My lg dehumidiifier does not seem to take much water out of the air even though it runs continuously. ijust got it back from the shop
  • 700 Answers
Thats because in the winter time the air is colder and when that happens it cannot hold as much moisture also depending on the type of heat that you have that alone dries out the air.Thats why your dehumidifier's not producing that much condensate.
Posted on Dec 23, 2008
My Aircon indoor unit will not run continually on cooling. It runs for short bursts then stops.
One thing that I am not seeing in your description is that the coil sensor has been replaced. I find it strange that a phone tech could diagnose this, send out a technician and not replace this component. Was the service tech an authorized LG repairman? That is where I would start. I would call LG and ask them for a certified technician supported by LG in your area. I feel you will have better luck with that approach.
Jan 31, 2015 | LG Heating & Cooling
Jenn-Air JFC2089HES ice maker
Try letting it thaw out and re start it.
Jun 19, 2014 | Jenn-Air Refrigerators
FE Code for model WM1812CW LG Washer
Hot water inlet valve most likely needs replacing
May 14, 2017 | LG Washing Machines
Bosch shv46c03uc
I would check the latch on the door..When you shut the door it makes contact telling the washer it's closed
Aug 17, 2013 | Dishwashers
Fussy Frige
Yes 66003764 Overload, Relay with Run Capacitor and you may need to also change the=> 67006531 Water Inlet Valve because it is not closing all the way and allowing water to continue to drip into the ice maker when it should be off. Here is a JCD2295KES Parts List and JCD2295KES User Manual I am here should you have questions, Thanks Sea Breeze
Jul 16, 2013 | Jenn-Air Refrigerators
We have an LG french door refrigerator model LRFD25850ST. It has water that leaks onto the floor from the back of the fridge. We traced it back to a faulty water line that continues to crack even though we...
I take it your water line is not copper. It may be old and getting fragile. I would replace the line with copper and check the water pressure in your home to make sure it isn't too high. (the maximum water pressure for a residence is 80psi.)
Mar 09, 2017 | LG LRSC-26922 Side by Side Refrigerator
I have the LG Tromm 27'' Front Loader model WM2277HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Getting the OE error message on LG Tromm
LG Front Load Washer
I've had trouble with my LG WM016CW front load washer leaking from the start. After many service calls, a Sears tech finally figured out that the water was running out the air vent on the back of the washer(leaks out even when no soap is added, so it's not a soap issue). The Sears tech called LG and it turns out that there should be mushroom valve(not on the original parts list) installed between the tub and air vent hose to prevent water from leaking through the air vent. That seems logical, so why wasn't the valve installed to begin with? LG is obviously aware of the problem, so why haven't they had the courtesy to inform their authorized techs? No, instead they wait for some poor tech to call them, then give out a part number that has proven to be dfficult or maybe even impossible to get(been 2 weeks and still no part). I believe LG is trying to hide the fact that the valve was left out of the original washer design and they do not want to go to the expense of correcting their mistake. Wish I could just return the washer, who wants one that leaks?
Jan 05, 2008 | Washing Machines
LG Dehumidifier Not Working
the freon has leaked out, must be replaced.
Jun 05, 2007 | LG LD65EL Dehumidifier
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
