Question about Samsung PCN5425R 54" Rear Projection Television
My samsung rear projecter has sound but no picture.
The color tubes are lighting up on the bottom of tubes but no light coming thur the lenses.
  • 9 more comments
  • john_hegedus Dec 24, 2008
    classyexpert posted the problem was the(ot crt) dose anyone have laymen terms on whats wrong.
  • john_hegedus Dec 28, 2008
    does any one know what a ot crt is and where do i locate it
  • john_hegedus Dec 31, 2008
    My samsung pcl5415r has sound but no picture. have replaced the red tube, all tubes lightup on the bottom but no light or anything coming thur the lenses. what is a ot crt? and where is this located? when answer my question explan and give location. than you
    thank you is the sub-deflection board the same as ballast ? sub deflecter is middle board.
    is the ballast board the same as the sub-deflecter board? or where is it located? 1,2,3, boards looking from back, #2 is sub- deflecter
    is the ballast board the same as the sub -deflecter board? where is it located 1,2,3 boards looking from back. is the CRT the tubes
  • 2,336 Answers
These rear projection TVs don't have a ballast.
The video boards are connected to the CRTs to provide high voltage and video info to the CRTs.
If not video is present but the CRTs are lighting up then is more likely a high voltage failure. The part that might be defective is the high voltage block that distributes power to all the CRTs..
Posted on Dec 31, 2008
  • Samsung Master
  • 19,396 Answers
Have the ballast boards that powers up the tubes checked, otherwise one of the CRT is faulty.
Posted on Dec 23, 2008
  • Ginko
    Ginko Dec 31, 2008
    What is often called ballast boards , are small high voltage board that connect to CRTs, they are called ballasts even if they are different from a traditional ballast. The CRTs are the tubes.
    Sergeant:
    Novelist:
  • 327 Answers
Its the problem ot crt and needs reparing.to make it proper. thanks.
Tv gets light blueand stays that way...comes back to perfect color the back to blue X-RAy looking it is a samsung pcl545r
Behind the screen, there are three color tubes: Red Green and Blue.
Unfortunately, rear projection screens often have these problems and the tubes do go out after extended use.
Take the television to a TV Repair shop to have this fixed. But in the long run, this may end up costing you a lot more than if you would purchase a new TV. The light tubes are fairly expensive.
Jun 03, 2011 | Samsung PCL545R 54" Rear Projection...
Tv is now in faded black and white
Your HT Tansfer is giving low votage to the picture tube. Replace the HT Transformer(don't touch or go near it, it carries 11000 Volts!)....sodeep
Mar 22, 2009 | Samsung HLN5065W 50" Rear Projection...
We are using the 55 rear tv to display our logo for a talk show.
I assume you purchased the tv in the current condition you are describing. Philips are notorious for having cloudy glyconol coolant. The coolant is situated in a chamber between the light tubes and the lenses and is required in order to keep the tubes running cool or they would otherwise crack from the excessive heat from the light tubes. The coolant normally becomes corrupted in the blue tube first, with the red and green tubes following closely behind it. The Video that is able to project through the cloudy coolant causes a picture that is washed out, fuzzy, and can even cause rainbowy colors depending on how many chambers are cloudy.
If you want further proof that the glyconol is corrupted, you can have someone remove the rear cover and take off the lenses from the light tubes so you can see directly into the coolant chambers to determine which ones are cloudy. Replacing the coolant is an involved process. You should attempt to return the tv to the sales person for a full refund if possible and explain the tv is not okay as he said.
Mar 12, 2009 | Philips 55PW9363 55" Rear Projection...
The screan is dark on the top and bottom and color is strong
This not the correct Model #, this model is a DLP set and does not have picture tubes and associated lenses. Did you remove the mirror? Does your set have a fold in back? I suspect the back is not fully out in the correct viewing position.
Dec 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
either your tube lenses are dirty or your focus control is bad.
May 17, 2008 | Samsung HCN4727W 47" Rear Projection...
No picture, but it does have sound. HLN617W
This sounds similar to the same problem I had with my TV. I went out and purchased a new light thinking it was the source of the problem, but I was wrong. It turns out the color wheel and fan went bad and it cost roughly $575.00 for the parts and labor to fix it. My tv was the hlr6167w
Feb 24, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
