Question about Air Tools & Compressors
Air Conditioning pump Kput
I Have a blazer and the air conditioning pump has had it. I am in New Zealand and my mechanic is unable to get an other one. He informs me that the part is no longer availiable, I wonder if anyone can help me.
Delphi Part # 1136618 Code 093081350
  • michael sinclair
    michael sinclair May 11, 2010
    what is the year and engine size for your blazer??
  • 70 Answers
You should try junkyarddog.com
Posted on Jan 09, 2009
How can I fix my 2003 Mitsubishi Eclipse GS Air Conditioning?
Repair your vehicle right away. Just click on the link I attached 2003 Mitsubishi Eclipse
Dec 01, 2017 | 2003 Mitsubishi Eclipse GS
Pro Standard Fan mount
Since the failure of an air conditioner to turn on, loss of air conditioner cooling capacity, reduced air conditioning output temperatures, loss of cool air supply, or even loss of air flow entirely can be due to a variety of problems with one or more components of an air conditioner or air conditioning system, after reviewing the lost air conditioner cooling diagnosis procedures described in this article, be sure to also review the diagnostic procedures at each of the individual air conditioning diagnosis and repair major topics listed just below. To return to our air conditioning and refrigeration home page go to AIR CONDITIONING & HEAT PUMP SYSTEMS.
Electrical problems on HVAC systems: Keep in mind that despite the depth of technical detail you will find here about all components of air conditioners and heat pumps, most service calls for non-working air conditioners or heat pumps turn up an electrical problem. So if your A/C system is just not working at all be sure to check all of our electrical and control setting suggestions first.
Mechanical problems on HVAC systems: tend to fall into these groups: refrigerant leaks, dirty condenser coil or unit, dirty evaporator or cooling coil, or burned out (or hard-starting) compressor motors. We have also seen a number of problems with fans and fan motors in both the compressor/condenser unit and in the air handler/blower fan unit. Some of those fan problems are mechanical - like a loose fan belt or blade. MORE DETAILS
Nov 13, 2012 | Heating & Cooling
1997 chevrolet blazer air conditioning trouble shooting
A mechanic would check to see if the system is full of freon, then check for voltage at the relay, the low pressure switch, and the ac clutch.
Aug 17, 2012 | 1997 Chevrolet Blazer
Air conditioning not too cold ??
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Let me explain in layman's terms how the air conditioning (AC) system works and what could be happening to your car.
Like your body, the air conditioning compressor is the heart of the AC system, and Freon is the blood. The compressor pumps Freon throughout the AC system, either the older type R12 which costs as much as gold it seems these days, or the new environmentally-friendly R134A Freon. This Freon is a gas and liquid combination that is compressed and circulated throughout the air conditioning system. The compressed Freon is pushed through the system under pressure and is passed through different sized metal and rubber hoses and a special valve called an expansion valve that cause the gas to expand and contract.
This expansion and contraction makes the Freon gas very cold. This cold gas makes its way via metal lines into the dash area of your vehicle to the evaporator core. This evaporator core is like a small radiator, except it has cold Freon circulating inside and not hot antifreeze. A small fan (the AC blower fan which you control from the control panel on the dash) sits in front of the evaporator core and blows air across this cold evaporator and then through the vents inside your vehicle.
The other objective of the air conditioning system is to remove the heat from inside the cab of the vehicle. This heat is removed by the Freon with the help of the AC condenser located at the front of the car (usually in front of the radiator). The Freon coming back from the evaporator carries the heat from the cab to the condenser via rubber and metal hoses. Just like your radiator, the condenser is lightweight aluminum with many internal winding coils.
The Freon travels through these coils, and in between these coils are small slits or fins that the Freon is forced through. The condenser will have an electric cooling fan mounted in front or behind it to push or pull air through these fins to remove the heat from the Freon. Some vehicles still use the old fashioned fan blade driven by the engine to pull air across the radiator and the condenser.
Now I know that is just a tidbit of information on how the air conditioning system works, and it is very general, but I wanted you to know what to look for to give you insight as to what might be happening with your vehicle.
A few causes of low cooling efficiency or no cooling at all at idle are:
Lack of air flow across the condenser. Make sure the electric cooling fan motor near the condenser is coming on, or in models that are equipped with a fan blade make sure this fan is turning and is turning very fast.
Low Freon levels. Freon level and pressure should be checked by your certified air conditioning mechanic.
Overheating. If the engine is running hot or overheating, it can have a noticeable negative affect on the air conditioning system. Some cars have two electric cooling fans, one for the air conditioning condenser and the other for the radiator. Make sure they are both working properly. Usually at idle on a hot day with the AC on both fans will be on.
When the vehicle is traveling at freeway speeds, the compressor is pumping the Freon throughout the system much faster and harder than at idle. There is a dramatic increase in air flow across the condenser due to 55 mph winds, and the engine is usually operating at a cooler, more efficient temperature as well, thus allowing the air conditioning system to operate efficiently.
Note: An air conditioning system that is somewhat low on Freon can still feel comfortable at freeway speeds due to the added air flow across the condenser which can overcome the ill effects of slightly low Freon. Periodic air conditioning performance checks by your mechanic are the best way to keep the system in great shape.
Hope this helps.
Goodluck
Oct 08, 2010 | 1998 Cadillac DeVille
Problem for Chevrolet 1998 blazer the air
If the compressor is cycling on and off and the system isn't getting very cold it's low on freon. You'll need to have it leak tested, repaired, and recharged.
Jun 29, 2010 | 1998 GMC Blazer
Air conditioning blocked unable to locate tubes
You will have to find the location of the condenser, their is drain , to drain the accumulated moisture, which is created when you have the AC at full cold! This drains the moisture outside of the car !
Aug 11, 2009 | 2007 Maserati Cambiocorsa Coupe
Air conditioning - a/c fans don't come on, compressor makes squeals, air is not cold.
The Air-conditioning needs to be re-gassed. Take the car to an Auto Mechanic to get the Air-Conditioning re-gassed. They might also need to check it for leaks to make sure the gas stays in.
Jun 27, 2009 | 1996 Dodge Caravan
Air Conditioning- is either COLD or HOT, nothing in the middle
make sure yourhot to cold knob is not striped or a vacum hose come off.
Aug 08, 2008 | 1998 Chevrolet Blazer
Air Tools & Compressors Logo
66 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
