1. I'm new at this so i might have the settings wrong so it would definitely help to tell me how to set it up to play in HDMI first. 2. I know for a fact that the HDMI input to my TV works because I have my computer hooked up via HDMI.
Your resolution on your ps3 may be too high for the tv to display. Hook up your PS3 to you TV with the HDMI cable. Now, when you turn on
your PS3, hold the power button on the PS3 for 5 seconds. It will reset
the PS3 video options and recognize the HDMI connection. It will then
search for the correct resolution settings on the TV. Press (X) to
confirm. And that's it. You should be set. If not, then the TV is acting
rather strange.
Please try this procedure to connect the PS3 to TV..
The PS3 has a Blu-ray drive that can be
used not only for playing games but also for watching high-definition
movies. The best way to connect a PS3 to a high-definition viewing
device such as a video projector is through the PS3's high-definition
multimedia interface (HDMI) output. The HDMI connection can transmit up
to 1080p high-definition from the PS3 to the video projector using a
single cable. Attaching and setting up the HDMI cable will only take a
few minutes and will let you watch high-definition video from the PS3 on
the video projector.
Connecting HDMI
Attach one end of the HDMI cable
to the HDMI output connector of the PS3. Turn the HDMI cable around if
it does not slip right into the HDMI output, because the HDMI cable can
only fit into an HDMI connector one way.
Attach the other end of the HDMI cable to the HDMI input connector
that is on the video projector. Make sure both sides of the HDMI cable
is securely pushed into the connectors of the PS3 and of the video
projector. Turn on the video projector. Press the "Menu" button on the
video projector's remote. Navigate to the "Sources" setting on the video
projector's Menu. Select "HDMI" from the "Sources" setting. Press the
"Menu" button on the remote control again to exit the Menu.
Adjusting the PS3
Turn on the PS3. Wait for the
"Home" menu to appear on the video projector, although the quality of
the video seen from the video projector will be muddied and dark.
Navigate from the "Home" menu to the "Systems" icon using the game
controller and select the "Display Settings" tab. Choose "Video Output
Settings" from the list presented in the screen that appears. Press the
right side of the directional pad on the game controller to move to the
next screen.
Choose "HDMI" from the list presented in the screen that appears.
Press the right side of the directional pad on the game controller to
move to the next screen. Choose "Automatic" from the list presented in
the screen that appears. Press the right side of the directional pad on
the game controller to move to the "Confirmation" screen. Press the "X"
button on the game controller to make the settings active. Return to the
PS3's "Home" menu.
Watching the PS3
Insert a Blu-ray disc into the
slot at the front of the PS3. Wait as the Blu-ray disc begins to play
the video content on the video projector from the PS3 through the HDMI
cable.
Please don't forget to rate my answer...I really appreciate any ratings you done..
either your hdmi cord is broken your port is broken or your settings are wrong
try a new cord see what happens
or try this first go to your settings then the video settings and then change it to hdmi i think thats the way i dont have my ps3 so i cant tell you exactly
Quite often, the
cause of the no picture problem is a simple one - loose cords. Make
sure that the cords are plugged in tightly, both on the TV side and the
PS3 side. This is especially true with the HDMI cable connection on the
PS3. Often, it looks tight, but you still might need to wiggle it a bit
more to seat it correctly. Along the same lines, make sure that the
cords you are using are new and match the connections properly on both
the TV and your console.
2. Wrong Connection Settings
If
you are using the HDMI/DVI cables and you don't get any picture, make
sure to check your video ouput settings. If your PS3 thinks you are
using standard A/V cords to connect to the set, you'll have issues. The
opposite is true too - if you are using the A/V cords and your PS3
thinks otherwise, you'll have the same no picture problem. Make sure
you settings match the types of cable connectors you are using. 3. Wrong Resolution Setting
This
is also an easy mistake to make that can result in no picture showing
on your television screen. For example, if you've been using your PS3
with an HDTV and then try to hook it up to a standard definition
television set, you'll encounter this issue. The cure is simple; just
go into your settings and switch back to standard resolution and then
restart your system. The 720p resolution is the default setting and
this should work for most standard definition televisions.
Instead please try the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Do the following steps to solve your PS3 problem :
It won't there is a setting on the PS3 that you have to tell it on the HDMI connection that you want to transfer back to A/V cables. If you don't do that and you have been playing with HDMI and then switch to A/V then it will still try to load using the 1080i settings instead of the 480i thus you will have a blank screen on the TV. Hope this helps.
First, you need to set the playstation to display on HDMI out.
Plug the HDMI cable into the TV and into the PS3.
Use the PS3 to setup the video settings to 720p which every HDTV can display. Then switch the TV-out to HDMI and it should display.
Also consult your televisions manual to set it up for HDMI input as well. Make sure that the TV allows sound through the HDMI port as some older HDTV's didn't have that ability.
If you still have a problem; please let me know! I hope it helps you out
Green bar or border is due to wrong AV Setting. To resolve this just insert the Blue-Ray DVD and begin to play. Press the Triangle button and select "AV Setting", in AV Setting change Video Output to RGB.
the problem is with the frames per second that the ps3 is putting out. i wound up calling both samsung and sony and the problem was in the settings. the ps3 allows you the option of playing in 24hz and for some reason if the option isn't turned off our tvs won't display frames at that rate. just go to the dvd settings and deselect the 24hz option, changing it from AUTO to OFF... the only problem i have with this is that this should effect the picture quality, becasue if it isn't displaying in 24hz that means it is downscaling the display and if it isn't upscaled by the tv's processor, then the display should be worse. i might be imagining it, but it does seem worse.. atleast they play now though. hope i helped.
