Question about Sony VGN-A270: VGN-A270 Pentium M Centrino 745 1.8GHz, 512MB RAM, 40GB Hard Drive, DVD+/-RW Double Layer,... (VGNA270VGNA270PENTIUMM) PC Notebook
How To Install Hard Drive In Sony VGN-A270 NoteBook
Hi, my 60gb Hitachi hard drive went bad so I purchased a new identical one, but I don't know where the hard drive is located in this notebook and I don't know how to properly get to it. Sony's website states it doesn't support hard drive replacement by end users.
Please help
  • 74 Answers
I suggest you read this before you start so that way you know if it's somthing that you want to do.
This is for the VGN-A270 Laptop
but i'm sure it will work for your's
You will need a philips head screwdriver and a regular head screwdriver.
Put the laptop on top of a table or any other working area without anything that can caus static electricity which is not a computers friend.
Make sure the laptop is off and unplugged and remove the battery.
Turn the laptop over so the top is on a surface
Now you are looking at the bottom of the laptop and you will see a cover with vents.
There will be 2 silver philip head screws.
Remove those screws turn counter clockwise to remove those screws.
Now remove the plate.
You will see memmory and another card do not remove those.
On the top right hand corner where the plate coverd you will see another philips head screw.
Remove that by again turning counter clockwise.
Ok now there is 9 screws 4 on the left side and 4 on the right side.
You will see along the edges of the case 3 screws.
And in the middle right below the plate you will see 1,
on the bottom right, center right, and top right hand corner and right beside the battery compartment you will see 1 screw that's inside a square opening.
Now on the left side beside where the battery goes you will see 1 screw in a square again Remove that screw then again one in the top left side then 1 in the center across from the plate and one in the bottom left hand corner.
Now put the computer over the center of the working area you will be turning it rightside up and having the screws fall that you just removed.
Remember do not lose any screws that you don't want to do so you don't have to hold it to high so screws won't bounce everywhere.
Now you should have 10 screws on the working area if not turn it back over and see if any screws did not come out and loosin those screws and turn it over again.
Now set the laptop down right side up so you can open the lid.
Open the lid and the keyboard we have to remove now.
Take the regular head screwdriver or the flat screw driver and
There are 2 places where it snaps Above the F12 key and over the F4 key you will see that there is 2 tabs like and what you do is put the regular head screwdriver in there and push down towards the touch pad lightly and you will see the keyboard move down now lift up a little so the tabs are no longer in the slots that the tabs were in and the keyboard should lift up and out of the laptop.
Be careful with the keyboard and not drop it or pull on it just be easy with it.
Now the Keyboard is still plugged in which we need to unplug.
Now the ribbon is plugged into the keyboard and the other end into a latch which you take your nail and move it to your right and unlatch it.
And pull the cable up it will unsnap do not yank it.
Take the keyboard and set it down.
Now you will need to unplug the speaker cables which there is 1 opening to your right and you will see a red and white wire plugged into a white plastic box like just take your screw driver and pull to the right easy and it should unplug and then there is another opening to your right that is also red and white same thing unplug it do not rip it out gently unplug it.
Now there is a blue ribbon that is in the center you need to unplug that by putting the blue plastic tab and pull towards the lcd straight it should unplug easily enough.
There is 5 more philip head screws you need to remove in the center where the keyboard was you will see a opening and right to the left of it there is a thing a screw remove that and if you were looking at a clock at 10 o'clock there is another screw and right above that to the right at 1 o'clock
and another at 5 o'clock and the last one is right below the fan which you will see a little bit to your right and you will see that last screw remove that and put the screws with that one piece so you know where the screws are and what they goto.
Now below the lcd you will see the hinges you need to loosin this piece.
You just push a little on the center of the hinge on both sides and it should unsnap and lift up.
now pull up on the top and you will see at the top a white cable that's still connected so you pull up on the cable lightly to unplug it then put that top off to the side.
