Question about Linksys EtherFast Cable/DSL Router
I cant get my router to connect to the internet
I got a new internet company and therefore got a new modem and now i cannot re connect to the internet if i try to use my router. i went through all the steps with the software that came with it and still no luck.
  • 1 more comment
  • hayesyork Dec 23, 2008
    When the power goes out, I just have to unplug everything from the router and plug it all back in, left to right. Wait until 3 lights quit blinking, then try to acess internet. This usually works for me.
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 11, 2010
    can you also provide us with the brand or model no. of the modem that you have from your new internet service provider?
  • dragoness1
    dragoness1 May 11, 2010
    does the net work without the router?
  • 51 Answers
If your ISP is DSL based, try the following:
Click Start > Run. Type in cmd. (For Vista users click start, and search for cmd. Make sure to right click and select Run as Administrator).
When a black box pops up on the screen, type in ipconfig and press enter. Look for the words Default Gateway. Next to it may be 192.168.0.1 or 192.168.1.1. Whichever it is, type in that into your address bar of your web browser. A dioloug box pops up. Leave the username field blank and type in admin for the password. Wheen the page opens, scroll down until you see Local IP Address. Change is to 192.168.2.1. Scroll down and click save settings. Once that is done, log in the page again. You should be connected to the itnernet now, being that your cables are wired correctly.
Posted on Dec 24, 2008
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
Adsl wont stay on ,quick set up ,says cant find modem
Either the router is not connected properly to the modem, or the modem is not set up properly. First, unplug the router from the modem and disconnect power to both of them. Make sure the modem is connected to its data source, in this case the telephone line. Make sure the company has authorized the modem and make sure it's connected to the phone socket they specified, if they did. You should plug a CAT-5(ethernet) cable between the LAN port on the modem and the WAN port on the router. Now power on the modem. Wait until the modem's lights indicate it has a connection. If the modem doesn't indicate a connection, call your ISP. It will probably be as simple as them sending a refresh signal to it. After the modem finds a connection, power on the router. Your internet service should now be working. If not, try plugging the computer's network cable directly into the LAN port on the modem. If that computer then has internet, your problem is with the router. If the computer still doesn't have internet, then the problem is either with the settings on the computer or there's still a problem with the modem/ISP
Feb 27, 2010 | D-Link 802.11g Wireless Router WBR-1310...
EMule TCP Port 11522 not reachable
Does you norton program have a firewall included with the software? If so, your windows firewall was probably turned off automatically because having two firewalls running simultaniosly can cause a conflict between the two firewalls and therefore will not work correctly.If you have a firewall included with your norton software make sure it is turned on and leave your windows firewall off, other wise turn your windows firewall back on.
As far as your situation with the broadband modem, I have to ask: Is your Thomson hardware a broadband router (wireless/wired), or are you using an access point? (wireless/wired) If you are using a "router" there is no way to set it up to work with the modem the cable company provided you. However, if the Thomson modem hardware is an "access point" the only thing I can suggest is to follow these steps:
1) Pull the power cord out of the back of the modem that the cable company provided to you.
2) Next, plug in your Thomson router in to the ethernet port of the computer.
3) You are then going to configure that device. Start by going to the "network and Internet" section in your control panel. There should be a section in there where you can click that says "setup a new network connection" There should be an option to set up and "access point" and it will search for your hardware. If your hardware is found you will probablybe promped to input information about your router and once that's done it should set up successfully. If it isn't successful by some chance don't give up just yet! Go to step 4-
4) Shut down your computer.
5) next, switch the ethernet cable going from your Thomson hardware to the modem from the cable company.
6) You will then need a second ethernet cable to go from a second port of the Thompson hardware in to the ethernet port on your computer.
7) next, plug the power cord back in to the modem from the cable company and your Thompson hardware and start up your computer.
You should be able to get a wired internet connection if all goes well. If you have a wireless access point go ahead and set up a separate internet connection only this time choose "wireless" and choose your settings. I hope this helps. Feel free to contact me anytime if you have more questions. Happy Holidays!
Rachel
Dec 04, 2009 | Computers & Internet
Connect MSI RG54G2 to speadstream 4200
so that means if you connect the computer to the modem, it works but not with the router.
it seems that the router and the modem are not communicating with each other.
When you connect the computer to the modem , check the IP address through the modem. If ti is private IP address then you will need to change the settigns on the router.
Click Here for more info about networking
Oct 14, 2009 | MSI RG54G2 Router (MS-6848-002)
Says connection is excellent but i cant browse ..when i restart my modem and my router the internet works for about a min and then it stops again.
Contact your cable or dsl company and have them check to see if your modem is working correctly. If the modem goes up and down it will change the ip address and then your router will have to be restarted in order for you go get to the internet. If you want to rule out the router plug in a differnt one and if the problem persists I would say it is the modem.
Aug 02, 2009 | NetGear WGR614 Wireless Router
I have same issue and using Asus WL-520GC
HI! I will be more than glad to assist u in this concern..the reason why page cant be displayed bcoz the router and the modem wont talk to each other.. u are connect to the router but not to the internet..this are the possible solution.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 30, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Orange light on router no internet connection
YOU WILL NEED THE COMPATIBLE ROUTER FOR THE COMPANY YOU ARE WILL, THERE WILL BE BELKIN ROUTERS OUT THERE FOR ORANGE BUT YOU BEST TO GOOGLE IT ON THE NET OR CONTRACT THEM WHICH MODELS ARE COMPATIBLE AS EACH COMPANY HAS A CODE ON THE LINE.
Apr 16, 2009 | Computers & Internet
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
I cant get out to the internet when I connect the netgear router.
Be sure that your cable company has enabled your internet. Power down the cable modem, power down any routers and computers. Start cable modem first, after internet connectivity is indicated, power up the router (if you have one) and then power upi the pc
Dec 27, 2008 | Arris Touchstone 450a (CM450) Modem
How do i hook up a westell router to a moterola comcast modem?
Okay, well something is obviously wrong.
This is how it should be connected. Internet to modem, then with an Ethernet cable, connect the modem to the router (jack1) then with another Ethernet cable, connect the router (jack2) to the computer.
If you are still having problems, then contact your company to see if they could walk you through it, or if they needed to set things up.
Also, where are you connecting your laptop from? Is it very far from the router? Perhaps your router's signal strength isn't great enough? (This would mean getting a new, more powerful router.)
Jun 13, 2008 | Westell Wirespeed VersaLink...
Linksys EtherFast Cable/DSL Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
