Question about Toys
Need blade for world tech skyhawk helicopter - Toys
  • 20 more comments
  • 8shango Dec 28, 2008
    Need a blade for world tech skyhawk helicopter
  • Anonymous Dec 29, 2008
    Tail rotor
  • Anonymous Dec 30, 2008
    same
  • csteck1 Dec 30, 2008
    same thing!!
  • fdsfdsf Dec 31, 2008
    Same thing...there is no contact info on the toy, either. It needs a longer guard around the tail rotor to keep it from breaking by hitting the ground.
  • Anonymous Jan 01, 2009
    Same problem, no parts source readily available.
  • jphill11 Jan 01, 2009
    I got 3 good fly's out of mine before the rotor blade snapped in 1/2. Let me know which one works out.
  • Anonymous Jan 02, 2009
    i landed mine safley and the tail rotor snapped.its all because the rotor fin is to short.i cant beleive the trouble im having finding a replacement blade.world tech toys is obviously not a great company.
    need tail rotor for a sky hawk
  • Anonymous Jan 03, 2009
    Second flight and "snap", a broken tail rotor.
    has anybody found a replacement yet?
    Copter was fun while in the air.
  • csteck1 Jan 05, 2009
    Well,
    All the blades I purchased are similar looking. The problem is that none of them have any kind of a central hub like the skyhawk one does. I went to lowes and got some 2-part epoxy. I took my original broken blade (with the hub still in tact) and tried to glue it. I got some thin, flexible plastic (about 1/16" thk.), drilled a hole to fit over the hub and then cut out a rectangle that fits the "raised" area on the back of the OEm tail rotor. (note - drill the hole 1st - it is very difficult to cut the square and then drill the hole). I mixed up the epoxy, glued the blade together AND to the new plastic shim. I made sure to drag soe of the epoxy up the hub as well (but make sure NONE gets into the hex notch in the hub!!).
    I then made sure it coated around the whole side where the screw goes in (but, again, not in the hole for the screw).
    I figured, why stop there - I made a 1/2" extension for the tail safety landing blade (the yellow blade that is a useless tail rotor protector). I just glues that on as well. Now there is a 1/2" between my tail rotor and the ground. It flies, but make sure you do your best to "balance" the glue joint on the tail rotor blade. The hole should be in the exact center of the shim and there should be equal amounts of glue used for each side of the blade. If your tail rotor broke further out towards the tip of the blade, I suggest fixing it the same way, but also glueing a "dummy" fix on the opposite side blade - for balance.
    Good luck. Oh, My upgrade from this toy will be a Blade MCX micro RC. They are about $125 and got rave reviews for being the best micro with the best controls.
    Thanks,
    Chris
  • ed1468 Jan 07, 2009
    Tail rotor on mine too. I got 6 flights out of it. Broke the flimsy plastic battery holder too. I can't find anyone that supplies parts. Anyone? My daughter bought this for me with her saved money, what a ripoff!
  • Anonymous Jan 08, 2009
    i need tail blade too
  • Anonymous Jan 11, 2009
    same total rip they dont even have a website i hope this company fails gets sued for evrything or mkae a website!
  • chitt451 Jan 13, 2009
    I had about a 20 second flight crashed and broke one of the main rotor blades. Will sell for parts if anyone is interested. Email me at chitt@mail.mcg.edu and put helicopter in subject line. Will sacrifice for $25 and you pay the shipping.
  • cfrye2530 Jan 13, 2009
    when i got mine it was broke in box but i kept it i now need several parts if any one can help please email at CFRYE2530@YAHOO.COM THANKS STEVE
  • hertzing Jan 20, 2009
    bought mine for 10 year old, has always been good with remotes but broke main roter blade on landing. Would like info on getting a new one, called macys where we got it and they had no clue how to get a new one or who too call??????????
  • Anonymous Jan 25, 2009
    I have a world tech skyhawk and i broke the main rotor blade. I cant find any info on this company!!! it is very frustrating to finally learn how to flythis thing and then to have it break on me! and the fix is sooooo simple!!!!They should include a set in the box.
  • j_loeb1980 Jan 29, 2009
    back rotor blade and front cover
  • Anonymous Apr 13, 2009
    anybody know were i can get a replacement rear rotor blade? it's realing frustating!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • salzman Dec 27, 2011
    You can find many of the Chinese toy parts at the following location.
    http://www.china-toy-wholesale.com/spare...
