Question about Dynex DX-E401 Router
I cannot connect to the site ?http://192.168.0.1 to set up my dx-e401 router can you help?
  • michael_gree Dec 23, 2008
    i did, and still cannot make it to the site to reprogram it, i lowered the firewall, i want to do port fowarding, but can make it to the site.
  • Teeboz Dec 31, 2008
    how do u open ports on dynext dx-e401 router
  • 3 Answers
The IP in the manual is actually wrong. Use 192.168.1.1 user: admin password: admin
This will let you into the router settings and you can configure it from there
Posted on Feb 21, 2009
    Genius:
  • 2,785 Answers
Plz check by resetting the router
Posted on Dec 23, 2008
I having trouble with my password
The best thing to do in this case is to reset the unit and then login with the "Default" login and password, once "in" the router then one can re-do the password etc all again.
Below is your manual, all is explained in there.
http://www.retrevo.com/support/Dynex-DX-E401-Routers-manual/id/8352ag821/t/2/
Aug 09, 2011 | Dynex DX-E401 Router
Trying to acces dynex router for xbox live and need a " pass phrase " lost the manual how do i connect
The Manual:
http://dynexproducts.com/cms/documents/DX-E401%20User%20Guide.pdf
The default address of the router is 192.168.0.1. Type that address into a web browser on a computer connected to the network and it should bring up the login screen for the router. The default login for the router is Username: admin with a blank password. If you changed this, you will need to reset the router with the reset button and configure your entire network again to make changes.
May 20, 2011 | Dynex DX-E401 Router
My dynex won't connect to my laptop
Try to change the channel first on your router. Access the router's admin page through http://192.168.1.1 and look for wireless tab and change the channel to 11. Save the settings. On your laptop, verify if your wireless settings is matching the router's wireless settings like the SSID and the security or encryption used.
Aug 02, 2009 | Dynex DX-E401 Router
Dynex DX-E401 Router setup
Here is the manual, and it states that to get into the router you use admin as the user name and password is blank. I would suggest that you reset the router. The reset button is on the back next to the power connector. Use a paper clip and push the reset button in for about 30 seconds till the lights flash. Then you should be able to log into the setup page and set it up .
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/DX-E401_Installation%20Guide.pdf
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 14, 2008 | Dynex DX-E401 Router
Wired dynex router suddenly started interfering with my internet connection.
Verify your router is connected to a standard grounded outlet. Check that the Internet cable is connected to the WAN port on your router, and check the WAN light on the front of your router is illuminated. Check that the LAN lights are on.
Power cycle your router by unplugging the DSL/Cable Modem from the power, then unplug the router and power off your computers. Then, plug in the DSL/Cable Modem to the wall and wait until all the lights are on and none of them are blinking. Power on the DX-E401 router and wait until all the lights are on. Now, power on one computer and verify the Internet connection.
You can verify your router is working properly by sending an echo request to it and verifying the response you get.
If you are a Windows user go to Start, select the Run option and in the dialog box type in CMD. Once there, type in ping 192.168.0.1 and you should get 0% loss as a response.
If these do not help, the router is likely to have malfunctioned, requiring repair or replacement.
Jul 29, 2008 | Dynex DX-E401 Router
Ftp server
What is the name of the software? Is that an FTP software?
Anyway if you are using DX-E401 Router you can enable DMZ (demilitarized zone) to your PC.
1.access your router configuration page (default ip: 192.168.0.1)
2.go to advanced tab
3.select DMZ
4.select enable then type the ip address of your server pc
5.apply settings
after that have someone try to access the files in your pc.
if the software you installed is ftp software then have them access it by this
ftp://internet_ip
the "internet ip" is the ip address found in the STATUS TAB of your router under the WAN catergory.
If this software you mentioned is using any particular application ports, you will have to open those ports for your server PC.
In that case you will to configure VIRTUAL SERVER. It's the actual term used by dynex. for you to have a general idea how to configure your pc behind your router please go to this link
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/DX-E401_Manual.pdf
Virtual server configuration is in pages 22-23. It has detailed explanation of the terms used.
Hope this helps!
May 07, 2008 | Dynex DX-E401 Router
Dynex DX-E401
Try an Xbox Live certified router.
GoTo
http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
Also it could be down to your connection what size is it?
I run 3 Live accounts and 6 PC's with no slowdown at all.
Feb 25, 2008 | Dynex DX-E401 Router
Software
http://www.dynexproducts.com/t-customer_support.aspx
Enter DX-E401 into Search and Click GO
Click this link under Product Matches
Dynex 4 Port Ethernet Broadband Router
You now have links to manuals, firmware and FAQs.
There is firmware that can be uploaded to the router and the FAQ and Manuals will explain the configuration process
Dec 16, 2007 | Dynex DX-E401 Router
Computers & Internet Logo
141 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
