HP 6180 with a persistent empty yellow cartridge
The system claims the yellow cartridge is empty and won't print color. The cartridge is full. I have replaced it several times to no avail... I tried various hardware reset techniques I found on the web (ususally for other HP model printers) but cannot get this error to clear. I suspect a clogged tube or malfunctioning ink level sensor but don't know how to troubleshoot or resolve.
  • 3 more comments
  • bbhop Jan 09, 2009
    Printer shows yellow ink cart is empty when I have tried 3 brand new carts, all show empty. Cleaned contacts, repowered machine same thing.
  • tommy1554 Jan 20, 2009
    Same problem. I have also tried three new ink cartridges. When I shake the cartridges, I can clearly hear lots of ink in there, but it won't print and thinks the yellow one is empty. Only the yellow one.
  • uniserve Feb 01, 2009
    Persisten Yellow cartridge empty error. Three new crtrisges tried all had full ink in them.
  • bobmontore Mar 07, 2009
    Ditto - tried three different (new) yellow cartridges but continue to get the empty cartridge message.
  • le915 Mar 16, 2009
    I have the same problem, HP C6180  with a persistent empty yellow cartridge
Problem fix step by step:
1) Remove all ink cartridges, not just the affected cartridge. Close the doors and the access door.
2) Unplug printer without powering it down.
3) Plug in printer while holding down the # key and the number 6 key simultaneously. DO NOT RELEASE THEM! The printer will start up and then after a few seconds shut down.
4) Press the "On" button
5) Reinsert all ink cartridges.
6) Send me thank you notes. I spent hours on chat with HP support until we got the correct fix!
Posted on May 27, 2009
2 Suggested Answers
  • 6 Answers
SOURCE: HP 6180 with a persistant empty yellow cartridge error
Remove the cartridges and cover the small windows on them with a small piece of duct tape to fit it(only on the window). Reinstall them and it will be fixed!
Posted on Mar 31, 2009
I have been printing photos and they have come out beautiful. Suddenly the colors are all muted, and brown hair has a green tint. My printer is an HP 6180. Nothing has changed - same paper, ink...
It sounds like one of the colors is not printing correctly. I would suggest , opening your hp solutions center programs and under tools you will find an option to clean the print heads. Follow the procedure to cleans the print heads, after cleaning open control panel on the computer and depending on the operating system click on "printers" (XP) or "devices and printers"(vista win7) right click on your printer( hit your right mouse button) select " printer properties" click on print test page. This page will print out showing each of the colors separately. You should see black, blue, pink and yellow. If one of these colors is missing or muted you will now which color is cratinging the issue. And at that time I would try changing the corresponding ink cartridge. Hopefully the print head cleaning will resolve your issue
Feb 11, 2013 | HP Photosmart C6180 All-In-One InkJet...
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
I have an hp 2600n and a ibook 4g. yellow cartridge is empty and orange light is blinking. have printer settings to black & white, but won't print. help!
Regardless of whether you have printer set to print in black and white, these models will not function without usuable cartridges in all slots.
May 14, 2011 | HP Color LaserJet 2600n Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Brand new yellow ink cartridges are always read as empty
We have a step by step solution posted on our we site at: www.ccl-la.com/HP.htm The problem is air in the ink lines and the guide helps you purge the air from the system and restore printing.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp deskjet 648c will not print
lexmark z515 program to download in my computer
Jan 26, 2009 | HP DeskJet 648c InkJet Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
try wiping down the metal parts of the ink cartridge with rubbing alcohol. as well as the inside of printer where it connects in.remember to unplug while doing this.then give it another try.
Dec 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
515 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
