Question about Sharp MX-2300N Color Copier
Sharp MX-2300N Maintenance required.code:TA
My printer shows "Maintenance required.code:TA" what's that means and how to reset this message
  • Anonymous Mar 20, 2014
    code showing on copier: maintenance required code dk
  • 3 Answers
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Posted on Dec 26, 2008
    Problem Solver:
  • 7 Answers
If these parts are serviceable and working fine you can reset the counters by entering the service mode. once in enter 24
then 4. This will enable to to select maint all and col all. once these are cleared however it is likely you will encounter maintenace cose Vk Vc Vm Vy DK DC DM DY if this happens go back into 24 and select drum clear on the choosen colour, and 24 again for dev counter clear.
Posted on Oct 19, 2014
  • Steve Gwynne Oct 20, 2014
    sorry about the spelling using iphone keypad.....
SOURCE:
My printer say maintaince required code: Ta. how repair
Call your printer technician for the maintenance because the printer is due for maintenance or you can clear the bin.
Jan 16, 2018 | PRINTER Office Equipment & Supplies
My sharp MX-C311 shows maintenance required Code TA
Hi, TA code refers to maintenance all counter has reached its specified limit. This usually means all the consumable parts have reached the end of their service life. If you have a maintenance contract with a Sharp dealer then they should replace all the units that require replacing & reset the maintenance counters for you, if you don't then, if the copy quality is still ok, you should be able to continue to use the machine as normal.
Hope this helps.
Dave.
Oct 15, 2017 | Sharp Office Equipment & Supplies
Maintenance required code TA
This is a scheduled maintenance error. It can be reset, but if you see it on the screen you likely need some preventative maintenance. If you're in the Houston, TX area we'd be glad to be your servicing dealer.
Feb 24, 2014 | Sharp MX-4111N Copier w/ 36 Month Warranty
Msg on my Sharp MX2300N
The TA code refers to the maintenance cycle of the copier. Its the copiers way of saying ''come and see if im ok''. I would recommend resetting the maintenance counters for your drums, developer, fuser and transfer belts. This can be done in the engineers menus.
May 06, 2013 | Sharp MX-2300N Color Copier
Sharp printer MX-2301N Code TA
Thanks for choosing FIXYA.
Have a nice day.
Jan 18, 2012 | Office Equipment & Supplies
What does Maintenance needed, Code TA mean?
Most of the time it means nothing. Do this.
On the consol, press # * C *,,,,,,,,,,,,,,, or P * C *.
Then enter the number 24,, press start. Then press 4, reset that counter. then 24 ,,, 5 reset that. 24,,,, 7 reset that .
The machine should run fine. Those are just numbers that are entered in the memory to make money most of the time.
If there is a problem , let me know the symptom
Nov 05, 2010 | Sharp MX-2300N Color Copier
Maintenance code TA does the printer go offline
Ok so the TA code means that the all maintenance counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 04
Then you can select what you want to clear so the maintenance count all
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
Jun 05, 2010 | Sharp MX-2700N Color Copier
Maintanance required code TA
# , * , c , *
May 11, 2010 | Sharp MX-2300N Color Copier
I am getting a message "maintenacne required code:dk"
DK means the black drum has reached its maintenance life - 50k copies. you need to buy an ARC26DU drum unit. The drum counter will need to be reset after its installed.
here is a starting point : http://electronics.pricegrabber.com/fax-copier-supplies/Sharp-ARC26DU-Developer-Toner-Drum-Cartridges/m12754437.html
Hope that helps.
Apr 10, 2009 | Sharp AR-BC260 Color Copier
Brother MFC-210C stuck in "please wait maintenance"
Press menu then start mono (b/w) then 4x arrow-up-button. Machine will be in maintenance-mode: What error code does the display show off?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Sharp MX-2300N Color Copier Logo
31,564 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
