Question about Acer Notebook
Acer 1690 When the system is powered on it will display the Acer logo for a minute or two then the screen will go black...no messages. Acer support suggested that the hard disk was bad and to replace it
  • 128 Answers
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
OR
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
recover.
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Posted on Feb 02, 2008
    President:
  • 2,961 Answers
They may be correct, although you can try pressing F8 on boot up and and enter safe mode. When in the menu choose 'Last Known Good configuration' and press enter, allow a reboot and hopefully you get into windows. It may also be the boot.ini which is damaged at tells the harddrive where windows is, but you will need your Windows disc to repair the system.
Posted on Apr 10, 2007
My garmin 1690 will not boot up past the logo garmin express says its not connected when it is how can I resolve this?
Garmin nuLink 1690 LIVE Factory Reset GPS Nation Admin posted this on Aug 5, 2015
Note: A master reset will erase all favorites1 and will restore your device to the default factory settings. If you would like to back up your favorites to your computer, you can find instructions to do so here.
To perform a master reset on a nuvi 200, 205, 405, 500, 600, 700, 705, 1100, 1200, 1300, 1400 series, 1690, 1695, 2300 LIVE series, zumo 220, 450, 550, 660, and 665:
  1. Start with the device OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the device ON
  4. Release the power button when the device powers ON
  5. You will see a new message: "Do you really want to erase all user data?"
  6. Remove your finger from the touch screen when this message displays
  7. Touch Yes
    • If text language is not in English, this is the button on the right
The device will now reset. Follow the on-screen prompts and then place your device in an area with a clear view of the sky until it acquires satellites.
1Although the master reset will erase all saved favorites, any loaded custom points of interest will remain intact on the device.
Jun 03, 2016 | Garmin Nuvi 1690 Car GPS
Acer aspire 1690 laptop can't complete the booting process and restarts automatically. During the booting process, it shows XP windows but can not boot to the desktop and shows a blue screen but the...
blue screen in XP is usually due to hardware issues. Did you add or change hardware? By now, probably your only solution is to repair windows XP by putting in the XP setup disk and get to repair. If you do the install, it will format your hard drive and you will lose your programs and files.
Oct 29, 2017 | Acer AOA150-1690 Aspire Notebook
My 1690 don't start black screen.
There could be a couple of reason why laptop didn't start-up. Basic: the battery is dead and need to be recharged. Possibly the battery isn't keeping charge and the AC power charge is un-plug from the wall. Leaving the laptop without power. Make sure everything is plugged in and try to power it up. It that doesn't work then it could be the power supply in the laptop it self. Good Luck!!!
Mar 15, 2011 | Acer Aspire 1690 Notebook
ACER ASPIRE HAS NO DISPLAY
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 07, 2010 | Acer Aspire 1690 Notebook
I hit F1 key and screen is black...been in phone with Dell for over 45 minutes...help I am on another pc
when you hit F1 key it was on the Dell screen logo right? so after hitting the key F1 it just go straight black screen with a cursor?
since you where able to get display try. 1. turn off laptop make sure ac adapter is plug in. 2. while laptop is off press and hold on the Fn key then press power while pressing on Fn. 3. Check if a self-assessment will display and run on the screen. Just follow the prompt messages on the screen to guide you for the error messages which will help you to identify the problem.
Mar 27, 2010 | Dell Inspiron 1545 Notebook
Aspire 1690 - Backlight on screen is failing Rose
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Acer AOA150-1690 Aspire Notebook
Acer aspire one black screen and no boot
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
Jul 07, 2009 | Acer AOA150-1690 Aspire Notebook
Black Screen on ACER 5570Z
there is a os problem try to run system in safe mode or format it
Jun 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
Booting problem
Similar problem
started a few days back
Aug 11, 2008 | Acer Aspire 1690 Notebook
Computers & Internet Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
