Question about Cisco (WS-X3011) Router
Problems with routing on a Cisco 851w
I have an Cisco 851w
Ethernet0 internal 10.10.10.1/24
Ethernet4 external 72.194.105.39/21
after a hard reset and set the default user / password
i use the default ip for ethernet0 and set ethernet4 to dhcp
when i use the sdm to ping i can ping from 10.10.10.1 to 72.194.105.39
i can also ping from 72.194.105.39 to 72.194.104.1 but can't seem to ping from 10.10.10.1 to 72.194.104.1 i have no firewall configured
i have a default route 0.0.0.0 0.0.0.0 Ethernet4
  • kbwww Dec 23, 2008
    my current route is set you 0.0.0.0 0.0.0.0 72.194.104.1
    Genius:
  • 2,785 Answers
Plz check you have a route to 72.194.104.1
Posted on Dec 23, 2008
My cisco router is not booting properly after turned on. it rather write show some language that is not known and then stop. it would not bring any of the command line or rommon or user mode up
Straighten one end of a Norwegian-invented paper-clip, and insert it into the small hole on the back of the router, and push-and-hold it.
This will reset the router to "factory" settings.
Reconfigure it, e.g., wireless network ID, et cetera.
Mar 14, 2014 | Cisco 851W Router (851WGEK9RF)
I need help with cisco asa 5505 ssl vpn.. ssl
The total sum of the Inside/Outside/ and pool address add up to 5,265. Subtract 10% and multiply by 260 to get the gender aspect of the original formula. Move the Network address to Google and download the residual code offered by the program that appears in the open window. Enter the code in the appropriate space provided and this will solve the problem by late 2015.
Oct 09, 2013 | Cisco ASA 5505 Firewall
Voice configuration on catalyst 3750V2
The short answer: No
The long answer: You will need a device that will handle call control. That can be an ISR router (gen2 example: Cisco 1900, 2900, or 3900 series) that runs Call Manager Express, or a Cisco UC5XX Box (or even full blown CUCM, though you will still need an ISR to get out to the PSTN). The switch will work great for the infrastructure side of things though. It is capable of layer 3 routing, voice VLANs, QoS, and PoE. But you WILL need something for call control.
Dec 07, 2012 | Cisco Catalyst 3750V2 24 10 / 100 PoE + 2...
Can i connect 2 isp in a single d link des-1016d?
You cannot connect two separate ISPs unless you have a router with two WAN ports
For redundancy, is BGP an option? It is very unlikely that two ISPs will permit your router to form any interior routing protocol neighborships with their routers for the purpose of link failure recovery.
A very basic (and usually undesirable) alternative is to configure a static default route to one ISP, and a floating static default route to the other ISP. The syntax for that in your case might be:
conf t
ip route 0.0.0.0 0.0.0.0 Ethernet0 1
ip route 0.0.0.0 0.0.0.0 Serial1 2
The problem here is that there is only physical link failure detection (ie: if someone yanks the cable connected to Ethernet0, it will switch over correctly, but if the ISP's equipment beyond the direct physical connection goes down, it won't switch over at all).
I'm assuming the serial and ethernet connections themselves are provisioned already though, correct? If not, as long as you're very specific about what you're trying to do (ie: as others said, encapsulation type in use, clock rate, etc.), then if you want you can email me the info and I might be able to design something for you.
Feb 27, 2011 | Computers & Internet
How can i config my DSL acount in cisco 857
with a dialer interface:
interface Dialer0
description $FW_OUTSIDE$
ip unnumbered Ethernet0
ip access-group sdm_dialer0_in in
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication chap callin
 ppp chap hostname xxxxxxxxxxxxxxx
 ppp chap password xxxxxxxxxxxxxxxxxxx
Mar 10, 2010 | Cisco 857 Router (CISCO857K9)
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
Jan 18, 2010 | Cisco ASA 5505 Firewall
1. Change your PCs default gateway to your firewalls' internal IP
2. configure the nameservers on your ASA
Then internet will work fine.
May 23, 2009 | Cisco ASA 5510 Anti-X Edition...
When Firewall powered on the Act/Net not enabling
jus login via console to the firewall and give the this command
Mentioned below is example give the interface number according to your firewall ports
conf t
interface ethernet0/0 100full if its a pix firewall
Mar 21, 2009 | Cisco PIX Firewall 506
Pix 515 E allow few websites only.
Do the nslookup for the three websites and write an access list to permit the traffic only to the said website ip addresses
Eg.
1. go to dos prompt
2. type "nslookup"
3. type "www.rediff.com
Note : You will get the ip address of the websites
4. Create an object group for these websites
5. Add ip addresses of the websites
6. create an access-control list element to permit the traffic from your circle office to this object group for port tcp 80 and 443
You are done
Mar 09, 2009 | Cisco PIX 515E Firewall
Cisco asa5505 problem
You seem to have the last resort (o.o.o.o) set to VLAN1 which is set as an inside interface.
Is VLAN1 connected to the outside router or internet backbone?
If not, change the last resort to the outside Ethernet port.
Apr 16, 2008 | Cisco ASA 5500 Firewall
Computers & Internet Logo
129 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
