Question about RCA M4204 MP3 Player
I was reformatting.got an error dont know what.now it want work
I was reformatting it to erase all songs to start over.some error came up.now it want come on or anything.when i plug it up tp computer nothen happens
  • 159 Answers
Even tho the computer wont say its there.
Download the firmware again. You might of got a corrupt firmware while downloading.
After its downloaded Go to where it downloaded
Click on the firmware install it if any errors show still continue to install the firmware.
Worked for mine good luck. I can also give you a link to get the firmware. Just hunt you make and model.
http://www.rcaaudiovideo.com/product.aspx?product=408
Posted on Jan 14, 2009
My freestyle player says format error how to fix?? it was working fine and then this error.
Hello there,
Q.: My player is having a DRM error / Format Error / Empty Disk Error
what do I do?
A: For all 3 errors, the first step is to attempt to reset the player, this can be accomplished by pressing the play and menu
buttons down together for approximately five seconds. If reset does nothing, make sure all the songs are .mp3s, if all songs
are .mp3s, attempt to format and re-sync the player.
if you need it
How do I convert my iTunes into MP3 format?
A: See Music Conversion Instruction Document: Transferring and Playing Music on Freestyle Audio mp3 players with
iTunes.
if you need to format the player here is how for MAC and windows.
Q.: What's Reformatting, How do I format my Player?
A: Reformatting your player basically wipes you player clean and deletes all songs, leaving you with a blank slate. Like
most removable drives you can reformat your player with no worries of damage to the unit. When reformatting on a Mac
make sure you choose the MS-DOS format style.
(CAUTION: FORMATTING WILL ERASE EVERTHING ON THE DRIVE)
PC (Windows NT, 9x, XP and Vista):
1. Plug in the Mp3 Player.
2. Put the Player in removable drive mode. Under "My Computer" you should
see the player as a removable drive.
3. Right click on the "removable drive" and a Drop down menu should appear.
4. In the menu select the option "format..."
5. Make sure that "FAT" is selected as the file system and that Allocation
Unit size is set to "Default Allocation Unit Size"
6. Now click format and wait, after it says format complete, you're done.
MAC OS 9 (and Earlier):
1. Plug the player in.
2. Put the player in removable drive mode.
3. Single-click the disk's icon on your desktop to format.
4. Pull down the "Special" menu from the top of the screen and select "Erase
Disk..."
5. Enter whatever name you want in the "Name:" field in the window that pops
up. If the disk is a hard drive, select "Mac OS Extended" from the
"Format:" pull down. If the disk is not a hard drive (such as a Zip Disk
or other removable media), select "MS-DOS or MAC OS Standard" for the
format.
6. Press "Erase." The drive will be formatted and ready to use.
MAC OS X (and later):
1. Start your computer and plug in the player in the USB port after the Mac
OS has completed loading.
3. An icon for a removable drive should appear for the flash drive on the
desktop.
4. From the Dock, open "Disk Utility".
5. Click "Erase" from the top selector (next to "First Aid")
6. Choose "MS DOS File System (FAT16)"
7. Click the "Erase" button
8. Perform the instructions given on the screen and finish the formatting.
if you need any help with a Step let me know and i hope this information was helpful don't forget to Rate .
Jan 27, 2011 | Freestyle Audio MP3 Player
Ever since i hooked up the usb ports from my mv8000 to my vista compuiter my roland wont save or it wont load any projects and also it seems that it erased all my songs that i ever worked on, when i start...
I think the most common cause of this with a pc is that windows media player scrambled the data on the hd.. you need to get a harddrive ide ata adapter , open the mv and connect the hard drive directluy to a computer then copy the files.. then reformat the harddrive in the mv then put the files back on .... i had the same problem with a mac but i dont know the cause since i dont have windowns media player.. im interested to know how this turned out.. i thinking of sending my drive to a drive saver company if it doens work out.. i neeeeeeddd my fillleessss.. aaahhhh
Dec 15, 2010 | Roland Mv-8000 Sampling/Record Production...
File system error..
try downloading a different file of that song.
and if the problem continues try re-nameing it manualy.
Jun 26, 2009 | Coby MP-C858 MP3 Player
Error! reformat internal media as FAT16
can you reach the data from computer (my computer)?
if so save what you think is important and then try reformatting it and then paste back the songs only.
May 25, 2009 | Audio Players & Recorders
I can't find out how to reformat my sansa e250!
I didn't have the same problem, but i know how to reformat it. first turn the player off. then switch the lock (the switch on top of the player) on. then press and hold the record button. (the one on the side of the player) then plug the player into the computer (then you can finally let the rec button go). the e250 should say "recovery mode" and you sholud see a new file on the computer. click the file ONCE. then scroll down and click new. then another file should pop up. name the file fmt. yes it DOES matter what you name it. it will erase ALL the data besides the time and date, but if you have tried everything else you pretty much have no choice.
hope it works.
karateboy100
Sep 17, 2008 | SanDisk Sansa e250 MP3 Player
My insignia
Try reformatting the unit using your PC as a FAT formatting. Don't use "quick format" so you can completely erase any glitchy memory points.
Also, press and hold the Reset button (little hole on the bottom right of the player) to reset the software.
Jul 20, 2008 | Insignia NS-DV2G MP3 Player
Do you no how to reformat?
Formatting your player erases all of the songs that you had stored there. Once erased, there is no way to recover them - you must re-add the files.
Jun 28, 2008 | SanDisk Sansa Clip MP3 Player
MP3
Reformat the player - may even need a firmware upgrade. You either have a corrupt database, or you are getting "error" messages on the 75 non-playing songs (which has to do with licensing).
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
May 30, 2008 | Audio Players & Recorders
Boot error please reformat
Reformat the player.
-Tha Mp3 Doctor
Mar 17, 2008 | RCA OPAL M4001 MP3 Player
When i switch the mp3 on its say error reformat again...........
-Tha Mp3 Doctor
Dec 24, 2007 | AIGO F008 MP3 Player
RCA M4204  MP3 Player Logo
37 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
