Question about Garden
Craftman wheel flange bearings
My front wheels sit tilted on my Craftsman 917.272059 lawn tractor. I am thinking it is the flange bearings that need replacing. If so, what is the best way to get the old ones out and the new ones in?
  • 49 Answers
Use a long punch and tap out the bearings from the opposite side, through the hub. Then tap the new bearings into place.
Posted on Feb 01, 2009
Front wheel alignment
Wheels are to straigten. Best to replace.
Jun 11, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I adjust front wheels one wheel goes way off center
before you change anything, lift the whole front end off the ground and check the wheel bearings and the suspension bushings for slop. you cannot align it if there is slop in the system and those cheap
plastic wheel bearings are usually the culprit. if the bearings are bad, replace both sides and you can buy new front wheels at small engine repair shops, lowes, menards, DIY. if the knuckle bearings are bad, then a sears parts location or a small engine repair shop is the place to be. and from time to time an entire knuckle is bent from where a woman hit something with it.
if there is no slop, then acquire an owners manual from sears, google it, and there will be instructions on how to align. very simple lock nut on a threaded rod type of task. not rocket science.
Jul 27, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Thanks: belt is slipping and I got it used and have used it for 8 years. Possible other problems. I need to remove the deck. Thanks again
hello qp..... the belt is slipping because it is old and stretched. Replace it and you will be good to go. Regarding the deck... you must drop it in order to replace the belt. look under the tractor to see how the deck attaches. do this on a level spot so the tractor won't roll. generally you begin by undoing the belt from the drive wheel in the front and then dropping the front by releasing the mechanism that holds it in place.
the last part is to disconnect the rear. Joe
Jun 06, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Changed the tire on my craftman lawn mower and now it will not drive
there is a key keeping the wheel and axle in sync. make sure this did not fall to the ground when you removed the wheel. fits in the slot on axle and wheel. if you lost it you can buy another at a small engine parts store. another possible problem is that you slid the wheel on backwards and it is rubbing against the mower frame.
Aug 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do you fix the front wheel alignment on a 48 inch lawn tractor by Craftman. The wheels are turned to the outside. Theres no bent rods or anything. Whenthe wheels go one way in the frony. you mow the...
make sure tie rod between wheels is straight. if bent will cause wheels to turn outward. take tie rod loose at each wheel, straighten rod reinstall wheels should be straight.
Aug 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Looking for a front axle for a craftman 19.5 briggs and stratton 42" deck green color model do not have the model # also does anyone know if the wheels come off the axle or is it one unit
The wheels usually have a rubber cover in the center, remove that and there is an e-clip that can be removed with a flat blade screw driver, or pliers. The axle beam, spindles and wheels can all be serviced separately.
Jul 01, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Front left wheel fell off of my Craftsman tractor. Model 917.274.650 I ordered new washers, bearing flange, etc. Now I discover that the flange won't fit into the hub of the wheel. The "shaft" hole...
go to sears parts .com and look up your model and the will give you a parts list and you can check if you have the right part they also have on line and phone help on any of their modfels.
Aug 15, 2017 | Craftsman 20 Hp 42" Deck Lawn Tractor
Can't get front wheel back on lawn tractor Craftsman 52-inch
Make sure you are putting the wheel on the right way. The rim may be off-set. The longer part of the hub should be on the inside.
Jan 29, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman lawn mower
Hi judycdenn
You can get replacement wheels from most decent hardware stores, either with ball race bearings, or just plain old plastic bushes. they don't cost much, I would take in my old wheel to get one that fits.
But before you go buying spares for the mower... you should read this
regards
robotek
Apr 28, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
603 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
