I have a mitsubishi projection tv and the sound and the menu work but no picture
  • Jeff Hogancamp
    Jeff Hogancamp Dec 23, 2008
    nope all the cables are in correct and the vcr won't give me a picture .
  • Jeff Hogancamp
    nope they are connected correct and the vcr wont give me a picture but i can see all the bulbs are working when i press test button. and the sound works well as the menu screen.
  • 3 Answers
Make sure all your cables and plug are in good and they are in the right spot that they need to be in. Flip around to a couple of channels and see if it worked... If not let me know and I will help you however I can... Glad to help.
Posted on Dec 23, 2008
I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
check to see if with a rear audio/video input you have sound (DVD etc)
look in menu speakers are not set to off or external
try the reset: Menu 1,2,3, enter.
Dec 22, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi dlp tv turns on but all static ,no picture or sound
What is model number and do you have Mitsubishi remote?
Soft reset with set on is for most models : Menu, 1,2,3 enter.
Feb 19, 2012 | Mitsubishi WD-60735 Projection Television
I have sound but no picture
Use your mitsubishi remote and press the menu button which will open up the menu screen and you will see the picture in the upper right. Now you press 1370 then the enter button and you picture will be restored. This is the factory reset for all mitsubishi projection tv's
Dec 03, 2011 | Mitsubishi VS-6043 60" Rear Projection...
My Mitsubishi VS 50703 is fed from a DVR into input Ant A. I get sound, but no picture, until I press the 'menu' button on the TV remote; then the picture appears in the PIP window for a few...
Try resoldering the vertica IC. Very common problem. When vertical drops out the CRTs go into blanking ( shutdown no picture) but the menu and on screen displays will still work. Resoldering the IC will usually solve the issue.
Jul 15, 2011 | Mitsubishi VS-50703 50" Rear Projection...
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Tv comes on and has no picture. menu there, video on monitor jack
This an old tv. From my experience i would replace it. It will be a money pit.Crts are beyond there life expectancey.
Nov 24, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi rear projection tv
you have a problem on the chassis. either the FMT, DM, or the terminal board have gone bad. the quickest most effective way to repair would be to repair the chassis. check out
Dec 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubushi vs4541 red,blue,green vertical lines no picture,very good sound
Try soldering the vertical output IC, sound without picture usually means vertical output is either defective or has bad solder joints. Does your on screen displays work when you press menu?
Mar 12, 2008 | Mitsubishi WS-48315 48" Rear Projection...
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Mar 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
