Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Missing folder options
Can i make the folder options in tools appear using regedit?? tnx for answering..
    Genius:
  • 2,785 Answers
HKEY_CURRENT_USER\SOFTWARE\MICROSOFT\WINDOWS\CURRENT VERSION\POLICIES\EXPRLORER
check in right pane- a Dword value named No Folder Option exit or Not- if yes then delete it.
Warning be care full when you edit registry any wrong delete will crash your system
Posted on Dec 23, 2008
I think my laptop has a virus because when i attempt to open run and type "regedit" a window will appear it say "registry editing is disable by your administrator" i am the administrator but i did not do...
to make sure you´re virus free try another antivirus.
Go to:
http://www.eset.com/onlinescan/
and run the online scanner ( works with Internet Explorer only, I think ). It is pretty accurate and might find something that Avast missed.
Oct 21, 2009 | Computers & Internet
Tip
How to remove the content advisor password?
Solution:
Although the removing the password in content advisor is not covered under warranty. It is a few simple steps to clear it and resolve the issue.
Follow the steps below:
(It is advisable to make a backup of the Registry before proceeding. To do this, go to the File menu, choose "Export Registry File..." and give the file a short name (e.g.: Backup1.1.04) storing it in the root level of the primary hard disk drive or floppy.)
1) Click on Start and choose Run.
2) Type in RegEdit and select OK.
3) Now click on the little plus sign to the left of HKEY_LOCAL_MACHINE.
4) Continue to drill down, always clicking on the plus sign at the left of the named key, through Software, Microsoft, Windows, Current Version and Policies.
5) Now click on the Ratings folder.
6) In the right pane of the RegEdit window, you'll see an icon called Key. Click on it and press Delete.
7) Next, choose Registry and then Exit to exit RegEdit. You've just deleted your original Content Advisor password.
8) Restart the computer and run Internet Explorer again.
9) Choose View and then Internet Options (or Options for version 3.x). For IE 5 or greater, Click on Tools, Internet Options.
10) Click on the Content tab and click on Disable. When asked for a password, don't enter anything; just click on OK. This will disable Content Advisor because there's no longer a password.
How to Fix Problems with Content Advisor Missing Information?
In most cases, this problem occurs when the Ratings.pol file is damaged, follow the instructions below to fix this issue.
1) Quit Internet Explorer
2) Open My Computer, click on Tools, Folder Options
3) Click on the View tab and make sure "Show hidden files and folders" is selected, you may also want to uncheck the box next to "Hide extensions for known file types" and click Ok
4) Double click on Drive C in My Computer
5) Double click on the Windows folder and then double click on the System folder
6) Search for the file RATINGS.POL and right click on it and choose Rename. Rename it to RATINGS.OLD
7) Close out of the open Windows and then reopen Internet Explorer
8) Click on Tools, Internet Options
9) Click on the Content tab, then click on Settings
10) Type in the Supervisor password if necessary and click Ok
11) Select the Ratings options you would like and click Ok and close out of Internet Explorer
12) When you reopen Internet Explorer, everything should work.
on Mar 29, 2010 | Computers & Internet
Tip
Enable the Registry Editor, Task Manager and Folder Options Disabled by Viru
Virus attack is common these days and we often come across the problems like Disabled Folder Options or like Task Manager and Regedit disabled by Administrator. These problems are nothing but virus activities. The virus has infected our system and stopping us from accessing these options.
Pressing keys Ctrl+Alt+Del opens up a dialog saying that “Task Manager has been disabled by your Administrator” whereas you are the Administrator yourself. It becomes very annoying when you think that you can fix this problem by going into the Registry Editor but it doesn’t show up. Even the Folder Options gets disabled.
This problem is generally caused by a virus named “Brontok” but don’t worry just use RRT (Remove Restrictions Tool) that can easily solve this problem. RRT is free and can successfully enable:
1. Folder Options
2. Regedit (Registry Editor)
3. Task Manager
4. Show Hidden Files option
The tool will come more useful if you use it in Safe Mode.
Download RRT
on Nov 17, 2008 | Microsoft Windows XP Professional With...
Unable to activate show hidden folders
You are right that this is because of a virus attack. The virus has changed somethign in the registry. Follow the below methods:
Method 1:Go to registry editor by running regedit in the run box.
Go to this key:
HKEY_CURRENT_USER\Software\Microsoft\
Windows\CurrentVersion\Explorer\Advanced
In the right hand area, double click hidden and change the value to 1.
Now you’re all set to go. Check it in your tools menu if the changes have taken effect.
