My vs17e hp the blue light blinks but moniutor will not come on
The blue light will blink but the monitor will not come on . I have unpluged both cables for about 10 min. but that did not help any thing else I can try or isd the monitor broke?
  • 1 more comment
  • jtimduncan Apr 28, 2009
    The blue light blinks on and off and the monitor will not come on. After an hour or more the monitor will come on, then the problem repeats itself if the monitor is turned off and restarted.
  • jas_chahal May 05, 2009
    my cousins monitor vs17e HP monitor, power button is on, blue light, but no screen dispay, remains black as if off, intermittent dispay works previously, but I am searching for a solution, do I need to open it up and can I fix it with some advice?
  • Anonymous May 25, 2009
    i have an hp monitor, when i turn it on it displays recommended settings than goes blank.
    Novelist:
    Champion:
  • 254 Answers
The quick way to determine if defective is to either substitute a monitor, or take that monitor to another computer. If the problem follows the monitor, then the monitor has an internal defect. if this is the case, electronic troubleshooting expertise is needed to repair.
A defective video card or chipset in the computer, or if the computer is dead- these would be typical problems if the problem is at the computer end of things.
Posted on Dec 23, 2008
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
When I start my computer, the monitor can take up to a 1/2 hr to display. I have dual monitors; the 'Acer' will eventually blink/show 'Acer', then fade. It repeats every 3 seconds. The...
your problem sounds like you have bad capacitors on your monitors power board. once you start it, they do not have enough capacitance to give to start the monitor, but after letting it for some 10ish minutes or so, they capacitate enough to start. even then, after some time, they will lose the capacitance because they are feeding the monitor in constant power when the power from the outlet drops a bit, but being bad - they will shut off your monitor. some repair shops can change capacitors only, others would make you change the all power board
Aug 04, 2017 | Acer AL1511 15" LCD Monitor
Montior screen is half shaded and half bright
Do this to check if your monitor is in working state or not...!
Step 1:- Turn on your computer.
Step 2:- Unplug the Video Cable of your monitor which is connected with the computer.
( Video cable:- Cable going from the back of your monitor to the back of your tower. It has a plug with two screws on the plug ends, which you can unscrew to unplug it. Thats how it looks like. Some times it is in grey in color some times in blue.)
Step 3:- Now check on your monitor. If the display says " No Input Signal " :- your monitor is fine. Some thing wrong with the computer graphics.
If there is not display and the monitor light is blinking or solid the monitor has gone bad.
( Note :- Remember when you unplug the video cable do not unplug the power cable of the monitor. )
Let me know if it helps.
May 18, 2010 | Computers & Internet
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
I shut down my computer at night. When I come back the next morning the computer is off and the monitor is in standby with an orange power light (so far so good). When I turn the computer on, the monitor...
that blue light show and error or faulty problem internally or there a problem with in the connection or computer but first check the makers website or manual for troubleshooting.
Dec 13, 2009 | LG L1932TQ LCD Monitor
Have a t6532 running fine one moning blue light blinking no boot fan runs 3 seconds no noise then blue light blinks nothing runs.
UNPLUG all keyboard, mose and etc and plug only power suppl and then video cable with the cpu and then power on you can get the display in you monitor
Oct 20, 2009 | E-Machines eMachines Desktop PC
GATEWAY 2275 LCD MONITOR WENT OUT, WHEN PLUGGED
This could be due to a bad power supply inside the monitor witch is replaceable for like $25 bucks all you got to do is unscrew off the back undo a few cables and put in the new supply.
I hope this helps you in the repaire process if its under warrenty please seek warrenty guidlines.
Jul 17, 2009 | Gateway FPD2275W LCD Monitor
Power Light Blinks Orange on Gateway PC
go to the screen saver and click on monitor power then change the power schemes to adjust, and select standy into never...
Jun 17, 2009 | Computers & Internet
No picture - blinking blue light. My daughter was
There are a few things you can check. First, try to see if the monitor cables are firmly connected on both sides (computer and monitor) no need to remove any cable for now just check the monitor cables (ends should be blue or white on both sides) Then check if you got an imput button on your screen (like all TV and some monitors now has) This input gives you the choice between a few possible connections and it may be on the wrong one. Just cycle trough the input modes and I think you will have your image back. If Still, you dont see anything, try a different monitor or try to connect your monitor on a different PC/laptop. In fact blinking blue could be there because the monitor is awaiting a signal on the input it's listening. At worst it could be because your video chip/card dont send a signal to your monitor, could happen, but imo it's probably not the case.
Jun 08, 2009 | Gateway 1532121 Monitor
Computers & Internet Logo
667 people viewed this question
David Payne
David Payne
