Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow SEPE Aquamate - I don't know how to use it. Help.
I just bought this Rainbow SEPE second hand, but without instructions. I don't even know whwer to begin with the Aquamate.
  • kjlyons Jan 20, 2009
    Dear adavcak - Thank you so much! Sending the PDF of the original insturctions was so helpful! Thank you for taking the time and trouble to do it. Kathryn
  • bonniejobond Jan 23, 2009
    I have the rainbow E Series with the Auqa Mate Shampooer, but I do not have the instructions for the shamooer. Could you help me find out how to use it.
    Thank you
  • 125 Answers
The hose connects to your faucet the jug on the other end , fill with soap
connect the wandsand floormate then the rest should be obvious
Posted on Dec 23, 2008
Here is a pdf file that has the instructions.
http://www.zianet.com/alkone/pdf_text/aq_en.pdf
Posted on Jan 08, 2009
Where do I get an adapter for my rainbow shampooer
This really depends on what Rainbow you have and which Aquamate you are using. There really is not an adapter for the Aquamate. The newest aquamate out there is for the E2 type 12 black that came out in 2012.
There is a modification of this aquamate to fit older E series vacuums (comes with a cord) , but you will need to have an electrified hose made for water pick up to use. You can find that aquamate here
Rainbow AquaMate 3 carpet shampooer
GoodVac
800-775-6586
Mar 05, 2015 | Rainbow Vacuums
How does the nonelectric hose detach from the wand on rainbow e series to connect to aquamate
Rainbow E Series attachment hoses fit the wand with friction. The wand will just twist and pull out of an attachment hose. Now for use with an Aquamate, if you have the newest aquamate like here:
Rainbow AquaMate 3 carpet shampooer , the aquamate needs an electrified hose made for water pickup and a stainless steel long pipe (stainless steel so it will not rust, you can use chrome but it will rust) .
Vacuum Repair Technician
800-775-6586
GoodVac.com
Feb 17, 2015 | Rainbow Vacuums
Why my aquamate will not spray
There may be solution clogging the tubing in your vacuum. A thorough take apart and cleaning will be needed.
Aquamate will not spray troubleshooting
GoodVac.com
800-775-6586
Jul 29, 2014 | Rainbow Aquamate Water Line Adaptor R-3250
Wont spray, no triger noise
<p>Need to know what model you have....</p>
<p>Do you have an <a href="http://www.rainvac.com/aquamate-model-am12-silver">AquaMate, Model AM12 (Silver)</a></p>
<p>or an <a href="http://www.rainvac.com/aquamate-ii">Aquamate II </a></p>
<p>or <a href="http://www.rainvac.com/aquamate-i-refurbished">Aquamate I</a>...</p>
<p>Let us know or call us to speak to a Rainbow Specialist.</p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Nov 04, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Aquamate II NOT WORKING !!
If this is pre-owned unit that you bought - it may be clogged. If people who had it did not rinse shampoo solution out of the system after using it - shampoo becomes thick and sticky when dry and may clog the tubes. Also it may impair the pump.
Pump may also be defective. It should make a humming noise while in operation. It is hard to hear when vacuum is on so take the Rainbow with water bowl of the white AQM basin, turn on the vacuum while AquaMate is still plugged in, put your hand on the black plastic on the white AquaMater water nontainer and you should feel pump vibrating inside.
If you feel it start with filling up the white tank and bottle with warm water, turn AQM on and try rinsing it. However if water can not get through at all - it will not help.
Then take the handle apart (a bit tricky but be careful ant to break the plastic and you will get it open). See if there are no clogs there. in tubes nor the VALVE.
If no clogs fing - you will have to acces the pomp and few short tubes inside this plastic box assembled onto the water tank. to get it open you may have to break off 4 latches that hold top halve to the bottom. You can purchase one HERE. Make sure that tubes inside are not bent at the sharp angle and obstructing the flow. If you need any tubing - you can find it cheap at Home Depot (have a sample with you so you pick the right diameter).
Clean all tues inside and you possibly will have to take the pump apart to get it cleaned. If it is not working you can buy one HERE.
Stil no luck - put EVERYTHING in a plastic bag or several bags and then in a box and ship it to us - we will get it running.
Good Luck,
Rocky
Mar 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
No iunstruction for my Rainbow Aquamate
Go to Rainbow manufacturers site - they have manuals THERE
Nov 15, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow shampooer and frieze carpet
yes, it can be used without harm, but try a test area to be sure the dye is not cheap
Aug 21, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
466 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
