Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator is freezing everything.
I have a GE die-by-side refrigerator, model number ESS25LGNA WW. It has been freezing everyhing in the fridge. I initially tried moving things around in the fridge and lowering the temperature to 1 and it did not make any difference. I removed the EPS FF Inlet Asm and disassembled it to learn the the door had broken. I attempted to super glue it as a temporary fix to see if that was indeed the problem. I believe that it was. It was fine for the first day, but now I'm back to 25 degrees in the fridge. My questyion is this... would merely replacing the entire asm solve my problem? I can't believe they do not sell that little door individually. What could cause that little gear driven actuator to rotate the door with such force to break it? Thanks, Pat
I had that problem in my refrigerator and found out that it was coming from the freezer. The thermostat in the freezer broke and it was crazy freezing in the freezer part as well as freezing in the refrigerator. Once we replaced the thermostat everything was fine. It cost me $125
Posted on Dec 23, 2008
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
GE Model # DSS25PFMD WW, lights and fan are working not cooling
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
Our freezer keeps freezing up and it causes it to
If you tell me the model number found in locations in photo below I can help you.
Jul 13, 2009 | Refrigerators
GE GSS25LGMF BB refrigerator freezing everything. Refrigerator is set on 1, still freezing.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | GE GSS25LGM Side by Side Refrigerator
Everything in Fridge side is freezing
your thermostat is probably defective. is an electronic or mechanical thermostat? there is a website called repairclinic.com. where you can enter your model number and get tech. help along with part #'s., its a very good website
May 08, 2009 | Refrigerators
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
599 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
BOYNISMO
