar 22, 2011 | LG VX9100 Env2
Genuine battery message
the software in the phone needs to be reprogramed at a store and they can fix that within maybe 20 minutes. also the phone may have a glitch in the software do to upgrades on the system. if the battery has gotten too warm though it will fry the battery to where the phone wont register it as a good battery. i have never had mine show use genuine battery though. i talked to a friend who works for verizon and she said only technical support at a main brach store can fix that.
Jul 22, 2009 | LG enV VX9900 Cellular Phone
LG enV2 stopped autosaving sent messages
How many pics, video, sounds and music do you have stored into your phone? You should save all of these onto a micro SD card.
How many texts are you saving onto your phone? It will only hold a little over 200 in your inbox. You many need to clean it up a bit..
Jul 10, 2009 | Verizon Communications enV2 Cellular Phone
LG env2 will not save text messages
This happened to me. My problem was that i had a memory card, and i accidently put the save options for my pictures to my phone memory instead of to card memory. So it messed up my phone.
May 30, 2009 | Verizon Communications enV2 Cellular Phone
LG env2 will not turn on
i am having the same problem with my env2. . .any suggestions?
May 23, 2009 | Cell Phones
Lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
Not exactly a solution. I tried leaving it off overnight and tried it several times after removing and inserting the batteries. I also cleaned the contacts with contact cleaner and a Q tip. It did not fix it. But I just left it off for 2 days meaning to go to the Verizon store and get it fixed or replaced. But I turned it on now and it fixed itself! Model VX8300. Maybe the contact cleaning did it but it had to dry more. You can use a Q Tip dipped in a cup of water with a teaspoon of Mr.Clean. But then rinse it with a water wet Q tip and then dry it with a paper towel. I used contact cleaner.
Dec 06, 2006 | LG VX6000
LG enV VX9900 Cellular Phone Logo
4,853 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
