Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
Thermostat turns unit one every 5 min
My unit shuts down every 5 min it turns right back on, My bill went from 115 to 435 in three weeks. Is there someting wrong with the unit?
  • marq313 Jan 07, 2009
    i ma having the same issue my heat is coming on and off every 5 minutes i dont know what to do about it and I am trying to avoid the 400 gas bill
  • 82 Answers
Check your filter if it is dirty it will not allow enough air flow and cause the heat limit stat in the unit to trip causing unit to cut off when it resets it will come back on.
Posted on Jan 13, 2009
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
Cooling begins then indoor blower stops...outside unit continues to run
I had the same problem,if you do not monitor that you will make matters worst and burn the Compressor.your problem is the blower unit it has three speed sometimes four.it needs to be changed..
Hi, My unit is gas, and is just a couple of years old, it will not kick on unless I turn it off then turn it back on, I have TWO green lights that STAY on, then a yellow light blinks, and blinks again 4-5...
check flame sencor is clean , check connection from sencor to the board , or pressure switch could not be working try jumping this out andf seeif it fires up check filters are clean
Jan 20, 2011 | Heating & Cooling
Furnace is 7 years old. Will not stay running for more than 5 min. Will start up again after shutting off and then run for another 5 min. Suggestions?
Check the air filter. Jump out thermostat to see if it stays running longer, if so replace thermostat. Make sure all return air ducts are clear of debris. If furnace has a Fan/Limit switch, make sure tabs are set at 100, 140 and 200. Sounds like something may be heating up and shutting unit off till it cools back down.
Jan 03, 2011 | Ruud Heating & Cooling
The electricity went off this morning and now the air conditioner is blowing warm air and I don't hear the compressor coming on its a whirlpool window unit Thank You
turn the unit off for 5-10 mins. turn thermostat to coldest setting then turn unit back on. see if the compressor kicks on in a minute . it may need to reset itself.
Jul 30, 2009 | Whirlpool Heating & Cooling
Power goes off
Try resetting the unit.
Make sure there is no disc in the unit. With the unit on, go to the front panel and look for the STOP (square) button.
Hold it down until the unit shuts off by itself. Turn it back on it shoudl work fine.
Jul 01, 2009 | Samsung HT-X40 System
Ac set at 74 room temp up to 78 and no Ac kicking on.
it could be the thermostat is loose on the subbase or if you went from OFF to COOL and the stat is a digital stat It will not come on for five min. This is a delay set by the manufacture to protect the compressor. during normal operation you will not notice because thier will be more than 5 min from the time it shuts of till it need to come back on but if the system switch is set to off and you switch to cool or unit just shut off it will always delay 5min. usualy there will be some insdiction on the screen that it is in delay like a flashing COOL or SNOW FLAKE or the word WAIT. the unit will not be running until the flashing words go solid
Jun 26, 2009 | Honeywell Programmable Thermostat Heater
Automatically shutting off after about 5 min
dose it have a thermostat if it dose that will turn it off
Jun 24, 2009 | Comfort-Aire PAD-91 Air Conditioner
Shutting down on 60mg system
try holding the power button on the right
side of the console as you turn the back power switch on.Keep on holding the power button and see if there is a double beep.If this doesn't work,and if you want to try this? Open the HDD cover on the left side of the unit(front facing you).after removing the cover,remove the HDD unit and reconnect.It might be a loose HDD connection.This should only take you 2 mins to do and it won't void your warranty
Feb 15, 2008 | Sony Playstation 3 (PS3) Console
Heating & Cooling Logo
130 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
