Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Pooling Water I have a Kenmore 106.42102300 which is a Freezer on the bottom and convertable frig/freezer at the top. It was manufactured on 2004. We use the top compartment as a refrigerator. The unit appears to be keeping the food at the top and bottom at the correct temperatures. The problem we are having is that the bottom freezer has water pooling on surfaces that then freezes. We are not sure if this a drip pan concern or not. Is the drip pan between the top refigerator section and the bottom freezer section. Is there some kind of drain for the pan? Or do we have a more serious problem where the unit is turning off, thawing and the turning back on and freezing up the water.
  • 163 Answers
Hi!!!Your drain line is frozen and plugged.Try to remove the cover of the evaporator and you should see a small hole on the base of the evaporator thats yout drain line hole. Blow it away and your problem is gone..Good luckk..Plugged drain line..
Posted on Jan 03, 2009
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Water pooling below the crisper drawers at bottom of the fridge. Kenmore model #363.79262991
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Kenmore Top Freezer Refrigerator
Side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to the bottom of frig. I SEE a drain in the back right of bottom of frig but it sits up like a knob with...
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer
Nov 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
Drainhole location on my Whirlpool 2004 freezer top frig?
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Jan 23, 2009 | Whirlpool ET1FHTXM Top Freezer...
WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Nov 07, 2008 | Refrigerators
Sears Kenmore bottom freezer/refrig #68142model
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Jul 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
316 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
