Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Connect TV to dvd player
I have a flat screen TV phillips and just brought a phillips dvd player and I need to know how to connect it.
  • Anonymous Jan 25, 2009
    I am trying to hook up my Sony portable DVD player to the Tv in my hotel room. When I looked on the back of the TV there is no yellow plug for the video feed, there are plugs for the left and right audio. On the back there are oter jacks such as purple, green and 2 USB connections. When I plugged the video plug into the green or purple ( I can't remeber ) I get video it's just black and white and my DVD player is showing color. Can anyone help
    Scholar:
  • 141 Answers
Hdmi, S-video or jack are the most common cables delivered with the dvd, you can plug an amplifier between tv and dvd for a dolby system.
Turn on the DVD player, the TV and Set your TV on "AUX" or "Ext" with the remote.
Posted on Dec 23, 2008
How do I connect my DVD player to my Apex flat screen TV?
Well, I don't know what kind of connections do you have, for my old DVD player I used an audio video cable. Connected audio video out from DVD to audio video in of TV. My current Blu-Ray player use the HDMI connection
May 11, 2015 | Televison & Video
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
Does the phillips flat screen tv have to be on a particular channel to operate the dvd player
Yes it has to be on the right av/ext
If you have connect the DVD player via a Scart lead all you have to do when your TV is on is then turn the DVD player power on and this should auto change your channel for you..... The scart lead send a voltage upto the tv so this changes the channel for you.
If this for any reason does not work. Then you will have to use your remote for the TV to flick through the AV/source button until you get to the DVD
Hope this helps you out.
Cheers Little Dish Fitter
Oct 06, 2009 | Zenith ZDA311 DVD Player
Sony Bravia with Phillps dvd player
The DVD player may have multiple output formats that can be displayed. Sounds like you have the composite output selected when you have the component output selected on the DVD player. Check the menu options on the DVD player and confirm they match the way you have the player connected
Aug 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Feb 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
462 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