Method 2:1. Click “Start” -> “Run…” (or press Windows key + R)
2. Type “regedit” and click “Ok”.
3. Find the key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\
Advanced\Folder\Hidden\SHOWALL
4. Look at the “CheckedValue” key… This should be a DWORD key. If it isn’t, delete the key.
5. Create a new key called “CheckedValue” as a DWORD (hexadecimal) with a value of 1.
6. The “Show hidden files & folders” check box should now work normally. Enjoy!
Mar 29, 2009 | Microsoft Windows XP Home Edition
Surabaya in my birthday
If you are getting message like" Surabaya in my birthday, Don't kill me, I'm just send message from your computer", then it obvious that your computer is infected with Surabaya Virus
Symptoms of Virus
1) All folders get disappear.
2) Folder options not work.
3) Machine Restarts on running command like msconfig , regedit.
4) You are unable to install many antivirus.
5) Folders name appear with scr extension ( Actually not folders)
Reasons of infection
1) Infection from removable drives e.g. pendrive, hard disk,
2) Reading cards using card reader
3) From CD or DVD
4) From others computer
5) From internet
Remedies:
1) Using free software:
Download the "Autorun Eater" from internet ( 1.5mb)
Download from:
http://oldmcdonald.wordpress.com/
http://www.softpedia.com/get/Security/Secure-cleaning/Autorun-Eater.shtml
a) Install "Autorun eater" ( some Antivirus detect it as a virus but it is safe) and run it. It appears at taskbar ( lower right corner)
b) Right click on it and follow following path
Registry fix>>fix folder option.
(This will repair folder option and it will appear in tool menu)
Now you can see hidden folders
But Surabaya virus change your folder attribute to system folder. So to see your folders you have to untcheck option " hide protected system files and folder" which appears
Right "below the show hidden files and folder" option
Path:
Open my computer>>tools>>folder option>>view>>uncheck show hidden files.. and hide protected system files and folder
How to change folder attributes to normal
You can use command prompt to change the folder attributes
A) Start MS-DOS command prompt (start>>program files>>accessories>>command prompt
B) Type drive letter and attrib command
D:\Attrib *. * -S -H -R /D /S ( Put space between /D and /S switches.)
This will change your all folder option to normal
1)Manual:
a) type "regedit" at command prompt..STRAT>>run>>regedit
b) Search word 'surabaya' in registry...Edit>>find>>Surabaya
c) Delete two entries appeared in search as " LegalNotice Caption and LegalNoticeText"
d) Now using left option tree navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\showfile
check value 0 to 1
Autorun Eater software:
Autorun Eater software helps to protect and remove autorun virus which generally infects from external storage device and internet. This small software is very helpful in conjunction with any antivirus software even it alone can protect your computer from autorun virus(but not complete solution).
(C)infoall , legal: Use above information on your own risk
Mar 21, 2009 | Microsoft Computers & Internet
Folder option is missing and regedit disabled
u need to format ur system or can run a full system scan
Apr 19, 2008 | Microsoft Windows XP Professional
Folder options in my control panel and in tools menu
hi friend
ur pc has been infated by viros taht y the folder option remove so u have to do this dwonlaod the latest updated antiviors form the intenet downlod it install ur pc scan form it see the link for more info
http://maintainyourpc.blogspot.com/2008/02/registry-editor-disabled-by.html
http://maintainyourpc.blogspot.com/2008/02/task-manager-has-been-disabled-by-your.html
after removing viorus here is link for ur restor ur folder optin link downlod soft & install it
http://www.raymond.cc/blog/archives/2007/06/28/restore-task-manager-regedit-and-folder-options-disabled-by-virus/
Mar 28, 2008 | Microsoft Office Professional 2007 Full...
Problem in Windows XP sp2
Type the following text in notepad
REGEDIT
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoFolderOptions"=dword:00000000
Save this file as recover.reg [.reg is extension for regfiles]
Double click on it.
Log off is essential.
Mar 15, 2008 | Microsoft Windows XP Professional
Folder option
may be you are only using the USER account so folder options are not available... there are full administrative right to use folder option so have a check with this...
in case you are administrator then also it s not available means this may be due to virus attack some system files have became unstable .... so try reinstalling operating system ...
and in further dont forget to use updated antivirus......
Feb 09, 2008 | Microsoft Windows Server Standard 2003 for...
Hidden folders not visible even after i follow folder options to open hidden folders
Use winxp original cd and repair it sir it will fix ur problem
Oct 20, 2007 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
