Question about Kenmore 73952 Gas Dryer
How to convert a drier from nat to propane gas i dont have the instruccions
  • luzysky Dec 23, 2008
    its the other way nat to propane
    Sergeant:
  • 359 Answers
NOT SURE BUT DON'T THINK YOU CAN USUALLY CAN GO FROM PROPANE TO NAT BUT I KNOW WITH FURNACES YOU CANNOT GO FROM NAT TO PROPANE AND THAT IS THE CASE WITH GAS LOGS AS WELL BUT NOT 100 % ABOUT DRYERS .
Posted on Dec 23, 2008
  • Allen Neal
    Allen Neal Dec 23, 2008
    CORRECT MY BAD
Convert from lp to ng
orifice sizes will increase since goin from lp to nat gas.......to convert appliances you will need diff gas valves, nat gas and propane will have diff pressures
Dec 05, 2013 | Heating & Cooling
How do you change a change glo-warm sit 630 from natural gas to propane
You cannot do it. Their is no way. These come in 2 versions. Natural OR propane and they cannot be converted. The pilot is designated as a nat pilot assembly and the gas valve is designated a nat only valve. Their is no way to convert it not without costing a ton of money. You would need a LP gas valve and an LP pilot assembly. It would be better just to sell it to a nat gas user and get an LP one.
Jan 09, 2013 | Kitchen Ranges
I have two pitco fryer natural gas that I like to convert to propane please help
Hi there!
You will be needing a gas valve conversion kit (nat to propane),
propane pilot orifice and burner orifice (depends on number of burners).
You will find these parts awhen you visit http://www.pitco.com
Regards.
Jul 04, 2012 | Kitchen Appliances - Others
How do I reconvert my Natural Gas BBQ BACK to LPG?
You will need to replace the nat gas orifices with propane ones, as propane orifices have smaller holes than nat gas ones. If you can't find a conversion kit for your grill, take it to a local propane co and have them convert it for you. What I do is drill out the existing orifices on the grill and install a spud, then redrill the spud with the smaller hole for LP-Gas. Then you will need to buy a regulator and hose and a 20# propane cylinder, if you don't have one. You can get those things from the propane co too. Call around first and see if anyone can help you.
NOTE: If your grill data plate isn't marked with the BTU rating of each burner, look at the nat gas orifices and see if there is a number stamped on it. I can reference this number to tell you what BTU rating they are drilled for and use that to redrill for propane. If they are not stamped with a number, then I would use my nat gas orifice drills to gauge what hole size it is. Hopefully you can find a local propane co that carries these orifice drill kits and orifice spuds to get the job done. You didn't mention the grill brand or model #, so I can't help with specifics until I know what you have. I may be able to find a conversion kit online if I knew that info.
Douglas
Jun 13, 2010 | Grilling
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane ready...you need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Maytag Range Model MGR5870 how to convert to propane
set the regulator to propane and change the orfices to the blk ones. copper is for nat gas / black for propane .. thanks hope this helped .mm
Dec 22, 2009 | Maytag MGS5870 Gas Kitchen Range
I'am trying to convert a ducane grill from propane to natural gas and I need to know the correct dia to drill the orifices. Any ideas??
when you convert a Ducane nat. gas grill to propane do you need to adjust the opening in the burner tubes
Nov 06, 2009 | Grilling
Convert propane dryer to natual gas
You need the NAT gas orifice and the stem under the cap on the burner needs flipped over
Jun 08, 2009 | Whirlpool GGX9868J Gas Dryer
Converting to propane
Call Dynasty / Jade ph # 800-884-5233 order convert kit from Nat to LP. Flip the cap on the gas regulator from Nat to LP, talk with Brad @ Dynasty if you needed help. Have fun.
Mar 22, 2009 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
CONVERT NATURAL TO PROPANE
you will need to change the injector (orrifce ) to a propane one the burner should burn nat gas and propane
Jun 27, 2008 | Rinnai RER-55AS 55-Cup Rice Cooker
Kenmore 73952 Gas Dryer Logo
108 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
