Question about Onkyo HTR500 Receiver
Onkyo system Hi I really hope you can help me out! I can get my volume on my system up to vol. 41,then it shuts off, I've kept my system well ventilated, but did mess around with the controls... I have it hooked up to my direct tv, and the direct tv is hooked up to my tv...any ideas? my e-mail is sarah_gentry@hotmail.com Thanks! Sarah
  • Joe T.
    Joe T. Jan 13, 2009
    this is all common sense, not a solution. I think everyone knows how to clean dust out of electronics. Not to be rude, but dust build up wouldn't cut the volume. You might have blown a fuse, or your settings are set different. Worst case is that your speakers are not handling the high power input.
    Problem Solver:
  • 15 Answers
You have a shortcut, u need to verify ur speakers and the cables of all speakers, doit in this way:
1: remove all speakers cables from the amp.
2: connect 1 cable (this mean 1 speaker) only 1 each time and go to step 3..
3: turn on the amp, and increase the volume and see if this pass from the 41, the speaker that u r checking is fine.
4: doit with each speaker cable, this way u can check if the problem is a cable or speaker.
if in all speaker u have the same problem, means that the prob is inside the amp, and must be the toroid or maybe some one drop a clip or a metallic objet inside.
u can clean it, just buy an air spray (only compressed air) usually the spray has a little mouth with this u can introduce in the air breath of the amp, and clean it ( be sure to do it with the amp in horizontal way couse the spray sometimes spit cold water and can damage the amp.
if u try all and still the same i think u must take it to a service center.
good luck!!!
Posted on Jan 12, 2009
When i turn up the volume my amp shuts down i turn it down and it comes back on. I have a crossfire vr1000d what am i doing wrong?
Is the protect light in your amplifier turns on when it shuts down? If yes, then your amplifier lacks voltage. The reason why it goes on protect mode is, the amplifier is needing an amount of voltage from your car, since your car cannot provide that amount of voltage your amplifier is not getting anything, instead of getting voltage to produce watts its getting minimum voltage & producing heat, to save itself it goes on protect mode so the incoming power shuts off & cools the amplifier.
Example:
Your on vol 40, amplifier is working fine, when you turn it up to vol 50 your amplifier shuts of, then you put it back to vol 40 & your amplifier turns back on.
At vol 40 your voltage is 12v or above. but in vol 50 your voltage drops to 11 & below.
Check your battery or alternator if they are giving enough voltage
Hope this helps your inquiry. Have a blessed weekend.
Apr 24, 2011 | Crossfire Car Audio & Video
Onkyo AV Receiver TX-SR503 While sleeping with earphones connected, the receiver shut down and the standby light blinked. I unplugged the power cord, reconnected power and the receiver shut down...
Have you provided adequate ventilation?
May be your receiver is running hot and when there is loud volume it is obviously getting overloaded. There are no fans inside 674, the only way to provide good ventilation is to keep the top of receiver clear for atleast 6 to 8 inches.
Hope that helps.....
Jul 03, 2008 | Onkyo Audio Players & Recorders
The Vol button on my Onkyo RC-588M remote doesn't work
It probably can be fixed. Dirt and such gets on the contact pads...take it apart by carefully unscrewing it and remove the top half with the buttons facing you. You will likely see that the buttons are made of molded sheet of silicone, lift that off. Beneath where the mold was for the volume control you will see the actual buttons that control the volume, inspect it to see if it simply got pressed down too far and try to operate it that way and clean anything that needs it while you have it open. If it works without the silicone button cover panel on it, then you can take a small peice of paper wad and tuck it into the mold for the volume button so that when you press on it, it always makes contact.
Dec 14, 2009 | Onkyo TX-SR702 Receiver
L or R Channel cuttint out
You have a shorted speaker, crossed speaker wires Or a blown speaker. The amp is reacting to the short.
Start with one speaker by itself, unplug the rest. Check the polarity. Run it on the channel that cuts out. can you replicate it? Check the connections on the amp, and see if they are really close to touching.
Absolutely if it happens on both amps, unless you bought both B stock or Remanufacturerd and they have the same problem. This is rare
Hope that helps you!
Charles
Jan 09, 2009 | Onkyo Audio Players & Recorders
JVC th-m505 and dish network box sound level control problem
It's not your receiver, it's the Dish Network equipment, I have the same issue with my Onkyo...unfortunately I'm still researching the solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/deric_c8d727d0b065baea
Oct 30, 2008 | JVC TH-M505 System
Onkyo HT-R500 amplifier protection circuitry activated
u have a short.
remove all speakers cables and turn it on, if remains on and u can up the volume do the next.
1: turn it off.
2: connect only 1 speaker cable (each time to see if the short is in one speaker or cable)
3: turn it on, up the volume.
this way u must be able to see what cable or speaker have the problem.
if still the same prob the short is inside.
i put a answer of a prob where cant up of 41 check the cleaning method.
Good luck
Oct 27, 2008 | Onkyo HTR500 Receiver
What remote control code does the Onkyo TX-SR304 use?
1) Tap AUX
2) Press & Hold Setup (1 then 2 blinks)
3) Enter 30842 or 0842 (The remote should blink twice)
4) Press & Hold Setup (1 then 2 blinks)
5) Enter 994 (2 blinks)
6) Tap Setup (1 blink)
7) Enter "00051" (1 blink per number)
8) Tap Power (not All On, just "power") (The remote should blink twice)
9) Tap AUX
10) Press & Hold Setup (1 then 2 blinks)
11) Enter 30135 or 0135
Aug 27, 2008 | Onkyo TX-SR304 Receiver
Onkyo ts595 goes into protect mode with volume increase
HI check your speaker cables are not touching, also make sure "b" speakers are not on and that all your speakers are 4ohm or higher as this will cause the amp to shut down if they are to low an impedeance,The amp is protecting itself when it shuts down.
hope this helps.
CABLE GUY.
Aug 03, 2008 | Onkyo TX-DS575 Receiver
Sound control is via TV remote only
You didnot mention wehther you selected external speakers on you tv. If your TV allows this then do that, first.
Also the sound input to your TV must come from some source, (cable/ Sat). You could remove the audio inputs to your TV and only allow the audio to go to your Receiver.
RCA cables will allow this to be easy just remove the red and white audio to your TV. If you have sent them to your reciever then you must balance the cable box volume (reduce to the lowest level , then raise your recievers vol until satisfied if you are to loud when you switch to a CD then raise TV vol until they match, so your CD doesn't play to loud when switching modes)
If you are using an HDMI cable to your tv than there has to be a setup for turning off the internal speakers on your TV.
Dec 03, 2007 | Onkyo TX-SR605 Receiver
Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Nov 29, 2007 | Onkyo TX-SR605 Receiver
Onkyo HTR500 Receiver Logo
110 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
