Question about Toshiba SD-2800 DVD Player
Cd's are ok but no dvd's...
Hi,when i insert a cd in the dvd player sd 2800 it's work all right but when i insert a dvd the tv display:"check disc"...it seem that the 2800 try to read a few time before displaying the info "check disc"..i have unscrew the top and it is very clean...we doesn't use it that much... thank you
  • avh22 Apr 24, 2008
    I have the same problem, It only reads cds. When you try to play a DVD it says loading and starts and stops spinning a few times but eventually just says "DISK ERROR".
Had similar problem. Found the disk was not rotating. Adjusted the torque on the hold down screws of the drive unit allowed the disk to spin. Still had some motor noise, but DVD would load.
Posted on May 19, 2008
Onboard LCD display
did you try to insert a different cd? see the settings like OSD button on the remote control or display to view the tracks.
CHARCOIS
Sep 13, 2008 | Toshiba SD-4900 DVD Player
Jvc vcr/dvd recoroder dr-mvis
No power, No Display - test voltages on secondary side of transformer were pulsating
Check diodes 6230, 6240, 6210. They are BYW98 Rectifiers, in my case it was s/c. Thanks to Sparky for similar tip - Philips CD Model: CDR770/00
No power and no output
Replace C6 with 4.7uF, 250v
No power, voltages on secondary side of chopper were very low and pulsating
Check diode 6230. It's a BYW98, in my case it was s/c. Note: it's the rectifier for the 14v line
Dead, no power up on pin 2 of ic601
Replace x601 on main processor ic601
(Brko) Toshiba DVD Model: SD-1750 / SD-2800
No sound
Replaced C927 / C928
Nov 26, 2007 | Audio Players & Recorders
Dvd screen comes up on TV but dvd player says "disc error".
unplug the pwr cord from dvd for 5-10 min..plug back into outlet..make sure the av cable is connected white-white yellow-yellow red-red...now press play on the dvd
feel free to rate help
Jul 04, 2010 | Toshiba SD-2800 DVD Player
Our dvd player now only works showing movies in black and white. What can we do? It use in color but for some unknown reason the movies are in black and white.
someone must have pressed something mistakenly.
Check the DVD remote and press PAL/NTSC. The color should appear.
Or you could also check the video wire at the back of the DVD and TV, maybe it has loosed contact.
I wish you all the best.
Jan 07, 2010 | Toshiba SD-2800 DVD Player
"No" message appears on player front.
Try inserting a cd, almost all dvd players can play cds as well, if it displays the same message you may very well have a defective dvd player, if it plays then you may have a damaged disc. If it plays the cd try a mint condition dvd; also, I'll assume that you know better but in many cases if the dvd player is not defective users are simply loading dvds in upside down. If all this fails return your dvd player to the store or check the warrenty.
I hope this helps, good luck
Jul 23, 2009 | Toshiba SD-K760 DVD Player
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD sound a problem but is playing ok.
try changing your dvd audio settings to stereo
Nov 12, 2008 | Toshiba SD-2800 DVD Player
DVD PLAYER
Hi Koji, My Toshiba DVD player does the same. It stops playing the disc, and the icon for incorrect disc displays. Often I cannot even start a movie. I keep getting BAD on the readout display also. I try hitting the player, or the stand in which the player is sitting, and sometimes it goes away and the movie plays. I will never buy Toshiba again.
Dec 25, 2006 | Toshiba SD-3980 DVD Player
Toshiba SD-2800 DVD Player Logo
259 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
