Question about Dayton 511 Utility Heater
UNIT LITES THEN GOES OUT BLOWING SMOKE
I HAVE A 150000 BTU KEROSENE HEATER. IT LIGHTS AND RUNS A MINUTE. THEN GOES OUT AND BLOWS FUEL AND SMOKE OUT. I HAVE TO UNPLUG IT THEN. SPARK PLUG, FILTER, AND TUBES ARE CLEAN. HELP...MARK
  • Anonymous Dec 31, 2008
    Heater will light and run for about one minute then extingueshes and blows smoke. The light on the power switch startes to blink.
Needs a new nosel and tuneup kit you can get it at sears for about 12.00 dollars
Posted on Dec 23, 2008
Pick the heater up throw It at the wall, the heater has been used to heat my uncles home no problem now it wont light, on the day its needed most outside in the freezing cold, so my solution was throw it at wall and go to walmart.
Posted on Jan 15, 2009
I have an All Pro 150000 btu kerosene / diesel torpedo heater. It runs for a few minutes and then starts sputtering, shooting flames and smoke. What causes this problem?
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If the units starts up and runs good and slowly goes out it will normally be due to a lack of fuel getting to the nozzle. When there is not enough fuel being delivered to the nozzle from either a clogged fuel filter of dirty air pump output filter the unit will slowly shut down from lack of fuel.
If the unit shuts down while it is running properly and the nose come is orange then you probably have a problem with a photocell or the flame out control.
If you have other questions you can contact our service department at 269-685-4125 at extension 224
Thanks
M Cramer
www.allpartsinc.com
Jan 04, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
My all pro 150000 btu heater sputters, shoots flames and smoke. what causes that?
The first thing to check would be the fuel filter from the tank to the nozzle.
Then check the input and output filters on the back of the pump housing.
Here is a link to a service manual.
Thanks
M Cramer
www.allpartsinc.com
I have a master 150000 btu kerosene direct fire heater that runs for 5 minutes then shuts down and blows white smoke. what is the problem?
The white smoke is the kerosene fuel hitting the hot combustion chamber. Your flame has went out. The cause for this could be many. The first thing you need to do is check your fuel. Remove your fuel cap and look at the bottom of the tank for trash or water. Use a good flash light. It will all settle to the bottom. If so, drain and clean out your tank. Add fresh kerosene. Check your fuel filter. Replace if dirty. Test again. If problem continues, It is possible that your photo eye could be deffective or just dirty. It is located next to the ignitor or spark plug. It sees the flame. If the flame goes out, the unit shuts down. The flame has to be smooth (not sputtering). Water in the fuel will make it sputter and the unit will shut down. When the water/moisture in tank settles to the bottom, your suction fuel line is just off the bottom which results in it picking up the water instead of good fuel. Always disgard the old fuel from previous year and start with fresh fuel. This will cut down alot of your problems in the future.
Dec 07, 2010 | Master Heaters B155DST
Heater runs a few minutes then blows smoke and cuts off
Are you using the old fuel from last year? If so, drain and clean the tank. Replace with fresh fuel and replace the fuel filter. Check or replace the air filters. Check your ignitor for proper operation. Test again. Good luck.
Dec 01, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Ready heater forced air runs few minutes then shuts off
Sounds like a full services like its getting too much air,and blowing out the flame. Check your fuel filter,and add a new spark plug ,also change the vanes on the pump, thus aFuu service. these sould be performed every fall before .
Dec 16, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
My 110,000 reddy heater flames up then after a minute or two just blows cold smoke???
Time for a Full tune-up, plug--fuel filter- 2-air filters -vanes in the pump.
Dec 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Kerosene reddy heater flame is intermitent
Heater had a cracked fuel line that was not visiable on original inspection.
Jan 25, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Blows cloud of smoke
thin your fuel mix with about a gallon of kerosene to 5 gallon of heating oil.could also be a semi clogged fuel line filter.
Nov 21, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton 511 Utility Heater Logo
516 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
