Question about Ricoh Aficio 1018D Copier
Copier will not sort documents correctly
I just purchased a used Ricoh 1018D and it works great except for one problem. When I select "sort" the light indicator shows it is selected. However, everytime the document is fed through the ADF with the sort selected, the machine stops after one copy is prouced and the "out of paper" indicator lights up for the paper drawer. If I feed the document through the ADF for multiple copies without selecting "sort", it produces the correct amount of copies from the paper tray without sorting. In this case, there is not out of paper indication and everything works fine. I would appreciate some guidance with diagnostics and/or a part replacement recommendation. Thanks in advance.
  • Larry Kiefer Apr 10, 2007
    I received the perfect solution to my problem. Thanks!
  • Anonymous Mar 20, 2014
    for a split second the paper light will illuminate, but paper tray is full
  • 38 Answers
If you are using a4 size paper,,,make sure that your using tray is prograo to a4 size...look the color green in tray with a number indicated there and adjust this that you want to use paper size
Posted on Jul 07, 2007
  • Ronaldo Panlaqui
    Ronaldo Panlaqui Jul 07, 2007
    or try this..example...you program in sort and if you are finish to copy press the symbol like this (R/#)
    Problem Solver:
  • 10 Answers
Hi songman to sort you need to have the A4 paper in both cassettes one cassette needs to be A4 portrait(wide edge first) and the other needs to be landscape (short edge first)make sure you have the green paper size selector set correctly as well regards Dr Bob1
Posted on Apr 10, 2007
Help my Ricoh Aficio 1018 is showing sc 990
These machines want their drums/pcu at 150K. SC990 is usually a good indication of a bad drum.
Sep 02, 2014 | Ricoh Aficio 1018D Copier
Resetting sc542 error
Fusing thermistor defective or out of
position
• Fusing lamp open
• Fusing thermostat open
• Fusing thermofuse open
• Power supply board defective
and for reset use prog 5-810 as follow
Resets all level-A service call conditions, such as fusing
errors. (To reset SC 547, switch the machine off/on.)
[0 = No / 1 = Yes]
• After selecting "1", press the Original Type key and the
' key (or OK key) at the same time to execute the
reset. If the reset is successful, the display shows
"Action completed." If the reset fails, the display shows
"Error!!!".
Apr 22, 2014 | Ricoh Aficio 1018D Copier
Use ricoh aficio 1018d as scanner
first do u hv a scanner and printer connection board in ur machine.if not its imossibal to work u must get one and install it.
Feb 11, 2014 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh aficio 1018D all in one printer is showing problem. No. SC 194
sc194 is an error with the scanner. It could be a bad exposure lamp, but it could also be a circuit board that needs to be replaced (either the SBU board or BICU board).
Mar 05, 2011 | Ricoh Aficio 1018D All-In-One Laser...
After reset SP5-810 we find error
Do this proceder:
After selecting "1", press the Original Type key and the OK key at the same time to execute the reset. If the reset is successful, the display shows "Action completed."
Feb 10, 2011 | Ricoh Aficio 1018D Copier
Finding IP address on ricoh 3260c
If you go into User Tools and select System Settings (or System Features, can't remember which one), there is a tab for Interface settings, and under that tab you should be able to view the IP address.
On some copiers (not sure if the 3260 has it) there is a tab on the bottom of the main Copy screen that says System Status -- if you touch that tab you should see the IP address.
May 29, 2010 | Ricoh Aficio 1018D All-In-One Laser...
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
this is an older model copier, however try going to www.savin.com and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Jan 09, 2010 | Ricoh Aficio 1018D Copier
Functional Problem on our Ricoh 1018D
Enter SP mode - Clear (yellow) key, 1 0 7 and hold and press stop (orange) key for 3 seconds.
Enter SP 5-810 (SC code reset) and
select “1”. Then switch off and on the machine.
If error still there, probably you have one of the following faulty;
Fusing thermostat open,
Fusing thermistor open or defective,
Fusing lamp open or
Power supply board defective.
Please, first check fusing lamp and thermostat for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Aficio 1018D Copier
Lost admin password for ricoh aficio 3260c.
if u have bios password u shoud do that remove your bios battry from the motherboard for few mints & your password will be reset
Jul 16, 2008 | Ricoh Aficio 1018D All-In-One Laser...
112 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
