Question about Vulcan EF3 Deep Fryer
Replace thermostats for Pitco 35c
Hoe do I replace both thermostats for the Pitco 35c? Does it make more sense to buy a new unit? Where is the cheapest place to purchase the parts?
  • smithtown Mar 29, 2009
    unit starts after it heats up it shuts off when it reaches operating temp.pilot light goes out so the unit cannot restart when temp goes down because there is no pilot light
  • 979 Answers
Replacing the t'stat can be hard. I would first evaluate the cost of the vat. Do you have any leaks now in it? I would replace the t'stats. The cost is much less than the cost of even a used one.
Posted on Mar 03, 2009
How do i replace the gas valve on pitco fyer model 35c+s
Either go to Pitco's website and look for cutsheets/parts info or call the company directly... They can walk you through it at no charge... Susan Restaurant Equipment Outlet, Cinc, OH
reocincinnati@yahoo.com
Aug 25, 2011 | Pitco Frialator 35CS Deep Fryer
Would Pitco 35C+ still heat if bulb/capillary of control thermostat breaks?
Hi there.
The unit will not fire up if the capillary of thermostat is broken or punctured because the thermostat's mechanical contact will remain open.
Regards.
Jul 08, 2011 | Pitco Frialator 35C Deep Fryer
Seems like it shuts off when its gets to a certane temp have to relight pilot
Check if the oil temp does not reach 450F because if it does, it will trip the high limit device that will shut off the burner flame as well as the pilot flame. But if high limit device trips off prematurely (at temperature less than 450F) you have to replace it. Just make sure that its sensing bulb does not touch the fire tube.
Apr 25, 2011 | Pitco Frialator 35C Deep Fryer
After we used our fryer last time, there was a soot build up on our exhaust. Just tested it again, and it seems to be running really hot. Do we need a new thermostat? How much is a thermostat?
Soot is formed when fuel combustion is incomplete. Check if the gas pressure is sufficient and of correct type (natural or propane gas). Thermostat can be checked by observing if the burner flame goes off when the oil temperature reached the thermostat setting. Price can be checked at pitco website on www.middleby.com.
Apr 14, 2011 | Pitco Frialator 35C Deep Fryer
Hello i have an electric Pitco Frialator and when I turn it on the light comes on but it doesn't click and doesn't heat up. What could be causing this?
If the mechanical thermostat is set at temperature higher than the present oil temperature and does not "click" it is a bad thermostat and needs replacement. Clicking sound on thermostat indicates closing of the mechanical contacts.
Physically examine the thermostat capillary and sensing bulb, any puncture found indicates that it needs replacement.
Oct 11, 2010 | Pitco Frialator 35C Deep Fryer
35C+ Pitco Frialator overheats oil what is likely problem
I am having the same exact problem and I am assuming either the tstat or high limit units have failed.....
Jun 04, 2009 | Pitco Frialator 35C Deep Fryer
Soot coming from flu
Remove the burners and clean the burner orfices and baffles,also check the vent cap on the pressure regulator that sits on the back of the fryer.Let me know.
May 14, 2009 | Pitco Frialator 35C Deep Fryer
Vulcan EF3 Deep Fryer Logo
148 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
