Question about JBL BP600.1 Car Audio Amplifier
My amp goes out and turns red when i get to a certain volume
I have a jbl 600.1 amp and every time i get to a certain volume on my radio the speakers go out. i was told that i needed a capacitor or battery but im not sure how much power i need for the amp.
Could you tell me what farad is needed?
General
Output 4 Ohms
300W x 1 Output 2 Ohms
600W x 1 Signal-to-Noise Ratio
>100 Frequency Response (±3dB)
20Hz - 500Hz Total Harmonic Distortion
0.1% Input Sensitivity
250mV - 4V
Get a 1.5 farad they have them at walmart for like 40 bucks
Posted on Dec 23, 2008
I have a JBL Venue sub12.It pops and crackles at certain levels.Ive had it for 5-6 years, dont use it much. Ive turned the volume down on the speaker to the lowest setting and it still makes the noise
It is hard to diagnose without seeing it, but most likely you need a new amp. We have them in stock. http://reconingspeakers.com/product/jbl-sub-12-amplifier-assembly/
Nov 21, 2016 | JBL Audio Players & Recorders
My JBL DCR 600 head unit keeps cutting out after I turn the power on
try checking your speakers and/or speaker wires for grounds or shorts. If they check out fine, you have an internal problem with the amp, more than likely blown transistor(s).
May 05, 2015 | JBL Car Audio & Video
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
Jbl radio A56840 loses station presets and no volume
Toyota vehicles have a fuse in the kick for the amp and sometimes there is located under the hood ... This is the switch turn on for the amp ... And 1 of the fuses is most likely the memory or constant power. B sure to check all fuses ... I do not have AllData pulled up . If the fuses are all good the amp or radio may be bad ... Or both ... Be sure to check all the fuses ... Many times I get clients that say allthe fuses are good and it is still the first thing I check ..Usually is a fuse ..Good Luck
Jan 27, 2014 | JBL Car Audio & Video
My JBL PRX 635 Speakers at all event shuts off during high volume ( No Red Light ) Very Embarrassing during the dance is packed. Volume is always set at one single yellow peak from the mixer and just...
Sounds like you're over driving them. First check to make sure they're on "line level" not mic. Shutting off is amp(s) in speakers going into "thermal shutdown" IE: overheating. According to your description level settings look good - check to make sure speakers are on LINE LEVEL
Apr 12, 2011 | JBL PRX635 Speaker PA Active
When i put on power protect light come on
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible causes, do the following. Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still shuts down (goes into protect mode), the amp almost certainly has shorted output transistors and will need to be repaired. If the amp only shuts down when it's driven to relatively high volume, you need to confirm that you have sufficient power supply voltage. With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts on either the B+ or remote line, you need to check the wiring feeding whichever line is too low. If 'both' the B+ and remote turn-on lines are low and your battery is fully charged, you may have a bad ground connection.
Dec 15, 2010 | JBL BP1200.1 Car Audio Amplifier
JBL JRX115 producing very muffled sound even though graphics on mixer at normally used settings. Someone suggested we may have "popped" the horns. Is this potentially the problem. We have been running...
The speakers are rated 250 Watts. Driving with 600 Watt amps requires one to be careful of how much the volume is turned up to avoid damage. You MAY have damaged more than just the compression drivers on the horns but the voice coils on the 15 inch speakers as well. Further use could also damage the amplifiers. You did not mention what brand amps and it is possible they have a problem.
You best replace the units with ones rated for the power of the amps as restoring them on short notice for a gig is not practical.
Sep 12, 2010 | JBL Music
Low volume with volume cranked up
Are the speakers battery-powered (with dead batteries?) or AC-powered (but not plugged-in) ?
Do the speakers work correctly when connected to some other desktop or laptop or iPod ?
Oct 09, 2009 | HP Compaq JBL Pro (401508-001) Computer...
My 605 turns off and red light blinks when volume goes past 58
Shorted speakers can cause the unit going on protection mode (the red light blinking) when a certain volume is reached.
Test with a set of replacement speakers.
If it is not the speakers, it is probably transistors in the amp final or something nearby. Test also input output board.
Apr 27, 2009 | Onkyo TX-SR605 Receiver
Shuts of when radio volume is above 24
check to make sure the ohms rating on the speakers is correct. should be equal to or higher on speakers compared to receiver.
Mar 11, 2009 | Kenwood KDC-MP235 CD Player
JBL BP600.1 Car Audio Amplifier Logo
163 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Morne Olivier
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
