Question about Zanussi TC180W Electric Portable Dryer
Condenser dryer Constant squeak and clother wont dry. Belts, bearing and heater element are all working fine
    President:
  • 1,462 Answers
Doubt if squeak is related to not drying. if you are getting heat (you say heating element is ok) take out condensor and hose it down till thoroughly free of lint. check appliance has adequate ventilation as well
Posted on Apr 10, 2007
SOURCE:
Constant loud squeaking
Squeaking is normally caused by a bad bearing or a slipping drum belt.
Feb 28, 2015 | Dryers
Squeaking
I have worked on some dryers of my own. The first thing I do is either purchase or go to the library and look at the maintenance/repair manual. These manuals have trouble shooting sections that are very helpful. Also, google it. I found several sites that appear to be very helpful. Squeaking is usually dry bearings some located in the rear of the unit, worn belt, worn carrier bearings or belts.
Nov 04, 2013 | Zanussi ZDC37100W Electric Dryer
Dryer squeaks when drying clothes
try letting the mouse out??? its likley to be the drive belt or rear bearing dry,,, could be the motor bearings dry,,
back bearing and motor bearings could be lubed with WD40 but dont put it any were near the drive belts as they will then slip like mad,
spray on the driv belt a bit of "stop squeak" its for car fan belts realy but it works on any rubber belt
Oct 24, 2009 | GE DRSR483ED Electric Dryer
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 07, 2009 | Kenmore Dryers
Irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Feb 20, 2009 | Frigidaire FEQ332E Electric Dryer
A Squeak
Hi.
Could be dry drum bearing or jockey pulley dearing. take the rear cveroff the back of the dryer, and you will see the rear drumshaft and bearing.
Squirt some wd40 on the bearing, hopefully.this will cure the squeak.
Nov 19, 2008 | Dryers
My Dryer squeeks while rinning
If it is a constant squeak no ups or downs then its the bearings in the motor that turns the drum. If the sound is not monotone, meaning up and down squeaks, then the drum is rubbing something foreign.
Nov 10, 2008 | GE DBSR453EBWW Electric Dryer
Kenmore Dryer Model 110.888029 Serial MH1102412 Type 180.00
MOST LIKELY PROBLEM IS A RESTRICTION IN THE EXHAUST. DISCONNECT THE VENT FROM THE BACK OF THE DRYER AND TRY DRYING ONE LOAD. IF IT DRIES O.K.,
THERE IS A RESTRICTION IN THE EXHAUST. CLEAN THE LINT OUT FROM THE ENTIRE LENGTH OF DUCT WORK.
Apr 08, 2008 | Kenmore 63942 Dryer
GE DBXR463GB Gas Dryer is squeaking loudly when it runs
one of 2 things can be wrong. Back bearing if bad will sound like a bird chirpping, front bearing glide will be more constant squeek. both need to be fixed by experienced tech.
Jan 05, 2008 | Dryers
Zanussi TC180W Electric Portable Dryer Logo
103 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
