Question about Dell 926 All-In-One InkJet Printer
When I restart my computer it locks up until I remove the usb cable from the computer to the printer
  • Anonymous Dec 31, 2008
    Same problem that I am having. The computer will only start in Safe Mode until I unplug the USB cord. Then everything works just fine.
    Master:
  • 461 Answers
Check your BIOS settings and remove USB from the boot menu.. This procedure varies by model of computer, please provide your model for more specific instructions.
Posted on Dec 23, 2008
I have a canon pixma mp 287 printer i have installed the drivers also and it is also not offline but when i am giving command to it then it is showing that printer is not responding.why it is showing like...
solution :
1. Uninstall driver printer and remove Printer USB cable from computer. After uninstall finish, restart printer.
2. Reinstall driver printer (don't connect printer USB cable to computer). Wait for the install process, until message "connect a printer USB cable to computer". After message appear, connect printer USB cable to computer.
3. Wait process install finish and try to print.
Sep 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
The cords are all plugged in and computer and printer is on but it wont scan, the computer cannot make a connection to the printer? there is no damage parts or wires.
Check and see if there is a lock button for the scanner,some printers have this feature so that during transportation or moving you can lock the scanner so it doesnt move to keep it from getting damaged,if that is not the issue then i would uninstall the software,restart the pc and then reload the software and make sure to follow the instructions on installing it to the detail.With usb devices you dont plug the usb cable in until it tells you to during setup,thats important,most printers are like that when installing,so if you installed the software with with the usb cable already plugged in then that can be your problem.Make sure your operating system is compatible with the printer such as winxp,vista,win7.good luck
Jan 24, 2011 | Canon PIXMA MP160 All-In-One InkJet...
The color is off when I print with my HP 3210 printer. It prints brighter and darker than the original photo. How do I reset it ?
erforming a soft resetA soft reset, also known as an Electrical reset, can be used to restore the printer to a ready condition when a cartridge, paper, or other printing issues occur. This reset method should be used for the HP Photosmart 100, 130, 145, 230 and 245 printers. Perform a hard reset for all other HP Photosmart printer models.
  1. Disconnect any USB cables attached to the printer and remove any memory cards from drive bay.
  2. Restart the computer.
  3. Unlock the ink cartridge locking clips.
  4. Remove all ink cartridges.
  5. Lock down the ink cartridge locking clips.
  6. Close the main printer door
  7. Turn the printer off with the Power button and wait for the printer to shut down before proceeding to step 8.
  8. Unplug the printer AC adapter from the printer and the wall outlet or surge protector.
    NOTE: The adapter itself has an overload trip that may need resetting, but will not reset if power is flowing to it.
  9. Wait approximately fifteen to forty-five seconds to allow all current to dissipate from printer.
  10. Re-plug only the AC adapter into the wall outlet then into the printer, but do not plug in the USB cable.
  11. Wait for the appropriate missing ink cartridge error to verify that printer can recognize this error.
  12. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page.
  13. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections.
  14. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer.
  15. Test for printer functionality.
Performing a hard resetA hard, or mechanical, reset is performed when the printer is in a condition where its normal printing process is interrupted. Examples include a paper jam, carriage stall, or mechanical noise. To perform a mechanical hard reset, follow the steps below.
  3. Remove any paper from the paper tray.
  4. Unlock the ink cartridge locking clips.
  5. Remove all printer ink cartridges.
  6. Lock down the ink cartridge locking clips.
  7. Close the main printer door.
  8. Turn off the printer using the power button and wait for the printer to shut down before proceeding to step 9.
  9. Unplug the power from the back of the printer.
  10. Unplug the power adapter from the wall outlet.
  11. Remove the rear access door.
    NOTE: The clutch is located in the same place as pictured above in Figure 1, however, you must access it from the left, just above the paper output tray.
  13. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  14. Release the clutch and roll the wheels up two more rotations.
  15. Locate and then roll the internal rollers in an upward direction until a clicking sound is heard.
  16. Reinstall and lock the rear access door.
  17. Connect the power adapter to a wall outlet.
  18. Reconnect the power cable to the printer.
  19. Turn the printer on.
  20. Re-insert the paper into the input tray.
  21. Wait for the appropriate missing cartridge error to verify that the printer recognizes this error.
  22. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page.
  23. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections.
  24. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer.
  25. Test for printer functionality.
Mar 05, 2010 | HP Photosmart 3210 All-In-One InkJet...
Will print test page, but nothing else,am on windows 7
Before reinstalling, go to ADD/REMOVE programs and completely uninstall the printer and software, and unplug the USB cable from the computer. Then restart the computer.
Make sure printer is turned on, then start installing the software again, and do NOT plug in the USB cable until told to do so! Once you plug it in, do NOTHING, and the system should finish automatically.
Finally, go to Control Panel / Printers and make sure it is the "default" printer.
Feb 13, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have a HPOfficejet 6310 All in One - I get the "No Scan Optiions Refer to device documentation when I hit the scan buttom...how do I set up the scan process?
You may need to uninstall and reinstall the software as per below procedure.
UNINSTALL THE SOFTWARE:
  • Unplug the USB cable. {caution - Do not reconnect the cable untill the onscreen prompt to connect while reinstalling}
  • Click Start > Control Panel and double click "Add or Remove programs".
  • In the list of installed programs, Click HP products and click "Remove".
  • Follow the onscreen instructions to remove the software.
  • After its done, restart the computer.
REINSTALL THE SOFTWARE:
  • After restart, insert the Software CD and follow the instruction to install.
  • At, one particular step you will be prompted to connect the USB Cable; turn the printer ON and then connect it.
  • Allow the installation to continue and then restart the computer and try scanning.
Regards
Rizwan
Feb 13, 2010 | HP Officejet 6310 All-In-One InkJet...
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
No communications computer to printer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jan 21, 2009 | Lexmark X75 MF All-In-One InkJet Printer
Unable to print from my computer to the printer
HI:
Try This:
Uninstalled the existing installed software of that printer in your computer then detached the USB cable from your PC restart computer. After restarting atached the USB cable then turn the computer. wait for a while until it recognized the printer then insert the CD Driver to the CD ROM then follow the instructions that pop-up to your screen.
Jan 12, 2009 | Office Equipment & Supplies
Will not work with usb cable
To fix a fouled install - (1) Uninstall the Lexmark drivers in Add Remove Programs
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark Office Equipment & Supplies
Inability to install hp psc 1310 series printer
uninstall the previous installation, restart your pc remove the usb printer cable, reinstall the printer driver donot plug the usb cable until the installation program tells you, then plug the usb cable, if it is detected its ok if not replace the printer cable with usb2.0 maybe the usb cable is defective.
Aug 06, 2008 | HP Computers & Internet
Dell 926 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
