Question about Roland MA 8 Computer Speakers
It seems that my volume control has a short
When i wiggle it.. the right speaker works or the left will work and the right one will stop... Is there an easy way to check the connections on the inside.
  • Anonymous Dec 31, 2008
    same problem
I have a 2010 cobalt lt. Today both my feont speakers quit working. And now my turn signals make no noise. Or the door chime or the seatbelt indicator does not work. What causes this and how do I fix it?...
The chimes an turn signal noise come out driver door speaker . Both front speakers not working could be a blown circuit fuse inside the radio or just blown front speaker channel . Your best bet , take it to a GM dealer or someother qualified repair shop . You have no idea of the complexity of this . The radio can set DTC'S - diagnostic trouble codes , believe it or not !
DTC B1025, B1035, B1045, or B1055
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3V AC and slightly higher.
DTC B1287 01: Amplifier Control Signal Circuit Short to Battery
DTC B1287 02: Amplifier Control Signal Circuit Short to Ground
DTC B1287 04: Amplifier Control Signal Circuit Open
The radio provides a remote amplifier mute output circuit to control overall muting of the remote amplifier. The amplifier receives pulse width modulated (PWM) signals on the control circuit at varying duty cycle percentages for controlling muted and unmuted functions of the amplifier. Circuitry internal to the radio monitors the remote amplifier mute circuit for faults and sets the appropriate DTC when faults are detected.
Feb 16, 2018 | 2010 Chevrolet Cobalt
Left Side of the car Speakers not working
yes there is certain chance for short circuit so better check whether the connections are proper ............
Aug 31, 2008 | Car Audio & Video
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at maurya.mohit07@gmail.com
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
Front left speaker stopped working. I use the system with my computer (full volume on computer), and usually half volume on the speaker. I've had the speaker for a few months now. I looked the wiring to...
You 'looked' at the wiring but have proven it is defective by swapping the speaker independent of the wiring. What's next? Replace the bad wiring.
What happens when you put a working speaker and wire on the front left output?
Apr 14, 2011 | Samsung HTC550 Theater System
Left speaker is not working on my 2.1 speaker system...
A few things can cause this to happen. First we should check the computer. Take a pair of headphones or other speak set and check if sound comes from both sides. If to then the computer output is correct, else the computer is channeled to output to one side.
To change sound settings, if this is windows, go to your control panel and look for sounds option. In there you can change speaker settings, change volumes. On the volume control you can balance the speaker output. center the slider to make both correct.
If sound is coming from the PC correctly with a test object you will need to check your speakers for a fade option, not many have this it is just a suggestion. If no fade option exists, make sure the plug is totally seated. Improperly seated plugs will cause only 1 channel to be outputted or none.
If all the above does not help then check the cabled leading form the computer to speakers for damage as well as checking the wire between the left and right speakers for damage. Many times the output lead from the right to he left gets damaged from stress or other things and will stop output. Wiggle and pull the wire gently in each direction if they don't physically look damaged to see if sound is produced. if it is then the wire is internally damaged or loose from the speaker.
good luck
Mar 14, 2010 | Altec Lansing Audio Players & Recorders
Right speaker without controls has stopped working.
plese change the wires and try the permutation and combinations.this wil lead to find out if the fault is in wire or in the port. this is purely a hardware fault.
Jul 29, 2009 | Logitech X-230 Computer Speakers
Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
Jun 27, 2009 | Labtec LCS 2424 Computer Speakers
Creative Speaker Of Model SBS-370 The Volume Control is not working, How to directly Connect those two Wires connected to Volume control,bypassing the Volume Control Switch
1. connect:Both Ground (copper wires) with Green wire
2. Connect Red with Blue and
3. Connect White with Yellow
This will give Stereo Output.
Apr 19, 2009 | Creative Labs SBS 370 Computer Speakers
Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Nov 12, 2008 | Logitech Z-2300 Computer Speakers
Only one speaker working
Even I have faced the same problem for the past six months.. Today i have fixed only issue with the back jack.. removed slowly and fixed it tightly.. it's works. :)
Oct 06, 2007 | Harman Kardon HK206 Computer Speakers
Roland MA 8 Computer Speakers Logo
53 people viewed this question
Top Roland Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
