Question about Harman Kardon AVR 225 Receiver
No sound I have just purchased a new Harmon Karon home theater system '225' I connected a HDMI cable to my new plasma TV but I can't get it to work or my DVD player, the onlt time my front and centre speakers work is when I tuning FM radio stations, I don't know what my problem is?
    Problem Solver:
  • 5 Answers
You need to have an input audio source on your receiver such as a DVD player or ipod. The radio is an internal source that is why yo uare hearing sound from it. One thing you could do is run a cable from the audio out jacks on your television to an input on the receiver, and then when you are watching TV select the input you put the cables in to hear the television sound through your receiver speakers.
Posted on Dec 23, 2008
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
Plasma tv/home theater
Is your Panasonic set to monitor the HDMI input? Just like selecting a mode input on the Tv you must also select the mode input on the surround system.
Bill
Dec 07, 2007 | Televison & Video
I have the Samsung HT-C550 home theater system and a Sony 42" HD TV. The two devices work well when playing a DVD but when I watch TV I can't get the TV sound through the home system. I am...
Try this:
Purchase a 3.5 mm jack (it will have a smaller connnector going into the TV and Red and White connectors on the other end).
Pull all the other cables running into the Blu Ray player out so that you are only left with the HDMI Cable coming from HDMI Out (DVD) to HDMI/DVI In (TV), along with the 3.5 jack.
You will be able to play the TV sound through the system.
Jan 13, 2011 | Samsung HTC550 Theater System
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
Connect home theater to tv
Do you have the cables connected to line out on tv ? Do you have the correct source and audio type selected in the home theater (analog/digital/coaxial).
Jan 18, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Surround Sound works with DVD, but not with TV, cable, etc.
dont know if it helps,but try connecting audio cables to the dvd from tv. worked for me !
Jan 05, 2009 | Sony DAVHDX265 System
Panasonic 1080p Plasma TH-42PZ80U Home Theater Setup Question
Hey Gamer1827,
While I personally can't provide you with any model-specific home theater system recommendations, there are a couple of common ways that you can generally configure your home theater.
Connecting several devices directly to the HTIB system may typically allow you to minimize the number of remote controls necessary, as long as the HTIB system supports the use of a universal remote. Should you not necessarily care if you have to change back-and-forth between two remotes however, you may have a wider variety of possible configurations available.
In order to use only HDMI cable connections to set up your home theater, you most likely would need an HTIB system with three HDMI ports: one for your TV, one for your PS3 and one for your cable box. Each device would require a separate HDMI cable running between it and the receiver. This option (in theory) would allow you to use one universal remote to control each device, assuming that they are all compatible with the same remote.
Another common configuration you might wish to try requires you to connect your cable box and PS3 directly to your TV. By doing so however, you might limit yourself to using an optical digital audio cable to make the connection between your TV and many HTIB systems. In this configuration, the cable box and PS3 would again have their own separate HDMI cables, while the optical digital audio cable would need to be run from the Digital Audio-Out port on the back of your TV to the Digital Audio-In port on the receiver. This option essentially treats the HTIB system as an expansion device, instead of the center of your home theater configuration.
Should you need any additional information or suggestions, remember that you may always speak with a sales representative at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
Panasonic HDMI surround system problem
The HDMI cable connection on your system is a video out to your TV.
To get audio from the TV so you can hear it through the system, you need to add a cable from the audio out of your TV to the "aux" input on the panasonic system.
This is most likely a red and white connection which will give you stereo, or pro-logic surround from the home theater system.
Dec 23, 2007 | Audio Players & Recorders
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Harman Kardon AVR 225 Receiver Logo
212 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
