RX600 why are my black and white prints coming out green - ?
    Sergeant:
  • 287 Answers
You need to clean the inside of your printer the ink is smearing and turns the prints green. you can clean with rubbing alcohol.
Posted on Dec 23, 2008
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
Printing in just black and white
Epson,. has it rigged, that you must have ink in all the cartridges.............! Doesnt make a difference, if you are printing black and white ONLY.
You have to replace them.
Good Luck......
Dec 29, 2009 | Epson Stylus DX8400 All-In-One InkJet...
No black when printing color
Dear Sir,
You are getting black lines in green color,and apperence of parallel light and dark lines because your colour catridge is almost empty.So solution is replace the catridge and take a printout. There is no proplem with a printer. i think it solves your problem.
good luck
chandrashekhar
Jul 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Epson Stylus Pro 4000 is printing green instead of black
Hi mariann346i am having the same problem with my EPSON RX 595 printer.
i can not print in black and white, it always prints in green.
i also notice something els, even after refilling my six cartridges
and only trying to print in black and white, my yellow ink is running out just as fast as my black so i guess they are somehow mixing together. you should check to make sure your yellow isn`t doing the same.
Jul 14, 2009 | Epson Stylus Pro 4000 InkJet Printer
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
Printer cant print in black and white
This happend to me also and I finally found out that the printer uses collor cartidges for GRAY printing. The back cartridge is used for BLACK printing ONLY. So if the printer was short of one collor in my case it was magenta (red) the gray parts of BW prints started to be green!!! When I put new magenta cartridge to the printer gray was gray again...
Mar 03, 2009 | Canon MP610 Photo All-In-One Printer
Black and white photo printing
Paste the address below in your browser.You might find some vital information there.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10238
Jul 09, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Rx600
Here is a link to the Epson printer RX600 support page which has downloads of latest printer drivers for your unit.
Did you remove any type of protective material that may be on the cartridge before installation?
Apr 26, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Printing Problems
In Windows 98/ME/2000:
1. Go to START, SETTINGS, PRINTERS.
2. RIGHT CLICK on your Epson printer name; left click on PROPERTIES.(PRINTING PREFERENCES in Windows 2000).
3. Go to the MAIN tab.
4. Place a check beside BLACK INK ONLY.
5. Click APPLY then OK.
In Windows XP:
1. Go to START, CONTROL PANEL, PRINTERS AND OTHER HARDWARE or PRINTERS AND FAXES. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear).
2. RIGHT CLICK on your Epson printer name; left click PRINTING PREFERENCES.
3. On the MAIN tab.
5. Click OK.
Remember to repeat these instructions and remove the check from BLACK INK ONLY when printing photos or color images.
Dec 28, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
233 people viewed this question
jasbo
jasbo
