Question about JVC AV-36950 TV
1998 JVC AV-32950 TV
The F connector input on my TV is shorted between center conductor and shield.
Is this normal?
The F connector is attached to a tiny shielded circuit box with 2 RCA connectors on the back of it.
The RCAs go to 2 tuners.
The little box looks sort of like a splitter only with a circuit board inside.
It is not currently connected to the tuners.
2 Suggested Answers
  • 24 Answers
SOURCE: Connection to Dish service
Your t.v is having only RFin , and if you connecting dish receiver , normaly their are two o/p for receiver one is RF and two is for audio out and video out. if your connecting direct RFout to t.v RF in then you have to tune the t.v in all bands. if your receiver do not having RFout facility, then you have to connect AV out to converter and then RFin of t.v. if you having a vcr, then connect AVout of dish receiver to vcr AVin and then vcr RFout to t.v again tune the t.v and pwer on the vcr.
Posted on Jun 25, 2008
My connection for the cable on the back of my tv is broken!
If you have RCA inputs for video and sound their will be a white and red which is audio and yellow is video. If you have a cable box that you use to change channels, this should have the RCA outputs for your audio and video. You will also have to set your tv to select that input to get the cable. Hope this helps
Apr 17, 2013 | Sony KP-53V85 53" Rear Projection...
Some reception produces a crackle noise and stronger ones not. This is not a squelch issue. It is a different noise, like a short in the antenna or something.
Check the antenna PL259 connector. It sounds like the ground (shield of the coax) is not attached properly. I would recommend replacing it with a solder type connector and solder the shield to the outer ring of the connector and the center conductor to the tip of the connector. If the problem still exists, I would recommend trying a different antenna.
May 30, 2010 | Icom M302 VHF Radio
I have a JVC AV-32950 and have lines running across the top 3 - 4 inches of the picture. The picture also goes black on occassion and I have to hit the top of the TV to get the picture to come back. While...
It may be a dry solder point somewhere near the vertical IC. First take look at the solder points and if you found cracks pls resolder it. if the lines continous you have to replace Caps near the vertical or circuit.thank you
Nov 23, 2009 | JVC AV-32950 TV
Connecting an analog TV (about 8 years old) to the cable, the picture and sound quality is very bad. However, connection via a VCR results in good reception but the VCR has to be left on and thus I have to...
Gary_akai, First thing to do is try to find out what 75 ohm "patch" cable or "F" connector is causing a "LOSS" of signal. Could be a "DEFORMED" center conntact in tv rf input. OR an open shield with one of your patch cables. OR a too short center conductor that should be sticking out at least an 1/8" past the end of the 75 ohm cable "F" connector. I'm louie12fix on fixya Bye for now..
Sep 22, 2009 | Hitachi Televison & Video
Need the a replacement coaxial connector on the rear, PN 807A. Where can I order this part?
Its better If you have found a dead tv somewhere may be from your neighbour so you can replace with that.
Sep 17, 2009 | JVC AV-32950 TV
The connector at the back of the tv where the cable would be connected broke off during a move. My step dad took the remaining piece out. How can we fix this? Is it a simple thing we can do ourselves?
The coax connector you describe is fairly low-tech, so it can be fixed. You need to open the back of the TV (careful - high voltage in the capacitors) and locate where it came from.
The best thing would be to take some coax cable and solder the appropriate parts (shield and center conductor) to their exposed matches where the break occurred.
You can then run that through the existing hole, put a screw-on F-terminal end on the piece of coax, and a coax coupler on that.
Home Depot, Lowes, Radio Shack, etc. all have these raw parts.
Jun 30, 2009 | JVC AV-27220 TV
JVC AV-32950. No sound after being in storage for 1 year
it may be dry points near audio circuitry
Mar 25, 2009 | JVC AV-32950 TV
TV shuts off after 10 minutes.
I think it's in sleep mode. On your remote, click the button that says 'sleep' until it says '0 minutes'
Dec 26, 2008 | JVC AV-32950 TV
Model AV-32950 will not turn on. The power light is flashing and the relay RY921 is oscillating. I have replaced C926 1000uf/35v & no change. Any suggestions. Circuit daigrams????
did you check his horizontal transistor?what is the voltage of the b+ in flyback. but common causes of that model is the defective horizontal transistor.
Oct 18, 2007 | JVC AV-32950 TV
JVC AV-36950 TV Logo
62 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
