Question about Toshiba 50HX70 50" Rear Projection Television
Tv repair I have a toshiba model 50hx70. There is no picture. There is a power light that comes on but no picture or sound. any suggestions?
  • Anonymous Apr 21, 2008
    I've got the same problem - my tv just went off and I just have a blank screen. The light on front of tv seems to flip from red to green. Any ideas, without being ripped off?
  • zippydave Sep 27, 2008
    Found fuse F470 (2 Amp) blown on main power board. I can not get connector off to input board to check power board.
    Problem Solver:
  • 5 Answers
This happened to mine. It was a fuse that cost $3.42 but the service call was $200! If I knew how to do the freaking work I'd be rich!
Posted on Mar 01, 2008
  • 143 Answers
Check all fuses then check horizontal out put tran sistor check for bad solder connections
Posted on Nov 03, 2007
Toshiba 50hx70 sound but no picture
NORMALY SOUND BUT NO PICTURE IS THE LAMP YOU SHOULD CHECK THAT TO SEE IF ITS BLOWN
Mar 07, 2009 | Toshiba 50HX70 50" Rear Projection...
No pic or sound with power on my Toshiba 50HX70 Tv
The plug configuration shouldn't make a difference; the third (round) pin is only an earth/safety ground. The two primary plugs supply the AC. You probably have a failed power supply which may be a separate board. Check to see if this is the case, look for a part number and see if you get any hits on it on search.
Jan 16, 2009 | Toshiba 50HX81 50" Rear Projection...
50hx70 blue projection light is concaced at top and bottom of tv
When the convergence amplifier ICs go bad (STK392-xxx), they RARELY cause more than one color to go out. The fact that the top and bottom of the picture are effected indicates the vertical convergence IC. Replace both, and while you're in there check the bias resistors... it is likely one of these is open. Once the ICs have been replaced (as well as any open resistors), customer convergence followed up with the auto convergence should do the trick.
Nov 19, 2008 | Toshiba 50HX70 50" Rear Projection...
Toshiba HD TV Model # 42HL117
Toshibas are notorius for Sustain board failure, You will have to find qualified servicer thru craigslist or yellowbook. If this is your problem, you could see a repair bill of 400+
Craig Cleveland Classic TV www.classtorations.com
Jun 08, 2008 | Toshiba Televison & Video
Toshiba projection tv
check for solder bridging between the IC pins. also make sure the wire connections are back in the proper locations
Feb 14, 2008 | Toshiba 50HX70 50" Rear Projection...
Picture & Color Distorted
Convergance IC replace.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50HX70 - red blinks but TV will not turn on...
Hi, you`ll need to call the tv guy then, you have a short in one of the power supplies, or possibly broken solder connections, either way the board has to come out and board repaired or parts changed, BMW Rider
Dec 02, 2007 | Toshiba 50HX70 50" Rear Projection...
TV picture shaking!!!
It sounds like the Hyper board is begining to fail....Does the menu shake too?
May 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Have sound and no picture
HI I HAVE THE SOUND BUT NO PICTURE BAT WHEN I BEND THE POWER BOARD OR PLAY WITH IT LEFT OR RIGHT THSN I GET THE PICTURE
Oct 02, 2006 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50HX70 50" Rear Projection Television Logo
157 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
