Question about Frigidaire ATF6000ES Front Load Washer
AFFINITY FRONT LOADER WON'T SPIN IN ANY CYCLE.
MODEL AEQ6000ES2 WILL NOT SPIN BUT BELTS AND SUCH APPEAR TO BE OK WHEN I TOOK THE BACK OFF. IS THERE A SOLONOID (SP?) THAT CONTROLS THIS AS IN OTHER WASHERS>
    Problem Solver:
  • 10 Answers
The problem is your door latch assembly. This is a common problem in Frigidaire front load washers. You need to replace the assembly. It is difficult to get to, you have to remove the entire front panel to get to it, but it should fix your problem. It costs around $50 and you can get it from your local appliance parts store or oder it from repairclinic.com.
Posted on Jan 02, 2009
I have a affinity front loader that will not spin. Is there a mixture of buttons to push to make this happen once it is stuck
If the unit will not spin during a cycle, check to see if you can turn or rotate the tub by hand when not in use. If not, you have a seized motor or transmission. If you can move it, then you possible have a bad belt, or control board.
Dec 23, 2012 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidare affinity model # atf6000es won't spin in
sometimes in the bottom right hand corner of the machine there is a little face plate and allows to you unclog foreign material that collect over time.
Nov 06, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
LED display on dryer reads AD???
All this is doing is letting you know that the Auto dry sensors are kicked in and checking to see how dry the clothing is.
Mar 29, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
Affinity washer front loader glacier blue
Since this is brand new, and that they are going to replace it, it should be fine.
Apr 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Sep 27, 2007 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
113 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