Now you will see the harddrive down at the bottom right and you will see the cable plugged into it on the motherboard grab each side of that cable on the edges and pull up it will unplug
Now there is 2 screws holding the cover for the harddrive.
The philiphead screws are closest to you one at the bottom left edge of the cover and one at the bottom right edge of the cover remove those set the cover off to the side and put the screws with the cover,
The cover now you will left up and your harddrive in in that cover.
Turn the cover sideways and there is 2 philiphead screws on both sides you need to remove those and the harddrive is in your hand and ready for you to insert the New HardDrive.
Once you put the new harddrive in reverse everything that you had to remove to put it back together again.
Posted on Dec 23, 2008
  • 59 Answers
Easy, and simple, if your laptop not too old like 3-5 year ago. in the back of your laptop, there is a hardrive icon looks like, and around these, it will have 4 screws, it is regular screw, just take them off, and you will able to open the cover and you will see the HDD, and check which model is your hdd, i means IDE (will have many pins in your hdd), STAT (the new one with no pins, only 2 ports)........... go buy one , just simple plug in and replace the old.
next step will be reinstall the window operation system......
that's it, the most difficult part for your . non-computer man is reinstall the window system
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Dell laptop HD
This model laptop came with a 60Gb hard drive and it will work with a 40Gb hard drive.
If it was me I would install a 60 Gb hard drive not a smaller one.
Apr 30, 2013 | Dell Inspiron Computers & Internet
How to get master password for hitachi hard drive
Wow, why don't you know the password? I'm not calling you a thief, but 99% of the time when you encounter a computer that has a lock on the hard drive and the person in possession of the computer does not know the password, the computer is stolen. The original owner puts a lock on it to keep thieves from getting to sensitive data.
Jun 02, 2012 | Hitachi Travelstar 5K100 HTS541060G9SA00...
I have a vaio nw150j with bad hard drive. What are the steps for ssd and new os install?
If you bought the same drive I don't see why you'd have to do anything to the Bios.
Apr 04, 2012 | Sony VAIO VGN-NW150J/S Notebook
How do I replace the hard drive on my sony Vaio VGN-NR120E?
To replace a hard drive, you'll need to backup any data you want to keep, uninstall the old hard drive, install the new hard drive, and then restore the backed up data.
The specific steps necessary to replace a hard drive differ depending on the type of hard drive you're replacing.
Jun 20, 2011 | Sony VAIO VGN-NR120E/S Notebook
Hi! My Sony Vaio vgn ux180 has a crashed hard drive. Also the cable connecting the hard drive is also damaged. I need a parts list so I can get that cable. Please help!?
You can browse their offer, here. Hard drive is here.You can research parts you don't see in previous links, here. Or you can call them on 1-800-488-SONY (7669) for immediate assistance.
May 16, 2011 | Sony VAIO VGN-UX180P 4.5-inch...
I have a imminent failure and when I press F1 then I start installing Windows the system doesn't detect my HDD. I have a bad sectors and I know it. But I can't solve it. Can you tell me more information...
The motherboard is quering the 'S.M.A.R.T.' status of the disk-drive,
and the disk-drive is reporting that it is about to "fail".
So, your motherboard is showing that "Imminent failure -- press F1 to ignore this alert" message.
Take your computer to a qualified technician, to see if it is "too late" to recover any files from your disk-drive, and/or to install a new disk-drive, and to install Windows.
Nov 09, 2010 | Hitachi 60GB Travelstar 5K160 Ultra...
I am trying to upgrade the hard drive on my sony vaio upgrade harddrive sony VGN-AR630E. I want to install windows xp on it, but it won't see the hard drive. What can I do?
its either the hard disk is bad or the operating system is faulty.try checking local computer fixers in your area.would like to know where youu leave maybe i can help.       thanks
Jul 02, 2009 | Sony VAIO VGN-AR630E Notebook
Gateway 450ROG only recognizing 7805 MB of 60GB hard drive
you may have to wipe that harddrive clean and start over new
Dec 12, 2008 | Gateway 450ROG Notebook
Computers & Internet Logo
615 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
