Question about Kenmore 62802 Electric Dryer
Kenmore gas dryer will not start model 110 72972109
I have a kenmore gas dryer which is about 6 yrs old and it will not start when I push the start button. I have tried it at all setting on the dial with the wrikle gaurd in both the on and off position. If you hold the start button down the drum will turn while you hold it in the down position. I have check the vent line and it is clear. What is the problem with this dryer
  • larsus Dec 25, 2008
    I have a kenmore 110.62822102 electric dryer that will not come on. I have checked power to the outlet and have tested the cord. Beyond that, I don't know where to check.
  • 179 Answers
Check your motor relay under your control panel
Posted on Dec 23, 2008
Kenmore heavy duty front loading dryer MDL 86821100 20 yrs old (?) won't start. Although I hear the timer humming when I set it, when I push the start button, no start.
here is a video that will walk you through this repair. It explains how to test all components of the dryer.
http://www.youtube.com/watch?v=i95okOr2rOI
You can also find further repair help at the link below, we would be glad to assist you.
http://www.appliancerepairlesson.com/
Mar 02, 2011 | Kenmore Dryers
My mother has a Kenmore 500 Gas Dryer at least 15 yr. old. Model 110 660 501. It stopped working and shows no indication there is power. Is there a main fuse or reset switch I can look for? We don't...
it would pay to replace dryer if it is 15 yrs old a newer dryer would be more efficent. Check wires from wall and run them to control panel. Ther should be a relay between power cord and switch
Mar 05, 2010 | Kenmore 72062 Gas Dryer
My gas dryer (3 yrs old today) wont turn. It just
O turned the drum by hand and it started running
Nov 04, 2009 | Frigidaire Dryers
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Jun 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
MY 10 YRS OLD KENMORE GAS DRYER HEST AT FRIST, THEN JUST RUNS AN
The timer has probably failed, a common problem. Easy to replace.
Jan 20, 2009 | Kenmore 73952 Gas Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer
The start button works like a push-on switch that engages the timer switch. It's all one unit. It isn't engaging because the internal lever the engages the switch is either broken or worn out. The start timer/switch will need to be replaced.
Jul 09, 2007 | Fisher and Paykel DG05 Gas Dryer
Kenmore 62802 Electric Dryer Logo
122 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
