Hello no i have all the cables hooked up correct and i tried a vcr and that wont give me a picture. but the sound works and i can see the bulbs are working when i use the test and i can set up the cross hairs.
  • 3 Answers
When it was working, was it on all the time or when went somewhere did you leave it while you were gone, because it may have overheated.
Posted on Dec 26, 2008
RCA Vr552 Picture but no sound?
The sound output of the VCR may not be connected to the correct inputs of the TV
Oct 10, 2016 | RCA VR552 VHS VCR
I have sound but no picture. The screen is black
can you see any any menus or the volume bar or channel indicator?
Make sure all your audio and video cables are hooked up correctly to inputs on the TV and to the same set of hookups. For example all of the VCR cables hooked into video 1 and all of the DVD cables in video 2.
Also check that you haven't hooked up the video to the tv's output. Some sets output audio and/or video for external devices such as recording setups or home theater sound systems.
Oct 17, 2009 | Zenith TVBR2742Z 27 in. TV/VCR Combo
We have a new vcr snowy
It seems that you need to take the new unit back for exchange, since you are using the same output for the vcr and the dvd and your dvd is giving you a good picture, the vcr is acting up and since it's new either exchange or repair will be needed.
Sep 01, 2009 | Philips Magnavox TS3260C 32" TV
I can see the picture but can not hear sound. All
try changing the down mix in the sound settings on your dvd/vcr combo
Jun 07, 2009 | Zenith XBV442 DVD Player/VCR
Adding vcr & rec to a '93
Please hook up VCR with TV through RF cable and check picture of VCR playback in TV.
Now you can hook DVD player video-audio out in VCR input and can have dvd playback picture in TV via VCR modulator.
If you want to listen sound via receiver then hook audio red-white cable between VCR audio out and receiver audio in terminals.
Let me know exact model numbers of units to help you out more.
Thank you.
Jan 13, 2009 | Televison & Video
Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Jun 17, 2008 | Gateway AR-230 DVD Recorder
Toshiba VCR/DVD Recorder Combo - Problems connecting it to system
I was able to connect to my cable box. I used RCA (yellow, red, white) cabling. I connected the Video Out on the cable box to the Video In on the DVD/VC (to the DVD VCR cabling section). I then from same section used the Video Out using RCA Cabling to the the Video In connectors on my Phillips LCD TV. That left only to connect the TV to the cable box using regular TV coax cable. Everything works, although I am going nuts trying to dub from VCR to DVD-R or +R discs.
May 21, 2008 | Televison & Video
Cant get vcr to work
is your vcr capable of hd output? if not the picture will be a bit distorted(stretched)
Apr 21, 2008 | iLO 3200 32 in. LCD Television
Problems hooking up a VCRplayer
Hello..try to turn on the test signal generator switch it is marked test at rear of vcr...and chose av¨rf channel on your tv i.e the 0 or 9 channel than search for the vcr and memorize on tv...alt you can playback a tape ..pre-recorded without the test signal and make the search...alt 2...use a direct av-cable between vcr and tv..which is best and put tv in av mode...good luck...Ron
Mar 11, 2008 | Televison & Video
Trying to hook up a playstation one
Make sure you have the cables connected correctly from the playstation to the VCR.
Yellow colour is Video output from playsation to Video input on VCR.
To get the audio from the playstation to the VCR just match the colours of the RCA connections.
Do not forget to select video input on the VCR as well.
Good Luck.
Mar 02, 2008 | Panasonic PV-V4540 VHS VCR
Televison & Video Logo
Top Televison & Video Experts
