Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Bog and dust on mirror....showing up on screen, how best to clean?
  • 58 Answers
Remove pointy screws out of back of screen ( 3 up each side and 4 across top). remove speaker grill, remove 4 screws from center cover. remove 4 screws from bottom of tv, disconnect wire bundle. lift screen up and off. clean mirror facing up and lens. Do NOT touch big mirrror, trust me. put it back together by sliding screen back on and making sure all edges are flush before putting screws back in. the pointy ones go in the back every other screw is flat. good luck, should only take about 5 minutes.
Posted on Dec 30, 2008
I have an 60PP9202 Rear projection HD TV and the inside of it needs dusting. Is there any instructions available on how to do this? The unit was purchased in 2004 and was vaccumed several times on the back...
You will need to remove the back cover. Here you will dust the lens with a pressure can of air only. Then you proceed to clean the lens with an eye glass damp cloth Get these from an eye doc). As for the mirror, you must use real caution. This mirror is made of a stretched plastic. The best way to clean this is to use a new feather duster. Do not even think of using anything wet to clean this mirror. It is very fragile. Let me add, that you want to do this from the rear also. Next, I would not recommend you try to pull the front cover (screen) off. It would be next to impossible to put the screen back on the TV. You will also feather dust the inside of the screen from the rear. No wetting solution here. Be sure your TV is not plugged in. Thanks for asking and show all hands of support!
Apr 21, 2011 | Philips 60PP9202 60" Rear Projection...
Need to take apart a Toshiba 57H83 for cleaning
This is fairly easy to do.
You will work from the back of the tv.
Steps:
1) Unplug the tv and wait a ten minutes for components to discharge.
2) Take the back panel off which is the brown pressboard with all the holes. Probably about 12 screws for that tv.
3) Take the back top plastic shround off if you want to clean the mirror. There are about 15 screws around the perimeter of the shroud, and maybe two in the back.
4) gently lift the shroud off the tv, it will have the mirror attached to the back of it so be gentle and careful.
5) lay the shroud on the floor so you can clean the mirror with window cleaner or non-streaking solution.
6) with the shroud off you should be able to see the tops of the CRT lenses covered in dust. Clean those gently. Do not bump them or turn the lens in any way otherwise you may need to do some re-alignment and/or re-focus of the CRTs.
7) DO NOT USE window cleaner on the back of the screen or front of the screen. You should get screen cleaner solution for this specifically. It might be best to just vacuum the spider webs off the screen and not clean it if you don't have the screen cleaner handy.
To clean the dust off the circuit boards, here is a tip:
With a clean soft paintbrush and a shop vac, or house vacuum, use the paintbrush and lightly brush around the components and on the circuit board. Have the vacuum hose right next to the paintbrush so it sucks up the dust as you stir it up. BE GENTLE on the components.
Stay away from the CRT necks and do not use your fingers. Remember the CRTs can still be carrying a good electrical charge, so best to avoid them.
Re-assemble the tv after everything has been cleaned. Figure it will take about 45 minutes if you haven't done it before.
Feb 20, 2011 | Toshiba 57H83 57" Rear Projection HDTV
My mitsubishi 65-inch dlp tv has white spots on the screen. What are the problem and solution?
It's either mirror hinge fatigue or dust on the inside.
Mirror hinge fatigue can be fixed by putting a solid color picture (white or gray works best from what I understand) on the display and letting it sit for 20 minutes.
If it's dust, someone is going to have to go in there and clean it out.
Also could be a defective micromirror device.
Try the first suggestion and if it doesn't work, you're going to need a technician to take a look at it.
Nov 22, 2010 | Mitsubishi WD-65833 65" HDTV
Mitsu 65" DLP-picture seems washed out
Most likely cause of your trouble is dust on the small mirror inside you set. Your DLP set has 2 mirrors not including the DLP chip itself which has about 500,000 tiny mirrors. The 2 mirrors reflect the DLP chip image to the screen you view. The first is the main suspect it's about 4inches by 7inches. It's mounted on the bottom center facing backwards. This mirror faces slightly up and somtimes after time dust, smoke, dirt settles on it . The second fills the space of the entire back of the cabinet but it faces down and takes alot longer to get dirty.
The compartment is sealed but dust seems to find it's way in. If you remove the screws that secure the screen assembly from the top , sides and bottom. Make sure to have a friend available the screen assembly is delicate when it's not mounted to the cabinet. You can remove and clean the mirrors. These mirrors are glass and you can use glass cleaned. Don't use glass cleaner on the screen it's plastic. You can clean it if necessary with plastic cleaner only. Probably not needed.
Good luck.
Apr 23, 2009 | Mitsubishi Televison & Video
Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
Jan 31, 2009 | Mitsubishi WS-55513 55" Rear Projection...
I have a Mitsubishi 62526 rear projection TV. When a wight background on the tv is desplayed, ie sky, snow , ect. I can see what looks like clouds on the screen. I have cleaned the screen, mirror and bulb...
i have the same issue.i had a service tech reccomended by mitsubishi come out and look at it. he looked at it for about 2 minutes-no testing or anything and sais it was the light engine- costs a 1000$ for the new one with replacement labor...
Jan 25, 2009 | Mitsubishi WD-62526 Projection TV
Dust inside my d200
The view finder and focusing screen are separate from the CCD sensor. The mirror reflects the image to the view finder until you take a picture. Then the mirror goes up, the shutter opens to expose the CCD to capture the image.
If you have a lot of dust, you should look into a cleaning kit, or have it professionally cleaned. This will show up on your images as white and/or black specks.
Jun 29, 2008 | Nikon D200 Body Only Digital Camera
Cleaning of mirrors
i have been fighting a dark screen almos impossible to see dark scenes
i found this from another person
the mirror has dust on it easy fix
remove front of screen by removing screws around the top and sides of the back don't forget to pop off the bottom cover in the front it just pulls off
then remove center cover screws
i could not disconnect the front electrical plug but it has enough slack to lift and then tip the front screen down to the floor
it will be obvious on the mirrors there is a big one it wasn't to dirty
lean in and look down there is a small mirror and lens they were filthy
there is a piece of foam trying to keep the dust out it was sucked backed so dust could get in
clean with windex and paper towels cloth didn't work
good luck
Apr 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dark blotches / Dirty behind screen
it could be dust in the mirror or in the optics,in this set if im not mistaken you have acces to the mirror from the back, anywhere from 12-20 screws it sould be easy to remove plastic cover first and the the mirror.this mirror are very delicate you dont want to leave fingr prints on it it will show just like the dust is showing right know. taking the mirror off will also give acces to the lense.
use someting soft to clean it.
hdtvman.
Dec 28, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