    Good Luck hunting, James
  • jaycrecelius
    jaycrecelius Feb 19, 2013
    bought my son the phantom for xmas worked for on day store would not take it back due to going out of business now i cant even get a hold of world teck toys any help
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Posted on Dec 22, 2009
These copters are actually made by the companu Syma for many differet sellers. If you google syma heli parts, you'll find about 50 suppliers.
Posted on Nov 01, 2009
I just bought 4 tail rotors (Syma 9093) on Ebay for $10.00 plus $2.95 shipping.
DB
Posted on Jan 28, 2010
Http://www.hobbymega.com/products/pc/Parts-Tail-Rotor-for-2-Channel-RC-Helicopter-66831-18p527.htm
This appears to be the tail rotor blade.  I've ordered 2.
Posted on Apr 08, 2009
Well,
Here;s what I am trying - I went to Hobbyzone.com and got (3) different tail rotor blades from 3 different helicopters (each about $3). I'll see which one is the easiest to retrofit and I'll post my results. I will also be making the tail rotor safety wing longer somehow.
I got 6 crashes out of mine before it broke...how about you guys
Posted on Dec 31, 2008
I bought one from someone who broke the tail rotor. I bought an E-Flight one to retro fit. I just used the screw to hold it in place. I flew it, but the heli needs adjustment. I looked at adapting the large tail gear from the E-Flight heli, but still thinking on how to go about it. I hear the Syma .603 helicopter is simular (sales@grandhobby.com). To the poster with the heli turning in flisht, there is a screw on the side where the on-off switch is. Turn anticlockwise if heli turns anticlock wise, and clockwise for clockwise.
Posted on Jan 12, 2009
Need a main gear for the colossus gyro metel helicopter where can i find one about maybe 2 inches in diamter
Posted on Jan 17, 2013
I recently purchased the Nano Hercules for my son. Flew it once and now lower rotor won't spin. Any suggestions on how to fix it. I can't reach World Tech Toys......
Posted on Dec 28, 2012
Pending on which way it is spinning (clock-wise or counter clock-wise) there is an adjustment near the on/off switch on the helicopter. Example: if it is spinning counter clock-wise adjust to the right. Hope this helps!
Posted on Jan 03, 2009
Sky Hawk Helicopter came with no instructions. Where can I find instructions. Helicopter will not fly straight, it keeps going round and round.
3 Suggested Answers
  • 906 Answers
SOURCE: find charger for world tech rc helicopter skyhawk
good day,
hope this link below will help tp solve your problem.
toys
Posted on Jul 29, 2010
ginko
  • 19396 Answers
SOURCE: Need an adapter for World Tech Skyhawk R/C
Hi.
I suggest contacting Great Planes. They sell the batteries and chargers for Worldtech helicopters.
Here the link: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGBM2&P=FR#otheritems
Posted on Dec 21, 2010
Testimonial: "Excelletn, thanks!"
How do i turn on
How do I turn the sound down on my kindle hdx
Jan 03, 2014 | World Tech Toys Saturn-X 2-Channel RC...
World Tech Saturn-X - spins, rudder trim doesn't help
I know what the problem is, i had the same issue right out of the box. if you take the cover off the front you will find the battery. on the bottom of the battery is a 2-sided sticky tape to hold it in place, on that tape the is probably a pulled wire. theres red blue black and white (as well as a thicker red and black that lead to the battery. find the wire that is pulled and solder it to the correct part. for me it was the white cable which controlled the top blades. the helicopter spins because both set of blades should counter rotate and if one of the motors isnt getting power from pulled cable the helicopter will spin and flip. Hope this helped. email me at thedew312@gmail.com if you need more help finding where the wires connect
Dec 28, 2012 | Worldtech Devices World Tech 85618 2CH...
Where can i find a tail rotor blade for a Expansys Skyhawk Rc 2 Channel Helicopter
theres ahobby store in reseda ca. its called heli somethin its on victory blvd i called 411 and they found the number
Sep 09, 2011 | Worldtech Devices Expansys Skyhawk Rc 2...
Find charger for world tech rc helicopter skyhawk
good day,
toys
Apr 30, 2010 | Worldtech Devices World Tech 14422 multi 4...
Worldtech skyhawk helicopter 7700-spins in circles and won't lift off.
Mine has 2 female ends. 3 people 1 of which is an engineer have come to the conclusion that they put 2 female ends on and we can't charge. Plus there are no replacement blades as advertised on the box and it needs batteries for the controller even though it states "batteries included"
Dec 15, 2009 | Worldtech Devices Toys
Toys Logo
8,577 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
