Question about Dryers
Drum belt broke
How to replace drum belt on electric Kenmore front load dryer?
  • 943 Answers
Http://www.applianceaid.com/slidewpdry.html Hi here is a step by step way of replacing the belt
Posted on Dec 23, 2008
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
The belt that rotates the drum broke. How do I remove the Back to replace the belt ?
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Oct 04, 2010 | Kenmore 64902 Electric Dryer
My kenmore dryer has become so loud it hard to use with all the noise
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine.
Note: This method works with most front loading machines.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical consol with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Oct 01, 2010 | Kenmore 64932 Electric Dryer
On a series 90 kenmore dryer where is the belt front or back
Anwer to your question: Front
Basic Information...
Sep 30, 2010 | Kenmore 64952 Electric Dryer
Replacing dryer drum Kenmore Elite Electric Dryer
Usually from the front. Lift top and remove front. I can't image it would be worth replacing the drum. What is wrong with the drum? or do you mean the belt to drive the drum.
Jul 25, 2010 | Kenmore Dryers
Replacing belt on 69808 kenmore electric dryer
If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7.
Good luck, I hope this helps Please do not forget to rate me Thank you
Jan 02, 2010 | Kenmore 63102 Electric Dryer
Two year old kenmore dryer has loose drum
Your problem sounds like drum rollers that are worn very badly.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers to see if they are worn or the bearing area is worn or flat spots, if they are worn in the bearing area or have flat spots on them replace them.
Good Luck,
I hope this helps
Oct 29, 2009 | Kenmore 62602 Electric Dryer
Element heats but dryer drum does not turn. It is a front loading Kenmore dryer. It seems the drum is off what ever it is that keeps it in place.
Your belt broke or just came off. The belt keeps it in line and turns the drum. If you're handy you can replace it yourself. make sure the thing is unplugged, it's 220 volts. take the back off. the belt goes around the whole drum and the motors pully. It takes some doing but it is doable. If it's broken, Order a new belt from the dealer and replace it. or if you're not so handy or just don't want to deal with it call a service man to replace it.
Aug 10, 2009 | Dryers
Dryer belt broke on my kenmore series 80
With the front cabinet panel off, place the drum against the back and on the rear rollers. The roller on the right will sometimes move toward the rear so reach from underneath and pull it forward. The rollers should sit in the groove. The drum will tilt forward but shouldn't fall off. Route the belt around drum, pulley and motor. Tilt the drum back and support it while placing the front panel back onto it's hooks. With the front panel on (don't screw it on yet), rotate the drum by hand to make sure the seal is not kinked and the belt won't slide off the pulley or motor. If all is well screw in the front panel and re-assemble the rest.
Feb 16, 2009 | Kenmore 62622 Electric Dryer
Drum does not rotate
The drum rotates due to a belt that goes around the drum and is driven by a small motor. The most likely answer is that the belt broke. This a common problem on an older dryer. It is relatively easy to replace the belt.
Feb 01, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
131 people viewed this question
Top Dryers Experts
