Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Display Codes The display on my fax shows a series of ampersands and H's (example &h&h&h&h ) everything seems to work fine except that none of the print out functions work.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
Updating the Firmware Unlike other machines with removable EPROM (Erasable Programmable ROM), this machine is equipped with an F-ROM (Flash ROM). F-ROM offers the flexibility of quick and easy firmware updates, creation of a master firmware card, backup and restore of firmware and machine parameters. The following is the basic procedure to update the firmware of the machine. The details are described in the Firmware Update Kit User?s Guide. (Order No.: DZTP000019)
Posted on Jul 26, 2007
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
I have the boss BR-900CD and everything seems to work fine but nothing shows up on the screen. It lights up but no data shows up. Thanks
the problem is from the display IC of your unit. You nee to change the display IC for your unit to display again.
If you cannot do it yourself, maybe you should consult an expert to help you have it fixed.
Good luck.
May 13, 2010 | Music
Incoming faxes are showing busy on the sender's end.
TAM is the setting for answering machine. Set it to fax. Not sure how on those ones.
Mar 31, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Denon AVR-3802 Front Display problem
This can be either the display itself or the display driver IC havng problems. Something as simple as poor solder connections may cause this as well. Without seeing hte unit, it is difficult to say what the real problem is. If you can solder, try resoldering all of the voltage regulator ICs in the unit. These look like transistors and will be marked 7805 or 7812. If the voltages drift too low because of bad connections, the ICs can get "confused" and not work properly.
Keep us posted.
Dan
Aug 26, 2008 | Denon AVR-3802 Receiver
Display problem
there are lamps inside the face of this head unit that go bad sometime they are wired in series and therefore if one goes out none will work. they a very small lamps soldered to the circut board inside the face
Mar 27, 2008 | Car Audio & Video
After static shock, keypad on fax machine is not working...everything else ok
Most office machines are properly grounded and don't suffer from static problems as severe as this. The machine is not repairable. Before you replace the machine, make sure that your electrical outlets are properly grounded. Then buy a line conditioner that will protect against this.
Nov 30, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
116 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
