Question about Philips 27MDTR20 27 in. TV/VCR/DVD Combo
Magnavox 27mdtr20 17
Is this a high def TV or will I need a converter?
Ive bought 2 remotes just the like the one that came with the tv and none work with it..including the one that came with..nor can i find any working code for universal remote...HELP
Posted on Oct 17, 2012
  • 16 Answers
The Magnavox 27mdtr20/17 is a standard def. television produced in 2003 by the Philips-Magnavox Corporation. This particular model was conceptualized long before DTV was an option, and much further before Digital Television Broadcasts were considered a viable option for our current current communications problems.
You will need a DTV box IF:
A) You use an antenna (roof top or otherwise) to watch television
You will not need a DTV converter box IF:
A) You subscribe to cable services, either analog or digital
B) You subscribe to satalite services
For more information on the reasons behind the DTV transition, as well as getting valuable cupons from the federal government to help subsidize the cost of a DTV box, please visit this site:
https://www.dtv2009.gov/
I hope this helped,
Remy
Posted on Jan 04, 2009
Can't get HD on my TV. Tried with every cable type but cannot get High Def
2 things have to happen. first, your tv has to be set for the correct resolution, second, You need to be recieving high def from your cable/sat provider.Your tv does not make programming high def, it allows high def.
Mar 10, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Tv turns on and has sound but no picture. Only black screen, the menu from the cable or dvd cannot be seen.
Make sure your using a cable box that is compatible with a high def tv, if your tuning a high def channel and your converter does not support high def, it will only play the sound, no vidio at all.
Sep 25, 2009 | JVC LT42P789 42 in. LCD TV
No picture - only sound
Ok, on a hi-def tv, you must have a converter box capable of receiving Hi-def. If you are using a converter box from a satalite or cable tv service, try getting a Hi-def box. Also try hooking a vcr or dvd player to the tv in the non high def ports to varify that this is the problem. If you have any question please let me know, I hope this helps, good luck.
Sep 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Can't receive high def channels.
What kind and model of TV?
More than likely it is not designed to receive the hi def signals and will require a converter box.
Sep 03, 2009 | Televison & Video
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
HF10 camcorder cannot read some .mts files
My knowledge in video editing is limited, but here's what I could dig up.
m2ts is also referred to as AVCHD, (MPEG4) a high-def Interlaced format which most computers cant render properly since most computers render in progressive format. You have to convert it to MPEG2, AVI, WMV, MOV or other movie file types in Progressive mode, a process known as "Deinterlacing" in order to edit it. Depending on how big the file is and how fast your computer is this could take several hours. Also, you cant view AVCHD files on normal televisions, you need a high-def TV.
If you want to edit high-def videos with post-effects and music etc, for dvd or blue-ray, you'll need a more powerful computer. The "recommended" minimum is a 64bit dual core processor, windows vista 64 bit, a seperate 500Gb or bigger hard drive and at minimum, 3-4Gbs of RAM with a high-def TV monitor. (1080i) Rendering High-Def videos is process heavy and can take up to 12+ hours to render a single 30-60 minute video with post-fx like music, logo's etc. The reason you need a 64bit processor and 64bit windows is because regular XP and Vista wont recognize more than 3Gb of RAM.
You could get by with a 32bit dual core processor and 2 gigs of RAM on windows XP, it's just going to be slower. You will still probably need a high def monitor if your going to edit in high-def mode.
High-def is new technology to mainstream consumers. Supporting technology hasnt caught up yet including most software--however most of what I read stated that Sony Vegas Platinum can do this pretty well.
Your camera is capeable of recording in progressive mode. You'll have to read the manual on how to do this. This will record it in standard mode which is not high-def. (For future reference)
To sum it all up, the camera's technology is more advanced than most PCs. I downloaded AVS Video Converter and converted the AVCHD, (MPEG4) a high-def Interlaced format to HD Video 720p: WMV9, 7000 kbps....... on the drop down screen of the AVS program. I now can view my videos in Progressive Standard mode with NO choppy play back or problems. Please note that 720p is a non digital standard Television view.
Remember M2ts files need to be converted to Progressive non HD files so your computer can read them. That will stop the choppy skips.
Hope this helps.
Jun 04, 2009 | Canon VIXIA HF10 HDV Camcorder
Is Model Philips/Magnavox VRA631AT22 HDTV Ready
I am not absolutely positive, but I do not think you will be able to get ANY TV after the transition without a converter box, unless you hook up to cable or a dish. IF your Tv were able to get HD, it would say so on the set...
I live w/ a son & DIL and we have Direct TV so we can already get HD programs, but since none of our sets are High DEF we do not get them IN high Def.... I also have two small TVs,- one in the spare bedroom and one in my computer/ library... both of those are hooked up with old fashioned antannae..[ I also have a VCR hooked up to each]. I have added a converter box to each and can already get more stations than I did before and the picture is better,
although it is NOT in High Definition; You have to have a High Definition TV to get programs in that foremat, although you can get a GOOD program; so it was worth the small amount I paid for the boxes... I got the Government discount coupons so they were reasonable...
Last week one of the local 'Best Buy' stores advertised the converter boxes for as low as $9.99 w/ the coupon... I think the Gov'mt has run out of funds, however.
I hope this answers your question...
Jan 25, 2009 | Televison & Video
Is our Sansui tv TVM1916 digital or do we need converter box?
You will need a converter box if you have an antenna.
Jan 24, 2009 | Sansui TVM1916 19" TV
How can I tell if my TV has high definition??
If it is high def it will probably have "HDTV" printed on it somewhere. It will have some type of HDMI or DVI inputs. If it's not high def there is nothing that can convert it.
Jul 25, 2008 | Toshiba 32D46 32" TV
Toshiba 43H70 - making it HD
you cant make it high Def. The converter only allows and analog tv to recieve digital signals, But it wont make it a HDTV
Apr 03, 2008 | Toshiba 43H70 43" Rear Projection...
Philips 27MDTR20 27 in. TV/VCR/DVD Combo Logo
622 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
